ISO 9001 Clause 7.6 Measuring Devices cannot be excluded!?
jeanmarc - 2011
#41
Correct, the person's weight & height would indicate whether the person would need to undergo other medical tests. Subject to the results of these tests, e.g if the person is a little overweight and might be suffering from diabetes as confirmed by additional blood tests, then the premium shall be different.
One thing that also catches my mind is that the does clause 7.6 apply to Product Realisation only? In our case, the product requirements have already been defined; and weight and other parameters are happening in the service delivery to the client.
Would be great to your views on same also.
JM
harry
#42
Not yet! You/your organization had not agreed to underwrite the case. It is under 7.2. contract review or customer related process.
Colin
#43
Clause 7.6 (2nd paragraph) states 'The organisation shall establish processes to ensure that monitoring and measurement can be carried out and are carried out in a manner that is consistent with the monitoring and measurement requirements'.
Now, to me the last part of that requirement is saying that we should choose the monitoring and measuring we require for the job in hand. So if we require a high degree of accuracy and the criticality of the measurement is high, we have to select suitable equipment and ensure appropriate calibration methods. Likewise, if the measurement is less significant we can also choose appropriate methods.
I would suggest that the weighing of the person is unlikely to be required to be of great accuracy - perhaps within a band rather than a specific weight - so the method of calibrating the scales need not be too critical. By all means send them away for checking but I would look to do it 'in-house' from now on by getting something of a known weight and checking them yourselves periodically - I refer to this as coarse calibration and it often suitable for the job in hand.
jeanmarc - 2011
#44
Thanks Colin.
JM
harry
#45
Exactly and thanks Colin.
Helmut Jilling
Auditor / Consultant
#46
I would agree. You are going to a lot of trouble to send the scale away, incurring cost. The standard allows for calibrating and verifying gages. A simple way to verify in your case - you could specify that you want your scale to be accurate to within one pound, or maybe 1 KG. Then, buy three or four test weights of 50 lbs, and verify the scale at 3 or 4 points -50, 100, 150 and 200 lbs. Record it, and you have met your needs and the requirement at a basic level suitable to your needs.
Jake.E
#47
Sorry for bringing this back from the dead....
We got hit with a Corrective Action from a DCMA NSEP-QAR inspector (Level 1/Sub-Safe Inspector) for not having our CMM Software calibrated per ISO 9001. Even though the CMM itself was calibrated annually. I ended up going to CMM-Manager and getting the PTB Certificate as well as a copy of all of the Release Notes before he accepted the Corrective Action Response from us.
#48
Ha! An oldie from the grave, indeed. DCMA dude has no clue. Software isn't calibrated! I guess you did good, under the circumstances...
Jake.E
#49
The sad thing was he sat down and read through all 80 pages of Software Release Notes, and the PTB Cert.
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO 9001 Clause 8.3 Design for an education services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
S ISO 9001:2015 Clause 9.3.2 - MR (Management Review) - Adequacy of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001:2015 Clause 8.7 Control of Nonconforming Outputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D ISO 9001:2015 Clause 8.4.3 "Information for External Providers" buying from online retailers. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E ISO 9001:2015 Clause 10.2.2 - Evidence of all nonconformities and actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
qualprod Only manufacturing, non applicable - ISO 9001 Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
MichaelDRoach ISO 9001:2015 Clause 9.3.2c)3) - What process or processes is this focused on? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Clause 8.5.5 and Clause 8.6: which one should be coming first? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
GStough ISO 9001:2015 Clause 8.4.2 - Who Is The "Its" in (a)..The Supplier or Their Supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Which ISO 9001 Clause applies to "Procedures are outdated"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to comply with ISO 9001:2015 Clause 7.4 Communication ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J ISO 9001:2015 Cl. 8.1 - 'and to implement the actions determined in clause 6' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Referencing ISO 9001:2015 clause for Audit General Auditing Discussions 10
P Design and Development Clause ISO 9001:2015 Exclusion for Medical Services Design and Development of Products and Processes 3
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
K ISO 9001:2015 Clause 5.1.2 Customer Focus (a) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Values - ISO 9001 2015 - Clause 4.1 Note 3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A How to 3rd Party Audit ISO 9001 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M What do you do for ISO 9001 clause 9.1? Key Performance Indicators ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001:2015 - Clause for Correction of a QMS Nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A How to approach ISO 9001:2015 Clause 7.1.6 when 3rd Party Auditing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K What can be considered a "Post Delivery Activity" (ISO 9001:2015 Clause 8.5) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
A ISO 9001:2015 Clause 7.1.1.b refers to ....? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S What do I have to do for ISO 9001:2015 Clause 6.2 - Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S What do I have to do for ISO 9001:2015 Clause 4.1 and 4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Clause 7.5.2 - Is Review and Approval applicable to Records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
B Clarification of ISO 9001:2015 Clause 8.5.6 Control of Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S ISO 9001:2015 Clause 8.2.1 e) - Requirements for Contingency Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Application of ISO 9001:2015 Clause Interpretations for Service Industries Service Industry Specific Topics 2
