ISO 9001 Clauses - Using only 23 of 62 Clauses
Marc
#11
Yup - The requirements of each clause can be in separate documents and they do not have to reference the clause, either. They don't have to be in the quality manual. But... Most companies have, at the least, a matrix which points to the document(s) which fulfill each applicable clause of the standard so it's very clear each of the clauses is addressed in their quality system. Back in the 1990's it was sort of expected that the quality manual had to address every clause in the standard. These days a quality manual can consist of little more than a high level flow chart.
TPMB4
#12
An old thread but I thought I would bring this up as I have seen a few threads and sample manuals that basically mirror the ISO9001:2008 standard.
I'm planning to totally update our manual as it is highly dated in look and even substance even if it does allow us to be certified and pass our 3rd party audits. Being new to the Quality representative role I've obviously looked around for ideas and there seems to be a lot who just regurgitate the standard. I've seen countless examples that in the first three sections even show the PDCA diagrams. Why?
That is why I see those 2 page manuals and think something closer to that end is better than creating an ISO 9001 standard clone.
Please correct me if I'm wrong but the whole QMS manual is about documenting what YOU do and whilst reference to particular clausesmight be useful to those who don't know them the auditor should be able to work out what clause a particular section or procedure is about.
Sorry if I sound a but angry but as someone who is really working from a low knowledge level I took some time to realize that these regurgitations are not needed. I have wasted a lot of time already trying to produce my own version of this.
Of course if I am wrong about this please correct me. I am willing and very keen to know. Correction of my mistake or misunderstanding (if that is what this is) would be a valued service to me.
Unless someone convinces me that I am wrong I will chart the processes in the company I work in and produce something from that. Basically document the processes that all work well and tidy up those that don't. Think I prefer the KISS approach but not quite down to 2 pages...yet!
BTW I already know our 3rd party auditor is supposed to be keen on simple systems where possible after he was told we were re-writing our manual and procedures. So provided I don't miss anything a simple manual should put us in good stead. Might actually be read by people other than the directors and me!!
#13
I agree with you completely. There's a lot of discussion here in the Cove on the subject. For example, have a look at Boss Wants a 4 Page Manual for starters.
somashekar
#14
Yes, you have to map what you do with the standard, and then find gaps if any and bridge them, and not the other way round, mapping standard to what you do.
Apart from keeping what the standard requires in your quality manual, you can add more if that makes any use to you. It is certainly not about 2 page or 20 page manual.
TPMB4
#15
Thanks for that. I did wonder if I was a bit mad. To me I could not see why things need to be that complicated. You have a company, it's not a big, multi-site corporation, it has procedures that are robust and well maintained. As a company it works so why make it bigger than it is.
I reckon I will write something out based on less than a page for policy, objectives and the scope (we don't design nor service so that is excluded). Then we have a small handful of processes that could be simply written up. Think I will try for less than 10 pages with the content spread out only for ease of reading. Although I will not dictate a page number before it is written.
Just one question for procedures. Are flowcharts or written procedures best these days? I mean do flowcharts look old hat for procedures? I've seen written ones with inputs/outputs, entry/exit criteria, etc. What is best?
#16
What's best is what accomplishes the mission with the least amount of trouble. Less is more, in most cases. Flowcharts are fine so long as they convey the requirements clearly.
TPMB4
#17
But the manual does not have to look like the standard or even refer to it. i have the idea that the manual is a record of what you do. The 3rd party auditor knows what the standard requires and must be able to recognize what your process/procedure covers in the standard's clauses / requirements. He/she assesses the manual and system to determine if it is capable of covering those clauses or requirements then he/she audits the company to see that they actually do what is recorded in the manual.
In my mind the manual does not have to refer to the standard at any point. It just has to meet the requirementsto enable the auditor to certify (if you do what you say that is and that is another matter competely).
From my view I intend to do less than 10 pages if I can and still have not decided whether for internal use to actually quote the clauses for each process/procedure. I suspect I will since I have generated audit checklists based on the clauses so should reference them somewhere in the manual, perhaps in a flowchart of the processes. I won't create sections 4, 4.1, 4.2, 4.2.1, 4.2.2, etc. and write in what we do for those clauses.
I will at least find it interesting come next 3rd party audit as it is the 3 yearly re-certification one.
