ISO 9001 - Design Validation Record exemption
Tyler C
Quality Pros
I have been looking through the records required by ISO 9001:2008 and one of them is Design Validation records.
My company does do design, but we design to customer requirements. We have stated it is not our responsibility to perform design validation as that is the customer's responsibility because we are a custom shop.
Since I didn't ask for an exemption on this, will it be a finding that we don't have design validation records?
Coury Ferguson
Moderator here to help
Quality Pros
In my opinion, if you didn't asked for the exemption you will be required to show records.
Question: Do you build to the design and submit to your customer, or does your customer(s) build to your design?
howste
Thaumaturge
Read the whole text of that requirement and see if the answer is there:
ISO 9001:2008 said:
Design and development validation shall be performed in accordance with planned arrangements to ensure that the resulting product is capable of meeting the requirements for the specified application or intended use, where known.
Do you know how the product will be used? If yes, you should validate that it will work for that application. If not, you already have an "exclusion" built into the standard.
By the way, you should also look at what you're allowed to exclude:
ISO 9001:2008 said:
Where exclusions are made, claims of conformity to this International Standard are not acceptable unless these exclusions are limited to requirements within Clause 7, and such exclusions do not affect the organization's ability, or responsibility, to provide product that meets customer and applicable statutory and regulatory requirements.
The short story is if you design product and you know how it's used, you have to validate. You'd have a really tough time justifying an exclusion. My take is that if you design product and you don't validate it, and it doesn't meet requirements, then you're still on the hook. If it can only be validated in a higher assembly by the customer, then you should specify that in your agreement with them.
Tyler C
Coury - to answer your question, sometimes the customer sends us a design specification sheet and we then create internal design sheets to be used in production. Other times, the customer simply tells us what they need (for example, we make heaters, and they may say they need a 5"x6" heater at 120 volts and 200 watts with 24" power leads) and we draw up a design specification sheet and send to them, they say yes or no, and we go from there.
Ninja
Looking for Reality
If it is documented anywhere (including a PO terms or order acceptance terms or simply in your design control procedures) that the customer approval on design IS the verification...then your record of "Yes" or "No" is your design verification.
If the customer supplied it...there's your design verification right there.
Depending on how you and your customer relate, you can also push first use at the customer to stand for design validation. The record of validation being the second order, or simply an email from them saying "Hey, it works nicely".
Those steps of verification and validation are there to make sure you are not just slapping stuff together and making promises. You seem to be working back and forth with your customer and sharing the design and validation steps back and forth...don't be afraid to simply call it that. It is a fully valid approach (mostly 'cause it works well).
normzone
I don't see any easy out from this, but you may already be doing this.
First I'll take liberties with your post, by removing some words.
" the customer sends us a design specification sheet and we then .... design .... Other times, the customer simply tells us what they need (for example, we make heaters, and they may say they need a 5"x6" heater at 120 volts and 200 watts with 24" power leads) and we ... design ... and send to them, they say yes or no, and we go from there.
So viewing verification as making sure you built what the customer wanted, and validation as making sure that it does what they wanted it to do, do you test the completed units you build for them?
Seems to me the test records would be validation records.
Tyler C
Howste - the standard is somewhat confusing to me, maybe I'm just having an off day, but here's an example. As I said above, we make application heaters. So, a customer calls and they need a heater to warm a table to keep a dog at the right temperature while they operate. So, we know the application.
How do we validate this application, simply show that the heater will get to the specified temperature they need? Or, do we have to build a table, apply a heater to it, perform surgery on a dog and see whether or not the dog was kept at the right temperature the whole time?
This is what I'm struggling with. Because we have thousands and thousands of customers, all with different applications, we can't re-create every single customer's application that we know to validate that the heater will meet the application requirements.
If they tell us the heater needs to maintain the table to 98.6 degrees F, we can validate this in house very easily.
If they tell us it needs to maintain the normal body temperature of a dog while under anesthesia for 6 hours continuously in a room that maintains 71 degrees F with a 50% humidity, we cannot validate this for several reasons. If this were to happen, we would tell them we need specific temperatures to work with but we would now know exactly how the heater is going to be used, are we still expected to validate all of these requirements?
Tyler C
Thank you Ninja. It works very well and I think this is the approach I am going to take.
