ISO 9001 Clause advice Needed
Jared
Hello All,
I have just completed an internal audit where I was shown an incident report which documents details around a broken SLA. Included in this was description of incident, root cause, impact to client and what future prevention measures have since been implemented.
My question is this, is it correct to note in my report that clause 10.3 Continual Improvement has been met due to the prevention action implemented? Is there a more suitable clause I should use instead?
Jared
John C. Abnet
Teacher, sensei, kennari
Hello All,
Jared
Good day @Jared ;
By SLA you mean "service level agreement" ?......
Keep in mind that 10.3 describes continual improvement. I assume the "SLA" was prescribed to be a certain way, and it was not so. Simply "fixing" it (i.e. corrective action/root cause analysis) is getting it to how it was intended in the first place. That is not continual improvement.
Continual improvement (e..g) may be something like....the OTD was running at 98% of (better than the original goal 95%). A team gets involved to see if the goal (and results) can be pushed to 99%. For example.
Hope this helps.
Be well.
Jen Kirley
Quality and Auditing Expert
Hi Jared,
What is an SLA?
What is an incident report used for - some kind of violation? If it is, it is a nonconformity and would be addressed as a Corrective Action. ISO/TS 9002:2016 describes its activities as, in part:
... several methodologies and tools that the organization can consider to conduct continual improvement activities (kaizen). Examples can include, but are not limited to: Six Sigma methodologies; “lean” initiatives; benchmarking and the use of self-assessment models.
in order to
...enhance the organization’s performance and benefit its customers and relevant interested parties.
...using results from analysis and evaluation and management review to determine if continual improvement actions are needed.
Can I ask what value you and other derive in assigning a clause number to this internal audit finding? What are you expecting to gain from this?
Sidney Vianna
Post Responsibly
Absolutely not. What you are referring to as preventive action, is, indeed corrective action since there was an incident in service delivery. Bringing the service to the level was agreed upon is OBVIOUSLY NOT an instance of continuous improvement, just like fixing a flat tire in your car is not continuous improvement either.
Hello All,
Jared
I think you have your terms mixed up. Preventive action is no longer a term used in the 2015 version of the standard. What you do to prevent something from happening again is part of the corrective action as noted by Sidney.
At most it could be used as evidence as an example of 10.2 Corrective Action is doing well.
Preventive Action was a term used in past versions of the standard. For the 2015 version it was replaced with risk. The need for the change is that preventive action did not live up to its mission as it was misunderstood, and the writers of the standard took responsibility for it. Since corrective action and preventive action were together at the back of the standard and written in nearly parallel language it was easy to tangle them. To resolve it, preventive action was given a new name (risk and opportunity) and move closer to the front of the standard.
It may help to think of corrective action as incident control. That is what you do after something happens to control and contain it. Preventive action was intended to handle what you do to keep a potential problem from happening, which, pure and simple, is risk.
How to attain continual improvement is actually contained in the standard. It is the results of analysis and evaluation and the outputs from management review.
It sounds like you may be using an element based checklist for your internal audit. Although it is not prohibited, it is discouraged with the preference of auditing using the process approach. That is determining how the company is structured and then auditing the elements of the structure instead of the elements of the standard. Perhaps you are doing a process based audit and referring the the elements that apply to it, which is fine.
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
K ISO 9001 Clause 8.3 & 8.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO 9001 Clause 8.3 Design for an education services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Determining if Maintenance Contractor is an External Service subject to ISO 9001 Clause 8.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
S ISO 9001:2015 Clause 9.3.2 - MR (Management Review) - Adequacy of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001:2015 Clause 8.7 Control of Nonconforming Outputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D ISO 9001:2015 Clause 8.4.3 "Information for External Providers" buying from online retailers. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E ISO 9001:2015 Clause 10.2.2 - Evidence of all nonconformities and actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
qualprod Only manufacturing, non applicable - ISO 9001 Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
MichaelDRoach ISO 9001:2015 Clause 9.3.2c)3) - What process or processes is this focused on? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Clause 8.5.5 and Clause 8.6: which one should be coming first? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
GStough ISO 9001:2015 Clause 8.4.2 - Who Is The "Its" in (a)..The Supplier or Their Supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Which ISO 9001 Clause applies to "Procedures are outdated"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to comply with ISO 9001:2015 Clause 7.4 Communication ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
J ISO 9001:2015 Cl. 8.1 - 'and to implement the actions determined in clause 6' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Referencing ISO 9001:2015 clause for Audit General Auditing Discussions 10
P Design and Development Clause ISO 9001:2015 Exclusion for Medical Services Design and Development of Products and Processes 3
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
K ISO 9001:2015 Clause 5.1.2 Customer Focus (a) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Values - ISO 9001 2015 - Clause 4.1 Note 3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
armani How to 3rd Party Audit ISO 9001 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M What do you do for ISO 9001 clause 9.1? Key Performance Indicators ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001:2015 - Clause for Correction of a QMS Nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
armani How to approach ISO 9001:2015 Clause 7.1.6 when 3rd Party Auditing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K What can be considered a "Post Delivery Activity" (ISO 9001:2015 Clause 8.5) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
armani ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
armani ISO 9001:2015 Clause 7.1.1.b refers to ....? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S What do I have to do for ISO 9001:2015 Clause 6.2 - Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S What do I have to do for ISO 9001:2015 Clause 4.1 and 4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Clause 7.5.2 - Is Review and Approval applicable to Records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
