ISO 9001 Clause 7.5.2 Validation of Processes - How to comply?
Jandro
Okay, so I've read many of the threads (debates :popcorn:) about this clause. A lot of them are about what is or isn't a special process (so as to exclude or not exclude). Not what I'm looking for.
What I do need: Help grasping a tangible way to fulfill this requirement. A real world example would help me a lot. My company takes sheet steel and cuts it to various widths and lengths (an oversimplification) and redistributes the processes sheets or coils.
Please help me by using a real world example on how 7.5.2 gets fulfilled. Feel free to use my process / product (or not).
Thanks so much ahead of time. This forum has been a big help for a long time. So much so that I never post because the search function has helped tremendously.:thanks:
mdurivage
Re: 7.5.2 Validation of Processes - How to do this?
"7.5.2 Validation of processes for production and service provision
The organization shall validate any processes for production and service provision where the resulting output cannot be verified by subsequent monitoring or measurement and, as a consequence, deficiencies become apparent only after the product is in use or the service has been delivered."
First are you 100% verifying the finished product cut size? If not I would run a validation that tests the systems ability. I would cut something at or just below the smallest size, at or above the largest size, and something in the middle to demonstrate the process is in control and stable.
Hope this helps!
Jandro
We perform three main inspections: Setup, In Process, and Final. These inspections measure the dimensions we cut the material to, but as a sample. There is no (reasonable) way for us to measure every dimension of every piece.
When an inspection fails we segregate the material until (later) it is determined whether it can be re-purposed (reworked or another application available) or not.
When you say a validation that tests the systems ability do you mean something like an xbar R chart? We have performed PPAPs for those customers that require it, but not sure if you meant that? Sorry for the confusion on my end and THANKS so much for your reply!
somashekar
Hi Jandro.
Welcome to the COVE and thanks for your encouraging first post...
What you can cut, you can measure, and you will take all the care to set your machine and cut within your required tolerance and periodically verify what you cut.
Take for example the plating process. This process is different than cutting in sense you cannot test the thickness and adhesion to the sheet at all places and on all sheets. Any defect in plating will not show up also until the sheet is put to use or later after certain time elapses. There are things to control in the plating process, and things to control in the sheet pre cleaning and preparation process. How much these have to be controlled within (Ex: current / bath concentration / time / anything else) to get the desired plating requirement ?
When you have this optimum set up parameters after you do some of your trials and apply learning from past experience, you are validating.
Big Jim
It does not appear that what you do includes any special processes so you have nothing to validate.
If you were to include welding, plating, and/or heat treating with what you either do or what you sublet, then you would have special processes that require validation.
L
lyang
If you define your process A, B, C, and what's critical to A, B, C then we can help more. Special process that requires validation is defined within the following documents:
www(dot)fda(dot)gov/downloads/Drugs/GuidanceComplianceRegulatoryInformation/Guidances/UCM070336.pdf
www(dot)imdrf(dot)org/docs/ghtf/final/sg3/technical-docs/ghtf-sg3-n99-10-2004-qms-process-guidance-04010.pdf
Basically, any processes that does not make sense to 100% verify, should be validated. Hence, a lot of company perform process validation & capability studies in order to perform sampling in a more meaningful way.
Jandro
Thanks everyone for responding!
(EDIT found the thank you buttons!)
I'm worried this will boil over into a "what should / should not be validated" discussion. My question is really (probably laughable to you guys) "How to validate a process / product?" or "What are some typical methods for validating a process or product?"
somashekar
There are many things that are person controlled, like hammering a nail, driving a screw, chiseling wood ...and so on. These are skill with tools, and operator competency and his qualification are the controls.
There are other things that a machine tool does, like turning a steel rod, milling a shape on a block, and so on. The controls are direct and are manual on the machine tool or are numerical controlled. Apart from operator qualification the machine capability comes into play, and includes machine proper installation and commissioning, calibration and correct tooling.
There are other things like plating, cement manufacture, sterilization, many adhesive processes, chemical processes, where controls are indirect (like pressure, temperature, speed, concentration, current, voltage..etc) and are set to optimum levels to get the desired output. Including operator qualification, this exercise also captures the equipment installation and commissioning and can also include calibration. We could call this as process validation.
Jandro
Okay, thanks again everyone. I've found some resources online now that I have limited my question to "what is validation?"
Big Jim
To some extent, the answer is given in the standard.
a) defined criteria for review and approval of the processes,
b) approval of equipment and qualification of personnel,
c) use of specific methods and procedures . . .
A method of validating welding is to certify the welders so b is the method.
Soldering is often validated by certifying the technician and following guidance from one of the IPC manuals.
Plating and heat treating are often validated by following specific specifications (for plating, tank chemistry, time in tank, rectifier settings, tank temperature) (for heat treat, temperature of oven, length of time in oven, and how quenched).
If you have a special process, you need to figure out how you can tell with a high degree of certenty that the product is viable.
Puzzle your way through determining how a fire sprinlkler company can ensure that their sprinklers will work in a fire without destroying them during testing, and you should begin to see what needs to be done to set up a good validation program.
J Iso 9001 Clause 7.1 - Advice needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
J ISO 9001:2015 Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J ISO 9001 Clause advice Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
K ISO 9001 Clause 8.3 & 8.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO 9001 Clause 8.3 Design for an education services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Determining if Maintenance Contractor is an External Service subject to ISO 9001 Clause 8.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
S ISO 9001:2015 Clause 9.3.2 - MR (Management Review) - Adequacy of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001:2015 Clause 8.7 Control of Nonconforming Outputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D ISO 9001:2015 Clause 8.4.3 "Information for External Providers" buying from online retailers. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
E ISO 9001:2015 Clause 10.2.2 - Evidence of all nonconformities and actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
qualprod Only manufacturing, non applicable - ISO 9001 Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
MichaelDRoach ISO 9001:2015 Clause 9.3.2c)3) - What process or processes is this focused on? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Clause 8.5.5 and Clause 8.6: which one should be coming first? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
GStough ISO 9001:2015 Clause 8.4.2 - Who Is The "Its" in (a)..The Supplier or Their Supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Which ISO 9001 Clause applies to "Procedures are outdated"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to comply with ISO 9001:2015 Clause 7.4 Communication ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
J ISO 9001:2015 Cl. 8.1 - 'and to implement the actions determined in clause 6' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Referencing ISO 9001:2015 clause for Audit General Auditing Discussions 10
P Design and Development Clause ISO 9001:2015 Exclusion for Medical Services Design and Development of Products and Processes 3
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
K ISO 9001:2015 Clause 5.1.2 Customer Focus (a) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Values - ISO 9001 2015 - Clause 4.1 Note 3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
armani How to 3rd Party Audit ISO 9001 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M What do you do for ISO 9001 clause 9.1? Key Performance Indicators ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001:2015 - Clause for Correction of a QMS Nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
armani How to approach ISO 9001:2015 Clause 7.1.6 when 3rd Party Auditing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K What can be considered a "Post Delivery Activity" (ISO 9001:2015 Clause 8.5) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
armani ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
armani ISO 9001:2015 Clause 7.1.1.b refers to ....? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S What do I have to do for ISO 9001:2015 Clause 6.2 - Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S What do I have to do for ISO 9001:2015 Clause 4.1 and 4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
