ISO 9001 Internal Audit Checklist
G
Goldstarr
Members
I am not sure if similar threads were posted before. I could not find any related to this. I am looking for the internal Audit checklist for ISO that may be used for conducting internal audit. Can anyone share the templates which have used in carrying out the internal audit.
Thank you all in advance for the help
Ajit Basrur
Re: ISO 9001 - Looking for an Internal Audit Checklist
We have couple of good internal audit checklists
EDIT: OBSOLETE LINK DELETED.
Randy
Pre-packaged, regurjitated, checklists won't accomplish what you need to do.
The best checklist you can use for internal audits, beyond making sure that the basic management system elements are in place, are your own documents (procedures, instructions, policies, flow charts, plans, how to do it instructions or whatever you call stuff).
Take a document, any document, read it line-by-line and verify that stuff is happening the way the document states that it is supposed to happen such as ..."The operator will ... " , well make sure the operator does what the document says he/she is supposed to do. If a measurement is supposed to happen, make sure stuff is measured, if a record is supposed to be kept, make sure there is a record
It is no more difficult than that. Almost without fail, on nearly every audit I do (about 100 or so this year) the auditee is surprised when I find out that they said they will do something and show them where they aren't. Why? About 99% of the time they are doing their internal audits with some pre-programmed checklist and not getting into their own documents as they should....It's like playing Russian Roulette with a loaded single shot pistol and expecting no injury.
There is absolutely no way that anyone will have any kind of checklist for your stuff.
Note: If you don't know what Russian Roulette is follow the link:
Wikipedia reference-linkRussian_roulette
Crusader
Our ISO 9001 system is established enough to where we just audit the procedures, processes, work instructions, etc. to ensure we're following them. And try to suggest opportunities for improvement if possible.
Once you get a system that adheres to the requirements, let go of those checklists!!!
Always rotating auditors because they see things differently and suggest different ideas. It's really working very well!
Members
I am not sure if similar threads were posted before.I could not find any related to this.I am looking for the internal Audit checklist for ISO that may be used for conducting internal audit. Can anyone share the templates which have used in carrying out the internal audit.
As Randy suggested and I'll add, the biggest mistake people make starting out an internal audit is thinking someone else's checklist is going to be any use to them. It would be like going on a grocery shopping trip with someone else's shopping list! OK, so there may be some basics - eggs, bread etc. but these are like document and record control. The rest of the list isn't going to be any good!
The most effective audits are done by people who invest in sitting down and planning their audit, and then derive their own list of items they wish to observe and question the specific process people about. Nothing else works, frankly, despite what some others may tell you. Canned checklists are the biggest hole you can dig for yourself and jump into when it comes to doing audits ineffectively.
LUV-d-4UM
I normally use the work instructions and make a customize checklist when conducting an ISO9001 based process audit. Happy New Year!
supermac
I would endorse what has already been said. To give some credence to that viewpoint, ask yourself this - what do I do if the answer to one of the items on the checklist is no? it could be a nonconformance, or it may be not applicable, or you may be asking the wrong person/function etc. I addition to the previous suggestions a good place to start with almost any person is - what is your job, who do you interact with and how do you know you are successful? THEN ask the questions, what process/procedure/work instructions/training... I hope this helps.
G
guruprasadb
Hi
this thread contains Internal Audit Report Example Template
we have started preparing check sheet for every process but to suggestion of all our internal auditors to have open audits, we have stopped preparing but any how i am attaching the Audit checklist prepared might be use ful
ChrissieO
As the well know 60s pop duo "Andy and Randy" have both said. Check lists for most standards, especially 9001 are of no value whatsoever to an auditor, the auditee or the organisation. The use of them results in tick box audits that look at the compliance to the standards rather than the actual processes.
Please tell me they don't still teach auditors to use check lists on auditng courses. They are my pet hate and I will not stop my campaign against them until they are banished into room 101 for ever:whip::whip::whip:
Chrissie
drgnrider
Had Lead Auditor training back in July, they recommended not too. :frust:
Our company is about to have our third Registrar audit next month. I know my company uses these... (previous QMR is now Factory Director and he was the creator of this process). I am going to TRY to adjust them :lmao: to be more process oriented, especially since out last RA said this about our IA process:
"Auditor notes show they are focused on the right issues; however audit planning continues to be based on clauses and not always on the system processes."
I also will have our IA's follow the RA's and observe what they are doing to see where they can improve.
I guess we are getting grief :argue: from our sister-plants about using these. :notme:
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A ISO 9001 Internal Audits - No production right now due to furloughs Internal Auditing 5
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
D Impartiality of Internal Auditor ISO 9001/13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
D ISO 9001:2015 Internal Audit Training Advice Internal Auditing 10
W Where to begin with an ISO 9001:2015 internal audit Internal Auditing 13
E ISO 9001:2015 - Internal Audit Plan Clauses General Auditing Discussions 8
S Internal Audit - Risk and Opportunity (ISO 9001:2015 ) Internal Auditing 1
tony s An organization's Internal Audit Office certified to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
Tagin Does ISO 9001:2015 require a full internal audit annually? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
T Relevant internal and external communication - ISO 9001:2015 section 7.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Please review my ISO 9001:2015 Internal Audit Plan Process Audits and Layered Process Audits 7
Y ISO 9001:2015 Cl. 4.1 Note 1 - External and Internal issues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
qualprod External/internal issues removed as well? ISO 9001:2015 Cl. 4.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O ISO 9001:2015 Transition Internal Audit completion thread ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
J ISO 9001 Competency - Forklift License and Internal Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 - Internal Auditing - Audit to the Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
P Internal Audit Schedule Complexity (ISO 9001:2015 ) Internal Auditing 3
Z ISO 9001:2015 Internal Audit Template/Form Advice Document Control Systems, Procedures, Forms and Templates 4
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Thoughts on performing an ISO 9001:2015 Remote Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
L Auditing Design and Development in ISO 9001 (Internal Audit) Internal Auditing 1
F What is your favorite software for ISO 9001:2015 Internal Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
A Developing a ISO 9001:2015 Internal Audit Plan and Schedule Internal Auditing 40
A Internal Audit - Coverage for ISO 9001:2015 Internal Auditing 4
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
V Certified Internal auditor is necessary? ISO 9001 requirement? Quality Management System (QMS) Manuals 4
J Can I conduct Internal Audit for combined ISO 9001, ISO 13485 and ISO 14001? Internal Auditing 37
P Can internal ISO 17025 Auditor conduct ISO 9001 Audit ISO 17025 related Discussions 7
Gman2 Internal Auditing Requirements before ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L Who can perform ISO 9001:2008 Internal Audit prior to our Registration Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T ISO 9001 Internal Auditing Auditor Training in Amsterdam Training - Internal, External, Online and Distance Learning 1
T Should the Internal audit for ISO 9001 cover all elements of the standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Marc Does ISO 9001 *require* that Internal Audits be Process Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C ISO 9001 - 5.5.3. Internal Communication clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P ISO 9001 Internal audit rotation in a small company Internal Auditing 7
Colin What QMS Internal Audits must cover and ISO 9001 Internal Auditing 19
S Is software developed for Internal Use covered by ISO 9001:2008 Sec 7.3? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
O ISO 9001 requirements for what Internal Audits must cover Internal Auditing 7
I Types of Internal Audit findings based on ISO 9001 Clause 8.2.2 Quality Manager and Management Related Issues 10
L Internal Re-audit after Major Finding during ISO 9001 Re-Certification Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
