ISO 9001 Documents for Submission to the Registrar
#31
Jim- these are not questions for you to respond to, since (as you stated) you do not represent a CB, but purely for the help of our readers who may be presented with a similar situation.
Surely, the point of a Stage 1 is as a readiness review? As ANAB found out, (the hard way) readiness CANNOT be assessed from simply looking at documents in isolation of being in the clients organization! Indeed, ISO/TS has required a staged approach for this exact reason.
What's more, if an output of the stage1 is a plan for the stage 2, how is the client to prepare for something prepared only the day before? If issues are found which cannot be corrected in the time allocated, how does this help the client if they were led to believe that a stage 1 could be followed immediately by the stage 2?
The most effective approach for any client is to have the auditor there, for 8 hours, to ensure it is they who do the work the client is paying for and to get the fullest benefit from that work, which is really what the stage 1 is for!
silentrunning
#32
Since it is easy to pull a good Quality Policy Manual and excellent procedures off the Post Attachments here on the Cove, I see little to be gained in reviewing just the paperwork. Besides, many if not most newbies to ISO 9001 merely regurgitate the standard anyway.
#33
Agreed, Doug!
Effective audit planning - when the client is paying for it - should be done in collaboration with them! This means going through documents together, not just to see they exist, but that they can "walk through" them, with the auditor! This displays a sense of ownership which is part of the background to the readiness.
Time spent with the client is also very valuable in building relationships. Since a CB is unlike any other supplier, the better each party understands each other, the better the relationship - and "value" for the audits - is likely to be perceived. As we all know, we get emails from people, posts in forums etc which can be taken many different ways from what was intended. So, to Doug's point, just looking at a bunch of documents might not give you a good idea of the client and they of the auditor (if that's who actually does it)
Despite what 17021 actually says, effective, customer oriented CBs do as much of their service as possible, by including their client in that work. It builds trust, partnership and effective systems.
Big Jim
#34
Big Jim, while I appreciate that you are not "defending the method", there is only 1 reason for this practice of (what the ANAB Heads Up document refer to as) back-to-back stage 1 and 2 audits: be cheaper save costs. By minimizing the travel/mobilization expenses for a stage 1 audit.
In my mind, the practice is just another example of a CB becoming "creative" to circumvent the intent of a well timed stage 1 audit, which, ideally should happen months before the stage 2 audit. It just goes to show that, it does not matter how generic standards are written, some people will always try to find loopholes to gain a commercial advantage.
I don't agree. I don't view it as a back to back audit. All except for the determination that the scope statement matches the site has been fulfilled. Hardly a reason to attempt to nullify the whole thing or attempt to say nothing was done until that very small part is fulfilled by the site visit.
Big Jim
#35
I don't know if they do off site Stage 1 audits for TS 16949 or AS9100. I suspect they do not.
The Stage 2 audit plan is completed as part of the off site Stage 1.
I never said anything about 8 hours. That is your assumption. All of the off site Stage 1 audits I have done were 4 hours. All were small companies. I don't see a need for 8 hours for that activity, and traveling on site AND charging for 8 hours, as you suggest could be considered as an abuse of the client.
Big Jim
#36
Agreed, Doug!
It is a mistake to assume that you cannot build that same sort of relationship from a properly handled off site audit. I have returned to some of those that started as off site Stage 1 clients and continue to have a good relationship that started with that Stage 1 off site audit. I guess that may depend on the personality of the auditor, but that would be true if the first contact was on site as well.
Big Jim
#37
So I'm guessing that you think that all that is reviewed off site is the quality manual. That is very shortsighted.
You can tell a great deal from looking over the management review records, the internal audit records, and the quality objective results. From how the records have been developed and maintained an auditor can gain a lot if insight about the company.
The purpose of Stage 1 is to determine if it appears that there is a quality management system in place that is ready for Stage 2. That takes more than looking over the quality manual. Evidence of results are needed.
Big Jim
#38
For the benefit of the people not familiar with ISO 17021:2011, the following comes from that standard, as it relates to the stage 1 audit:
As for the expected time gap between Stage 1 and stage 2 audits, ANAB has released a Heads Up document, which reads:
I don't see how any of that is violated from the off site Stage 1 audits I have performed. There is time between the off site Stage 1 and the on site Stage 1 / Stage 2 for the issues raised from the off site to be resolved. I don't view that as a "back to back" audit, and if it were considered as one, what you posted doesn't prohibit it.
