ISO 9001 Implementation and Certification - 6 Years of Advice
Stijloor
Re: ISO 9001 Implementation and Certification - Some advice
The consultants I know have not dropped their prices, especially to one quarter. I have noticed they are not raising them in the current economy.
That is correct. I have not lowered my consulting fees either.
Stijloor.
Helmut Jilling
Auditor / Consultant
Stijloor.
In fact, not lowered, and I am busier than before. This is a difficult time, and companies are realizing they must improve their performance and position themselves correctly for the recovery. In the coming 12-24 months, more companies will ahve opportunity to gain market share than in the last 5-10 years. Also, more companies will fail or experience difficult situations than did during the downturn. Those that are positioned and ready should do very well.
N
NewQM
You've given good advice about starting small etc, but this bit is bad advice - you are promoting a (mis)understanding that all that's required by the Standard is 6 procedures. Not true, and indicates a failure to grasp what the documentation requirements actually call for.
The standard only *specifically* requires 6 documented procedures. While it is true that more are generally needed, only 6 HAVE to be in place. If you will read my post closeley, you will see that i suggested STARTING with the 6 required.
When reading the standard, highlight the phrase "A documented procedure shall be established to define requirements for..."
you will see it only 6 times.
again, i only suggested starting with the 6, i never meant to imply leaving it at that is the best option....
you will see i also suggested to pay close attention to their design procedure.
Thank you for the comments,
James
JaneB
James,
My posting was not a failure to read your post 'closely'. With respect, I've seen this kind of 'you only need 6 procedures' misinformation many many times before. And the poor results it brings.
I stand by what I wrote.
To start with those procedures? Nope. :nope:
Absolutely not. I repeat: bad advice. I not infrequently with clients have them sort out their Doc Control procedure early on (so other documents will be controlled as they develop them) but there's infinitely more important things to focus on, like their core processes (not procedures yet!) and their objectives (what are they aiming to achieve?).
I can understand why the kind of idea you're suggesting proliferates, because the way the Standard is written makes understanding the real requirements for documentation somewhat confusing - particularly for new and inexperienced people. Promulgating the idea that 'all you need is 6 where it says shall' is a simplistic understanding and poor advice.
I wrote in this post in 'What Should Be Changed in ISO 9001:2014?' a suggested revision to express the the documentation requirements more clearly and avoid such common misunderstandings.
N
NewQM
James,
To each their own....
If you will read the original question, he says that they want certification in order to get contracts. while this is not the ideal, it is the truth.
Respectfully, i stand by the advice i have given. For someone new to writing a QMS...this is a good way (again, not the only way) to start.
I know we don't like to admit it, but for a lot of companies, they aren't looking for a QMS; they are looking for a certificate on the wall. From the original post, that is what i gather this design firm is looking for.
Sidney Vianna
Post Responsibly
:agree1: Yes, Jane. It is disheartening that we still have a high percentage of consultants who see and promote ISO 9001 implementation via the despicable "say-what-you-do-do-what-you-say" approach, rather than the intended plan-do-check-act cycle.
ISO 9001 implementation and certification has been trivialized by many, so it can be "commoditized", packaged, sold and bought with canned approaches, faster, cheaper, easier.
The suckers organizations get the seal on the wall, the ticket to trade, but are not an iota better, in terms of customer satisfaction and cost of non-quality at the end of the engagement.
somerqc
As much as I agree with JaneB et al, the harsh reality is that many, many companies simply as the wrong question. What do I have to do to get ISO registered? (well, most of them use "certified").
I try to answer that question by asking them "what do you do on any given day?", "Does it work?". Usually the 2nd question is "most of the time". So I start with looking that their processes for gaps (usually communication gaps), fix those, and move forward.
Unfortunately, many just want the wallpaper and that approach (although will result in better system) is too slow for them so the "6 procedures" approach lives.
Sad but true.
N
NewQM
why despicable? would you prefer to go in and "shake things up?"
If a company has been succesfull without a certification, why go in and change everything?
Why not just set up the documentation and let them ease into it?
This is why so many companies are nervous about setting up a QMS...consultants with a god complex and a "my way or the highway" approach to the QMS....
When companies receive a cert from us, we routinely hear something to the effect of: "we had another consultant that came in and tried to change everything because ISO REQUIRED IT"
HA! Requires what?!?that consultant was fired, we were hired.
If it isn't broken, don't fix it.
there are much less invasive measures with which to improve customer satisfaction/cost of quality, etc.
Sidney Vianna
Post Responsibly
Because, IN THE VAST MAJORITY OF CASES, that is the approach which obviously brings no changes to the organization at hand. And, in general, no changes mean maintenance of substandard performance.
In my experience, the VAST MAJORITY of organizations require a profound cultural change to adapt and adopt the underlying concepts of an ISO 9001 based QMS.
