ISO 9001 Clause 5 - Leadership (as a Process?)
Solitude
I work for a company who are not currently ISO9001 certified, but we have very recently started working towards certification to ISO9001:2015. This is because the MD and Senior Management team think that it is right for the business, and a number of potential and new customers are requesting this.
I had a visit from a key customer in the week who stated that there should be a business process clearly defined for Leadership. I do not agree with the auditor.
My take on it is that for clause 5.1.1 - General, we can demonstrate that the Leadership is fulfilling the requirements of a) - j) with objective evidence which could be verified through audit activity.
For 5.1.2 - Customer Focus point a), the specification provided as part of the design process along with the technical file for our CE mark meets this requirement.
Point b) is addressed through our risks and opportunities register
Point c) we monitor and measure customer facing metrics, track repeat business and are looking ta introducing customer surveys.
For 5.2, there is a quality policy in evidence that meets the requirements defined, and this is communicated and there is evidence that people are aware of this and understand it.
For 5.3, we have an organizational chart, job descriptions and process documents which define the requirements of a) to e).
Has anyone got any thoughts on the need for a Leadership process document? I am struggling to see the need, but the customer auditor was adamant that one was required. Am I missing something? Thank-you.
Jane_S
Hello!
I had to check the ISO 9001:2015 after I read your post.
To answer to your question - there's no requirement to have a documented process/procedure on Leadership (to be honest, for me it is hard to imagine how it could look like). There are different ways how to comply with the requirements of ISO 9001:2015.
For example, in my company we just document our quality policy together with the Top Management's commitment in the quality manual (which minus the procedures and work instructions consists of like 3 pages which mostly cover the "Leadership" part). Of course the revision of 2015 doesn't require to have a documented quality manual anymore, but it doesn't mean that you should throw it away and are forbidden to establish one if necessary.
As for the quality objectives - those a set during annual management review and all the employees are informed about them (they ale placed on the board, for example).
All employees have seen the Quality manual and there are training (if you can call it like that) records referencing the Quality manual. Hence after the previously mentioned 3 pages are read and understood all employees know what is the quality policy of the company, who sets objectives and what does the QMS mean and why it is necessary. Which means the quality policy and all the other leadership stuff is known and understood throughout the organization.
So in general: one way is to cover the 5.1. of ISO 9001:2015 is through quality manual (for the things which are set in stone) and annual management review (for the things that can change and have to be evaluated - like the effectiveness of QMS)
Solitude
Thanks Jane. I was struggling to see how the process would look like in my mind too to be honest.
What you have suggested is along the lines of my thoughts and what we are looking to do to meet the requirements.
howste
Thaumaturge
Looking at the definition of a process may help to decide if it makes sense:
ISO 9000:2015 said:
set of interrelated or interacting activities that use inputs to deliver an intended result
If you look at leadership as a noun (group of leaders), then it's probably not a process. If you look at leadership as a verb (act of leading) then you might have a process.
I've seen MANY organizations that have a process named Management Review or similar. This could just as easily be called Leadership. The inputs to the process consist of information and metrics from all of the other QMS processes. The intended result would be improvement of those processes, achieving objectives, profitability, etc. This is a process that oversees all of the other processes and determines decisions, actions, and resources to be applied throughout the organization.
All of these activities are required and need to be done. Ultimately, your organization decides what processes you need to carry them out and how you'll define them.
Kronos147
FWIW, we have defined the following core processes for our small machine shop:
-Management
-Production
-Purchasing
-Customer Related Processes
-Inspection & Compliance
I would answer a customer\auditor that Leadership is a 'sub-process' of Management, based on the Context of the Organization being we are a small machine shop, with 5 core processes and sub-processes identified underneath.
Solitude
Thanks @Howste. I agree with what you say, and looking at the definition as a noun or a verb helps. We have a Management Review process with inputs, activity and outputs. We have a documented QMS including a policy and a customer monitoring process. I think that I am going to argue that we do not need a standalone Leadership process, and give him the evidence we have that shows we meet the requirements defined within section 5 of the standard.
Solitude
-Management
-Production
-Purchasing
Thanks @Kronos. I agree that leadership is part of the management process. I will post my Process Interaction map later today, as I think it may be too detailed, e.g. we have a series of management processes.
Alienraver
I have lumped our management process into the Support Process. Our support process includes things like high level quality, IT, Leadership (Management) and Safety. Which as a manufacturing facility are all supporting the major process of production. There are others, we have a total of 6 CORE processes for our business, about 185 employees.
Coury Ferguson
Moderator here to help
Good job on that. Management is a Supportive Process. Management/Leadership makes decisions for the organization, that can affect interested parties and should be identified somewhere, in my opinion.
I like what you did with that.:applause:
J Iso 9001 Clause 7.1 - Advice needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
J ISO 9001:2015 Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J ISO 9001 Clause advice Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
K ISO 9001 Clause 8.3 & 8.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO 9001 Clause 8.3 Design for an education services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Determining if Maintenance Contractor is an External Service subject to ISO 9001 Clause 8.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
S ISO 9001:2015 Clause 9.3.2 - MR (Management Review) - Adequacy of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001:2015 Clause 8.7 Control of Nonconforming Outputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D ISO 9001:2015 Clause 8.4.3 "Information for External Providers" buying from online retailers. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
E ISO 9001:2015 Clause 10.2.2 - Evidence of all nonconformities and actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
qualprod Only manufacturing, non applicable - ISO 9001 Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
MichaelDRoach ISO 9001:2015 Clause 9.3.2c)3) - What process or processes is this focused on? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Clause 8.5.5 and Clause 8.6: which one should be coming first? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
GStough ISO 9001:2015 Clause 8.4.2 - Who Is The "Its" in (a)..The Supplier or Their Supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Which ISO 9001 Clause applies to "Procedures are outdated"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to comply with ISO 9001:2015 Clause 7.4 Communication ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
J ISO 9001:2015 Cl. 8.1 - 'and to implement the actions determined in clause 6' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Referencing ISO 9001:2015 clause for Audit General Auditing Discussions 10
P Design and Development Clause ISO 9001:2015 Exclusion for Medical Services Design and Development of Products and Processes 3
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
K ISO 9001:2015 Clause 5.1.2 Customer Focus (a) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Values - ISO 9001 2015 - Clause 4.1 Note 3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
armani How to 3rd Party Audit ISO 9001 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M What do you do for ISO 9001 clause 9.1? Key Performance Indicators ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001:2015 - Clause for Correction of a QMS Nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
armani How to approach ISO 9001:2015 Clause 7.1.6 when 3rd Party Auditing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K What can be considered a "Post Delivery Activity" (ISO 9001:2015 Clause 8.5) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
armani ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
armani ISO 9001:2015 Clause 7.1.1.b refers to ....? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S What do I have to do for ISO 9001:2015 Clause 6.2 - Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S What do I have to do for ISO 9001:2015 Clause 4.1 and 4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