Tyler C
Thank you Normzone. We do perform 100% testing at final inspection when the product is complete. I do at times struggle with verification vs validation because it seems to be the same to me. I understand the difference in your definitions, but it seems building what the customer wants is the same as ensuring it does what the customer wanted it to do. The customer wants something that will do what they want it to do... But, I was considering the inspection records as verification records, not validation records. Maybe I am looking at it wrong.
Ninja
Looking for Reality
FWIW...you'll likely have to walk your CB auditor through it the first time...we had to.
There are so many applications where in-house validation is a total must, that many are used to it from everybody.
In cases like yours where such a thing just doesn't make sense...you may have to help them get out of the rut and think about it without bias or preconception.
Sidney Vianna ISO 9001 News ISO 9001 Design Specification to be developed - May 2022 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
A Design process goal for ISO 9001 Manufacturing and Related Processes 23
S ISO 9001 Clause 8.3 Design for an education services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 & ISO 14001:2015 - I need a format for Design & Development planning ISO 14001:2015 Specific Discussions 2
armani ISO 9001:2015 - How to apply 7.1.5 to an organization performing only design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Development separated from design? ISO 9001 cl. 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K ISO 9001 2015 Exclusions - Product Design is purchased. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C ISO 9001 2015 Documentation for Engineering and Design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P Design and Development Clause ISO 9001:2015 Exclusion for Medical Services Design and Development of Products and Processes 3
G ISO 9001:2015 8.3 Design and Development (in Civil Engineering) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Y ISO 9001 Cl. 8.3 - Design and Development of Products and Services not applicable ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J ISO 9001:2015 8.3.2 f) - Interfaces between Persons in Design & Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 - 8.3 Design and Development of Products and Services (Repair Company) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Question about ISO 9001:2015 8.5.3 - Design and Development of Products and Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
4 Adding a new Company - ISO 9001 Design Exclusion Design and Development of Products and Processes 1
C Optic Patchcord Cables - Does 8.3 (Design) Apply Here? ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R Understanding a few points on ISO 9001's Design and Development Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C ISO 9001:2015 - Non Applicable Design and Development (Power Plant Operator) Design and Development of Products and Processes 2
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
L Auditing Design and Development in ISO 9001 (Internal Audit) Internal Auditing 1
M "Partial Design" Designation and Applicable ISO 9001:2015 Exemptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q ISO 9001:2015 - Design of Process vs. Design of Service Service Industry Specific Topics 4
G ISO 9001:2015 8.3 Design and development of products and services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 9001:2015 - Clause 8.3 - Design in the Custom Manufacturing industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N Dual ISO 9001 (Manufacturing) and ISO 13485 (Design Control) for same product line ISO 13485:2016 - Medical Device Quality Management Systems 3
I ISO 9001 Scope - Exclusion of Design in an engineered solutions company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D ISO 9001 Design Process Flow Chart ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K ISO 9001 Section 7.3 Design and Development Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
H ISO 9001 Document Control Requirements - Design and Development Department Checklists Document Control Systems, Procedures, Forms and Templates 3
A Quality Manual Statements - ISO 9001:2008 Design and Development Exclusions Design and Development of Products and Processes 6
D Consultancy company - ISO 9001 Implementation and Design Exclusion ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
smryan Satisfying the ISO 9001:2008 7.3.5 Design & Development Verification requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I Interior Design Company Design Procedure Example wanted (ISO 9001:2008) Design and Development of Products and Processes 3
E ISO 9001 vs ISO 13485 or both? A QMS for a Design and Development Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Y Clarification on ISO 9001 - Exclusion of Design and Development, Clause 7.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
armani ISO 9001 Clauses 7.5.1 and 7.5.2 - Exclusion for Design Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C How to do a procedure for ISO 9001 2008 7.3 Design and Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Design & Development in Updating Machines and Equipment - ISO 9001 Help Design and Development of Products and Processes 4
L ISO 9001 Clause 7.3.2 Design & Development Input - Adequacy, Complete, Unambiguous ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Does the Layout Design of a PCB fall under clause 7.3 in ISO 9001 Design and Development of Products and Processes 7
B Design and Development Exclusion - ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D ISO 9001 Clause 7.3 - Design & Development - Requirements help wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M ISO 9001 Certified Education Company - Defining the Product & Design and Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Advisory Services - Design and Development requirements per clause 7.3 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Question about Design Exclusions - Clause 7.3 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W ISO 9001:2008 Clause 7.3 Design and Development Exclusions Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
