D.Scott said:
"Toyota's production system (TPS) is designed (and continually improved) to be able to deliver value by eliminating non-value adding waste and making system processes ever more valuable, capable, available, adequate and flexible."
I think you are lmis-interpreting ISO if you think 9000 doesn't strive for the same thing. This line could be easily applied to the philosophy of continuous improvement of ISO 9000.
"And most companies would appear to do not much more than pursue a certificate, and then do little else, except what is necessary to maintain their certification status. I have been in probably several hundred mid to large-size ISO 9000-certified firms around the world and once I see their shop floors, I would not want to do business with them. But they are certified."
Isn't what you are really saying is that individual companies are probably not benefitting from their own QMS? This isn't the fault of the Standard, it falls back to the company that is implementing it. ISO 9000 is a model for a basic quality system. It isn't a miracle pill that transforms a company into a world leader. Toyota may have a good QMS but I'll bet it is only as good as the implementation. It's the development beyond the basics that make it work so well and the same applies to ISO.
I assume Toyota does in fact buy from somebody and I would assume some of their suppliers are ISO certified. Would all these suppliers fall into your "not want to do business with them" class? I feel confident that Toyota has some sort of supplier requirement and that they work with their suppliers to meet their requirements. Is it possible that Toyota would disqualify a supplier because they were certified to ISO? Are you saying you see no process improvement, elimination of waste, etc. outside of the Toyota system? In your view is a company with no QMS a better supplier than one with ISO? If you can truly answer yes, maybe you are justified in saying there is no "value added" by ISO.
Dave
Dave
Ever notice how much muda sounds like the French merde?
