ISO 9001 Containment Requirements
LUV-d-4UM
#11
The auditors usually require "Containment" when we respond to findings even if the findings are normal such as non-conformance to a work instruction. Do we have to do "Containment" in response to a finding in ISO9001 external audit?
randomname
#12
Correction includes both containment and remedial action. And yes, it also applies to audit NCS. Can't write a proper problem definition until correction has been done, since full magnitude is not likely to be known (e.g. Was it an outlier or did it represent a larger, more systemic problem?). If the former perhaps CA isn't necessary (depending on risk), but if systemic CA likely makes sense.
Big Jim
#13
It seems as though different CBs have slightly different rules and definitions. I would check with your CB to understand what they actually want.
In my perspective, correction includes containment and something related called extent of the issue. Even if your CB doesn't require it, I would recommend you do. You will have a healthier QMS if you do.
LUV-d-4UM
#14
Thank you Big Jim. We are addressing "Containment" for external audit corrective actions. I think the auditor is in compliance with the ISO standard for auditing. I appreciate everybody'd feedback.:applause::agree:
howste
Thaumaturge
#15
Here's the ISO definition of correction:
ISO 9000:2015 said:
correction
action to eliminate a detected nonconformity
Note 1 to entry: A correction can be made in advance of, in conjunction with or after a corrective action.
Note 2 to entry: A correction can be, for example, rework or regrade.
I'm not sure where people are coming up with the idea that correction includes containment. If anything, I would say that containment of a nonconformity is more likely include correction. Unfortunately containment is not defined in any ISO document that I'm aware of.
Generally all of these terms are used in the context of corrective action for a nonconformity. Correction eliminates the nonconformity, while corrective action eliminates the cause of the nonconformity and prevents recurrence. Containment is something that we do to keep the effects of the nonconformity that already exists from causing further problems internally and with our customers.
Any way you look at it, containment is a good idea and should be considered along with each nonconformity encountered.
Big Jim
#16
I have seen containment as part of the correction portion of nonconformances from CB auditors using the CB's form.
ANAB Heads Up 137 provides a bit more detail and may help to see where it came from. This ANAB publication is directed to CBs and how they answer nonconformances written against them by ANAB, but the principles are much the same, and it was passed on to auditors as an example by many CBs. Here is the pertinent portion:
Correction – in order to be fully accepted, the response must include the following components:
1. The extent of the nonconformity has been determined and contained
a. The nonconformity has been corrected and the response is written in the past tense. (E.g.
the missing record was found (not will be found)).
b. The CB has examined the system to see if there are other examples that need corrected
(extent of the issue) and have also addressed the extent in their response.
c. Including the evidence ANAB found and any other evidence the CB may have found.
howste
Thaumaturge
#17
In that Heads Up ANAB only uses the terms correction (not containment) and corrective action, but requires the CB to look for other instances of nonconformity that must also be corrected. You could imply that looking for other NCs is part of containment. ISO 17021 also only uses the terms correction and corrective action.
LUV-d-4UM
#18
Thank you. As Big Jim said containment is good for my quality system. I am given enough chance to better my system and I give credit to my CB auditors.
Big Jim
#19
Heads up 137 comes very close to saying containment. As noted in the prior post:
" The extent of the nonconformity has been determined and contained"
The word containment has been bantered about within some CB for at least ten years. It is also used in some of the CB nonconformance forms.
I'm explaining what I have seen. If it of value, take advantage of it. If you see no value to using the concept, then don't use it unless it is on your CB's form.
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G National Structural Steel Specification 7th Edition - Do I now have to be audited against ISO 3843-3 as well as ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Sister-company providing parts is only ISO 9001 registered IATF 16949 - Automotive Quality Systems Standard 7
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G Logistic organization and controls - IATF/ISO 9001 audit Nonconformance and Corrective Action 2
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
