ISO 9001 Internal Audit Compliance Scoring System
Crusader
#21
Crusader,
I wanted to evaluate only one section of QMS which is Measurement, Analysis and Improvement. Is it possible? If yes, can you help me how my table and formulas would be? I have 6 divisions in my company.
Also, can you tel me why you use -30, -20, -10 specifically?
Thanks.
I can try to help. I used those numbers at random. You can use any metric you choose.
Crusader
#22
Crusader,
Thanks.
Sorry, I forgot about this thread....I thought you were going to provide more info but I can set something up without any more info.....give me some time today and I will try to post a file later that you should be able to modify and use.
Simon123456
#23
Hi
Excellent spreadsheet. I've long been tweaking a number of files I use to do just this. My only issue has been getting everything to tie in. We have ISO9001 and ISO17025 so they are not totally in alignment but they are getting there.
If I could ask an obvious question with regards the scores used. Maybe get an idea or fuller description of each score level. You have mentioned in your sheet that you can score more than once so I am assuming it could be say a score in 1 and 6?
1 - Fully Documented & Implemented
2 - Not Documented & Not Implemented
3 - Documented - Not Implemented
4 - Documented - Partially Implemented
5 - Implemented - Not Documented
6 - No Records / No Objective Evidence
7 - Inc. Records / Doc-process mismatch
Simon
Crusader
#24
Hi
Simon
More like 4 and 6 and or 7.
If you get a 1, then there would be no need to discount further.
Note:
I have since changed this scoring system to a completely different system…since I changed jobs and I am starting from scratch. That older scoring system only worked well for an established system, IMHO.
I'll share the scoring labels a little later. Just got home and I have 3 hungry felines circling me! :mg:
Crusader
#25
Here is what I am using now and it most likely will evolve as I try out this new scoring:
1 - (100 pts) Fully Implemented
2 - (-100 pts) Nothing Implemented
3 - (-50 pts) Under 50% Implemented
4 - (-40 pts) No Records OR Objective Evidence
5 - (-30 pts) Over 50% Implemented
6 - (-20 pts) Process / Document Mismatch
7 - (-10 pts) Missing or Incomplete Records
Simon123456
#26
Many thanks.
Mine is an established system but in need of a review due to the number of other standards and new clauses we are introducing.
Thanks for the help
Helmut Jilling
Auditor / Consultant
#27
1. Just a reminder, ISO does not require a scoring system. That is a convention that was set up for an item by item type gap audit.
2. Looking at the CD1 Draft of ISO 9001, it appears they might finally be making the requirement to follow a process approach more explicit...15 years later. As such, the auditing will need to fully follow a process approach. For a lot of ISO companies, that will be a new thing in their audits.
Crusader
#28
1. You are correct. No scoring system is required.
2. No. The scoring system is not set up as a item by item gap audit. Not at all! I do not audit clause by clause, etc. I merely score how I estimate that the company meets each requirement of the ISO 9001 standard after the audit each month. Audits vary and I cover a lot of areas at once.
This scoring method is an easy method for assessing compliance…and it works.
#29
I agree with Helmut. Crusader, before you go too far down this road, points scoring will lead to exactly the wrong behaviour IMHO. It will become a case of "points" and not management understanding what they need to do to effectively manage their processes and use audit to validate that. I've encountered too many managers who simply pick up on easy to grasp numbers and completely overlook what they mean! As a CB auditor, too many people wanted to know how they compared on the total number of ncs that other companies get - what a stupid question. They might have just 1! "The system is not implemented".
So, I'd appeal to you to review what is necessary to drive management to do something - which is going to be risk based - risk to customers, their satisfaction, compliance to regs (if applicable, risk to stakeholders (usually $$$) or their personal risk of missing their objectives. That will be sufficient to get action, not "50/100".
Crusader
#30
Seriously, I think you and Helmut are misinterpreting the scoring tool. You're going too deep into some other direction and I'm like scratching my head?whhhaaaat? How'd you get there from way over here?
It's a simple tool or an aid for the user. Apparently, I don't have the issues you say may happen and I've never had those issues since starting this scoring tool.
Truce! :bigwave:
D Impartiality of Internal Auditor ISO 9001/13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
D ISO 9001:2015 Internal Audit Training Advice Internal Auditing 10
W Where to begin with an ISO 9001:2015 internal audit Internal Auditing 13
E ISO 9001:2015 - Internal Audit Plan Clauses General Auditing Discussions 8
S Internal Audit - Risk and Opportunity (ISO 9001:2015 ) Elsmar Xenforo Forum Software Instructions and Help 1
tony s An organization's Internal Audit Office certified to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
Tagin Does ISO 9001:2015 require a full internal audit annually? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
T Relevant internal and external communication - ISO 9001:2015 section 7.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Please review my ISO 9001:2015 Internal Audit Plan Process Audits and Layered Process Audits 7
Y ISO 9001:2015 Cl. 4.1 Note 1 - External and Internal issues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q External/internal issues removed as well? ISO 9001:2015 Cl. 4.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O ISO 9001:2015 Transition Internal Audit completion thread ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
J ISO 9001 Competency - Forklift License and Internal Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 - Internal Auditing - Audit to the Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
P Internal Audit Schedule Complexity (ISO 9001:2015 ) Internal Auditing 3
Z ISO 9001:2015 Internal Audit Template/Form Advice Document Control Systems, Procedures, Forms and Templates 4
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Thoughts on performing an ISO 9001:2015 Remote Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
L Auditing Design and Development in ISO 9001 (Internal Audit) Internal Auditing 1
F What is your favorite software for ISO 9001:2015 Internal Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
A Developing a ISO 9001:2015 Internal Audit Plan and Schedule ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
A Internal Audit - Coverage for ISO 9001:2015 Internal Auditing 4
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
V Certified Internal auditor is necessary? ISO 9001 requirement? Quality Management System (QMS) Manuals 4
J Can I conduct Internal Audit for combined ISO 9001, ISO 13485 and ISO 14001? Internal Auditing 37
P Can internal ISO 17025 Auditor conduct ISO 9001 Audit ISO 17025 related Discussions 7
Gman2 Internal Auditing Requirements before ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L Who can perform ISO 9001:2008 Internal Audit prior to our Registration Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T ISO 9001 Internal Auditing Auditor Training in Amsterdam Training - Internal, External, Online and Distance Learning 1
T Should the Internal audit for ISO 9001 cover all elements of the standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Marc Does ISO 9001 *require* that Internal Audits be Process Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C ISO 9001 - 5.5.3. Internal Communication clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P ISO 9001 Internal audit rotation in a small company Internal Auditing 7
Colin What QMS Internal Audits must cover and ISO 9001 Internal Auditing 19
G ISO 9001 Internal Audit Checklist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
S Is software developed for Internal Use covered by ISO 9001:2008 Sec 7.3? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
O ISO 9001 requirements for what Internal Audits must cover Internal Auditing 7
I Types of Internal Audit findings based on ISO 9001 Clause 8.2.2 Quality Manager and Management Related Issues 10
L Internal Re-audit after Major Finding during ISO 9001 Re-Certification Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B Internal Audit Requirements for ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D ISO 9001:2008 Internal Audit ? Strategic Department Internal Auditing 6
M Internal Audit of our ISO 9001 Quality Systems prior to the Registration Audit Internal Auditing 9
B Combined ISO 9001/ISO 14001 Internal Audits Miscellaneous Environmental Standards and EMS Related Discussions 7
J ISO 9001 Checklist Type Internal Audit Forms? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