Sure, if you have a high performing organization, which is culturally compatible with modern quality management practices, you might have a case for minimal impact onto them. But, if this organization is so good to start with, why would they be running a tribal-knowledge based, undocumented QMS? If they are so good, why would a customer require a non-value added certification?
JaneB
That's not what I read from the original question here. He said they needed it for one client, but did acknowledge that as not ideal. To leap from that as 'they are looking for a certificate on the wall'? Not sure how you made that jump.
You see, the real power of ISO 9001 is way beyond 'write up 6 mandatory procedures'. So to advise someone that that's where they should start is akin to telling someone who wants to learn to drive to memorise the parking distances... yes, it's needed, but it's not all there is and there's oh, so much more.
If the question had been - how do I go about documenting our system, just possibly (and I'm being overly charitable because that old '6 procedures' canned stuff ain't good). It wasn't.
As Sidney said so elegantly:
And the fundamentally important thing is that the organisation is better off improved!! as a result of undertaking ISO 9001. Not just 'same ol, same ol, but got the cert on the wall' garbage.
Just whack in a few mandatory procedures and 'ease into it'? Nope. Seen what that does. Usually gives people a very false idea about what "ISO 9001' is really about and cheeses them off. And then it takes a while for them to understand what's really available.
None of the consultants of any integrity who write in here regularly have a God complex or a 'my way or the highway approach'. Including me. But yes, we do care, passionately, about real quality, not the commoditised, watered-down, paint-by-numbers-just-do-6-mandatory-procedures garbage.
Huh? :confused: Is the meaning of 'us' that you're from a certifying company? Your name says your'e a 'NewQM' and your profile lists you as a Quality Manager. Are you neither of those?
As for the 'ain't broken, don't fix', as Sidney says so well:
Mine too.
Precisely. Customers want the benefits that certification is supposed to - and should - bring.
Following the '6 procedures' approach devalues that and detracts from it.
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B ISO 9001 Implementation Time Frame ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
V ISO 9001:2015 Implementation Packages ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
a_bardi ISO 9001:2015 - Implementation in 4 Plants Different Countries ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Partial Implementation of ISO 9001 in a Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A ISO 9001:2015 Implementation for Marketing and Sales Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Informational Risk Management Implementation for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 60
H How to find a good ISO 9001 Implementation Consultant in Calgary, Canada? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
F ISO 9001 Implementation Advice for Multiple Locations needed! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R OHSAS 18001 & ISO 9001 Implementation - help! Process Maps, Process Mapping and Turtle Diagrams 7
D Consultancy company - ISO 9001 Implementation and Design Exclusion ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R ISO 9001 Implementation in the Bus/Coach Industry - Confused and Help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F ISO 9001 QMS Implementation in an Engineer To Order business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Bilingual ISO 9001 Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Help with ISO 9001 Implementation in Oil Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J ISO 9001 Implementation in SMEs - What are the Possible Barriers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B ISO 9001 Implementation for the Legal Department in my company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
N ISO 9001 Implementation - I am still confused on where to start ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S How to start implementation of ISO 9001 in manufacturing concern? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Why do so many ISO 9001 Implementation Programs Fail? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 171
D Stuck in the middle of ISO 9001:2008 Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
C Organization unsure about the ISO 9001 implementation route? Share your thoughts. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A Problems in Implementation of ISO 9001 - How to React? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A 100% Contract Labours (workers) - Is it ok for ISO 9001 implementation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D ISO 9001 Certification Implementation Project Consultant Expectations ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J ISO 9001 Implementation moving forward - Completed pre-assessment audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
V Small Startup Manufacturer ISO 9001 Implementation and Registration Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Implementation of SAP and compliance to ISO 9001: 2008 Document Control Systems, Procedures, Forms and Templates 7
G ISO 9001 Implementation in a Travel Agency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B One Man ISO 9001 Implementation - Help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Gantt Chart or Excel Spreadsheet for ISO 9001 Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P ISO 9001 Implementation Roadblocks - Small Manufacturing Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Case Study - Implementation of ISO 9001:2008 in Small Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001 Implementation - Quality Manual is Dreary! Documentation Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
I ISO 9001: 2008 Implementation - Quality Manual First -> Questionable approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
A ISO 9001 Implementation - Advice appreciated ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S New to ISO 9001 - Where to start implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 69
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
I ISO software: Valuable during ISO 9001 implementation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 42
A ISO 9001:2008 - Implementation in practice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
N ISO 9001 Implementation - Fabless Semiconductor (ASIC) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F ISO 9001 implementation at a prototyping shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Howard Atkins Implementation Guidance for ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001:2000 Implementation Project: finished procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 52
I ISO 9001:2000 Implementation Project: How to find assistance (training, consulting)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 54
G Is a copy of the ISO 9001 Standard necessary before starting an implementation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
A Focus and Scope of ISO 9001:2000 Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