Randy Lefferts
#18
What you put in the quality manual is up to you as long as it meets :
4.2.2 Quality manual
The organization shall establish and maintain a quality manual that includes
a) the scope of the quality management system, including details of and justification for any exclusions (see 1.2),
b) the documented procedures established for the quality management system, or reference to them, and
c) a description of the interaction between the processes of the quality management system.
I created a 2 page quality manual after seeing an example in this thread. Post #9, by DrM2u, contains an example.
Rickser
#19
One of the "catch phrases" I use when working with processes, procedures and quality manuals is: "Say what you do, do it, and document that you did it". That has worked well for me, especially when getting employees to write processes. Clauses and the number of clauses do not matter as long as you meet the requirements of the ISO standard. You can combine requirements into one process. You can spread requirements out over more than one process (though I can't figure out why anyone would).
F Logistics and IT clauses in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
E ISO 9001:2015 - Internal Audit Plan Clauses General Auditing Discussions 8
P Quality Assurance and Quality Control - Which clauses of ISO 9001 deal with each? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
1 Applicable ISO 9001:2015 Clauses for Remote Site(s) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Difference between ISO 9001:2015 Clauses 8.1 and 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Use of information from ISO 9001 Clauses 4.1 and 4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 clauses and clause details in Excel format Document Control Systems, Procedures, Forms and Templates 11
A Action to demonstrate compliance with on clauses 4.1, 4.2 and 6.1 of ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q ISO 9001 Certified but not complying with ISO clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Differences between Clauses 7.5, 8.2.3 and 8.2.4 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001 Clauses which reference the 8 Principles of Quality Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Requirements for Product Related Emails - ISO 9001 Clauses 7.3.4 and 4.2.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Marc ISO 9001:2015 Structure - Top Level Clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
K How to apply ISO 9001 clauses 7.3.2 to 7.3.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A ISO 9001 Clauses 7.5.1 and 7.5.2 - Exclusion for Design Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001 Clauses 7.5.1 vs 7.3 for Services Service Industry Specific Topics 5
K Exemption from Section 7 clauses of ISO 9001 - Scientific Research Company Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Q Quick Guide - Processes vs. ISO 9001 Clauses? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A ISO 9001 and ISO 17020 Clauses Correspondance (Cross Reference Matrix) Other ISO and International Standards and European Regulations 4
J Requirements for Records in ISO 9001 Clauses 4.2.4 and 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P ISO Clauses and Processes Flowcharts - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M What is the intent of ISO 9001 Clauses 8.2.4 & 7.1 d? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Corrective and Preventive Actions - ISO 9001 Clauses 8.5.2 & 8.5.3 Preventive Action and Continuous Improvement 39
A Comparison Table for ISO 9001 & ISO/IEC 17020 Clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Improvement in ISO 9001 Clauses 5.5.2 b) and 5.6.2 g) - Are they the same or related? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M One audit finding - deviated from 2 clauses of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Managing Hotel Services and Selling Travel Tickets - Excluded ISO 9001 Clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
I Design and Development vs. Production - ISO 9001 Clauses 7.3 vs. 7.5.1 Design and Development of Products and Processes 8
J How do you audit or interpret 'Where Appropriate' in ISO 9001 Clauses such as 7.4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Interpreting ISO 9001 Clauses 4.1.a to 4.1.c - What are these Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Z ISO 9001 Clauses which should be known by every one in the organization? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S Who can confirm the 21 mandatory records (clauses) as required by ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Nonconformities against General clauses in ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Understanding the clauses of ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Matching ISO 9001 Clauses/Requirements to my processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Control Plans and ISO 9001 Clauses 7.4.3 vs 8.2.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
W Interpretation of ISO 9001 clauses issued by TC 176 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D ISO 9001 tree - Diagram showing the inter-relation of all the ISO clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C ISO 9001:2000 Clauses 7.4.3 & 8.2.4 - Incoming inspection records - need your input Inspection, Prints (Drawings), Testing, Sampling and Related Topics 30
I Audit Matrix - ISO 9001 clauses and some of the sub clauses General Auditing Discussions 6
N Seeking: The ISO 9001 Clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Why internally audit ISO clauses for ISO 9001:2000? (Small company) General Auditing Discussions 16
A Corrective Action and Preventive Action clauses - ISO 9001 - Corrective Action Nonconformance and Corrective Action 6
S Quality Procedures for ISO 9001:2000 - 5 clauses, with 22 processes and 6 procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N How Can I Remember the ISO 9001 Clauses? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