#39
It's OK, Jim. I have all the information I need, thanks. Since you are not a CB representative, it's OK not to justify or defend what happens with the registrations you take part in. Thanks for clearly describing your process and understanding of the stage 1 and 2 audit process.
Sidney Vianna
Post Responsibly
#40
Now I am confused. What do you mean by stage 1 audits that you perform? Are you an auditor? You had said before
I do not represent the CB.
As for the stage1/stage 2 bundled activities, in my mind, it clearly goes against the intent of 17021. There is an obvious reason for the standard to state that the certification audit MUST/SHALL be split into Stage 1 and Stage 2. If you bundle the 2 stages together, you are clearly violating both the text and the intent of 17021. And, exactly because of people becoming too creative, ANAB had to clarify the issue with the Heads Up document.
Until people understand that CB's are should be in the confidence building business and not in the lobby wall adorning business, we wont have done a good job of educating our interested parties.
qualprod To set frequency to review documents in ISO 9001 7.5? Document Control Systems, Procedures, Forms and Templates 13
I Sales Documents in scope for ISO-9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V ISO 9001 Detailed documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Customer Specific Documents and Records - ISO 9001 Control Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C ISO 9001:2008 4.2.3(f) - Controlling Documents of External Origin Quality Manager and Management Related Issues 9
K ISO 9001:2008 Logo on objects/documents/brochures/logos where we advertise ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
H Is "Master Documents and Records list" required per ISO 9001 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
drgnrider Informational Required Documents/Records in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 65
F ISO 9001:2008 Fundamentals: Basic Questions - Controlled Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
O Documents & Records as per ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N What Documents are Required for each ISO 9001 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Rookie to the ISO 9001:2008 World - Required Procedures and Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P Where do training documents fit into the ISO 9001 categories? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F Paperless Procedures - Does ISO 9001 Require Paper Documents? Quality Manager and Management Related Issues 37
L Does ISO 9001 require that hard copies of documents be archived? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Control of Safety Documents Required? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Lean ISO 9001 - Lean Documents, use of Gemba, Inspection Methods, etc. Lean in Manufacturing and Service Industries 9
E Control of Documents - ISO 9001 Requirements Document Control Systems, Procedures, Forms and Templates 3
L ISO 9001:2008 - Control of Documents of External Origin Document Control Systems, Procedures, Forms and Templates 13
J ISO 9001:2008 Clause 4.2.3 - What are the required documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
K If an individual requests my ISO 9001 QMS Documents, do I have to supply it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Requirement for Review and Re-Approval of Documents - ISO 9001 Clause 4.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Before the ISO-9001 certification audit can we submit the documents to our customer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K How can I revise my QMS documents to meet requirements of ISO 9001: 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q How to name ISO 9001 Checklist, Documents and/or Technical Documents? Document Control Systems, Procedures, Forms and Templates 2
S Revisions in ISO 9001 QMS Documents - Where to keep the record of revisions? Document Control Systems, Procedures, Forms and Templates 7
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Control of Documents - ISO 9001:2008 Drowning in Processes! Document Control Systems, Procedures, Forms and Templates 6
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
M Revision Frequency of Documents (in ISO 9001, cGMP, GMP or others)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Documents required for ISO 17020 vs. ISO 9001? General Measurement Device and Calibration Topics 10
P Required Documents and Document Control in Human Resources for ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 5
P Documents of external origin not identified? ISO9001 Clause ISO 9001:2000 5.4.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 55
K Can ISO 9001 4.2.3 and 4.2.4 Documents and records be one procedure? Document Control Systems, Procedures, Forms and Templates 8
P Form Number for Master List of Controlled Documents - ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 8
L Document Hierarchy Structure for Documents Compliant in ISO 9001 and CMMI Document Control Systems, Procedures, Forms and Templates 23
D Controlled Documents - ISO 9001 4.2.3 - What documents must be controlled? Document Control Systems, Procedures, Forms and Templates 9
R Addressing Training in ISO 9001:2000 Process Documents Training - Internal, External, Online and Distance Learning 21
J ISO 9001:2000 - 4.2.3 Control of Documents - Used to be document and data control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A ISO 9001:2000 - Documents Requiring Control - Documents of External Origin Document Control Systems, Procedures, Forms and Templates 27
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
