N
Re: ISO 9001 Implementation and Certification - Some advice
Indeed.
I was arguing from the standpoint of a hypothetical company that has been around for 20 years. Their processes / customer service are obviously adequate (as they have been around for 20 years). Most likely, what they lack are things such as a documented management review/ internal audit, a formal CAR/PAR-ish program and a records process that would conform to 9000.
For this company, minimally invasive consulting is better.
Similarly, some companies maintain an undocumented QMS simply because they are a family owned/operated company and utilize "tribal knowledge" as you put it. Consultants must be even more careful about changing processes at these companies, or risk offending daddy.
In the case of a disorganized / young company, I say that it is probably okay to go ahead and "shake things up." Or create their QMS, rather. ON A CASE BY CASE BASIS.
In Houston, a lot of companies require registration for admittance to an AVL (or are forced to do customer audits).
Also, international contracts can require registration.
I wouldn't go so far as to say that large changes are never required, just not usually.
Then again, what do I know?
Because, IN THE VAST MAJORITY OF CASES, that is the approach which obviously brings no changes to the organization at hand. And, in general, no changes mean maintenance of substandard performance.
In my experience, the VAST MAJORITY of organizations require a profound cultural change to adapt and adopt the underlying concepts of an ISO 9001 based QMS.
Sure, if you have a high performing organization, which is culturally compatible with modern quality management practices, you might have a case for minimal impact onto them. But, if this organization is so good to start with, why would they be running a tribal-knowledge based, undocumented QMS? If they are so good, why would a customer require a non-value added certification?
Indeed.
Is it necessary to have a internal audit cycle to the new QM?
