ISO 9001 - Documentation Control - Letters / Letter Templates
stephenh
Hi all,
I have a query regarding the control of letters.
We have a certain procedure flowchart which requires various letters sent at certain points.
I have put the file name of the letters under 'documentation' on the front page of the flowchart. As far as i'm aware they do not need a reference code or logging in the document register. It would sureyl be too much effort to control every single letter we send out in the company?
Any advice would be appreciated, T-minus 11 days to audit!
Stephen
Paul Simpson
Hi all,
Stephen
Is it important that letters are all sent the same?
If your letters all have standard text in them then you might decide they need control. The level of control is up to you. Some organizations use templates that are all document controlled and protected so bits can't be taken out of them (but with fields where bits can be added).
Don't forget the standard letter or template would be controlled as a document (form) and the completed letter would be controlled as a record.
The level and type of control is up to you.
stephenh
Thanks Paul,
The letters are generated from a database. Would this cover the requirement for keeping records? can search by dates/status etc.
As for controlling letters, I'm not going to for the time being, I think I will reference them under templates in the Document Register and keep an electronic copy in the ISO > Department file. It's a department I know very little about and as long as they have a method for controlling them then thats fine by me.
Paul Simpson
OK. The record then is the entry in the database (unless the person putting together the database can "add" to the text in which case the letter is the record (as they may have committed the company to additional requirements.
Looks fine to me.
P
pzaltz
Hi Stephenh,
In my humble opinion, as long as the records are the proof that your procedure was followed, you don´t need to keep a copy of the letter. Otherwise, you'll need to store "copy" every item produced using your quality management system in order to show compliance with the procedures, and you don´t ¿right? ;)
Just make sure that your procedure: a) points to a letter template to follow; and b) The record for demonstrate compliance is your database field "sent letter date".
Good Luck for the audit!!
BRegards,
Pablo
A Process Documentation for ISO 9001:2015 Internal Auditing 2
L ISO 9001:2015 standard documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C ISO 9001 2015 Documentation for Engineering and Design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Changing Terminology in ISO 9001:2015 - Documentation Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Any recommendations on canned ISO 9001 documentation? Document Control Systems, Procedures, Forms and Templates 3
C Google Apps vs. Wiki for ISO 9001 documentation Document Control Systems, Procedures, Forms and Templates 30
A Query about ISO 9001 Certification Documentation for a Service company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K ISO 9001 - Standard Documentation Template required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
I ISO 9001:2008 4.2 Documentation - Where to put a Procedure Quality Manager and Management Related Issues 7
M Software recommendations for ISO 9001 Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D ISO 9001 documentation requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Documentation for ISO 9001:2008 - 6. Resource Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001 and ISO 13485 GDP (Good Documentation Practices) Findings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L ISO 9001 QMS Documentation Style/Model Document Control Systems, Procedures, Forms and Templates 5
T Safety & Health Documentation Responsibilities and Requirements (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q ISO 9001:2008 Documentation Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C Documentation Update to ISO 9001:2008 (My first post) Document Control Systems, Procedures, Forms and Templates 8
D Documentation used to satisfy ISO 9001:2008 Clause 7.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A ISO 9001 Documentation Formats - Issue date for first issue ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B ISO 9001 Documentation and PCF (APQC's Process Classification Framework) Document Control Systems, Procedures, Forms and Templates 21
S ISO 9001 Implementation - Quality Manual is Dreary! Documentation Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
H ISO 9001 Documentation Templates ('Canned' packages) advice Document Control Systems, Procedures, Forms and Templates 4
T Level of Documentation and Records required for ISO 9001 in a Small Business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
I ISO 9001:2000 - is Spanish translation of documentation required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
J Engineering Department Documentation Requirements - ISO 9001 Clause 7.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
I ISO 13485:2003 documentation vs. ISO 9001:2000 documentation - Differences ISO 13485:2016 - Medical Device Quality Management Systems 4
J What are the basics of ISO 9001 documentation? Document Control Systems, Procedures, Forms and Templates 6
U Documentation Reduction - Over Documented ISO 9001:2000 QMS Document Control Systems, Procedures, Forms and Templates 23
R Documentation and Records Requirements for ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Documentation required for AS9003 registration - More than for ISO 9001? Various Other Specifications, Standards, and related Requirements 3
G Good ISO 9001:2000 documentation and record management software Quality Assurance and Compliance Software Tools and Solutions 8
Claes Gefvenberg ISO 9001: Avoiding Over Documentation Document Control Systems, Procedures, Forms and Templates 26
Raffy Documentation of ISO 9001:2000 especially on the six procedures Document Control Systems, Procedures, Forms and Templates 6
Raffy ISO 9001:2000 Documentation - Necessary to "paraphrase the standards" in procedures? Document Control Systems, Procedures, Forms and Templates 2
E New Standard's Name - Referring to ISO 9001 in our documentation Document Control Systems, Procedures, Forms and Templates 5
A What is the relation between SAP and ISO 9001:2000 documentation requirements? Quality Assurance and Compliance Software Tools and Solutions 3
J IDEF0 / IDEF3 as ISO 9001:2000 documentation? Implementation of IDEF0 or IDEF3 Document Control Systems, Procedures, Forms and Templates 3
Marc ISO 9001:2000 Documentation Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G Structure in ISO 9001 documentation - Level 1, Level 2, Level 3, Level4, etc. Document Control Systems, Procedures, Forms and Templates 7
J Tracking ISO 9001 documentation - Seeking software recommendations Quality Assurance and Compliance Software Tools and Solutions 3
Marc Upgrading to ISO 9001:2000 - Changing Documentation Document Control Systems, Procedures, Forms and Templates 4
B ISO 9001 Documentation Control Document Control Systems, Procedures, Forms and Templates 13
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 2
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
