ISO 9001 Internal Auditing for Construction Company
L
Limmeng
I hope someone could help me with performing ISO 9001 compliance audit (after Management Review) prior to initial/certification audit (first time by Registrar).
For example - how is the "process approach" trailing done, especially when it comes to auditing the construction site(s).
Please help. I have some experiences auditing manufacturing but never in construction (building) industry.
Thank you
Lim Ah Meng.:)
joshua_sx1
Re: ISO 9001 Auditing for Construction Company
…the same approach as in manufacturing :rolleyes: … you are only going to replace the “product” by “project”… which means, project quality plan would be necessary, ITP's, as well as the project quality objectives, document & record control procedures, control of nonconforming works (instead of products), corrective & preventive actions and so on… including customer satisfaction & complaints…
Thank you
Lim Ah Meng.:)
This is a great question and thanks for bringing it here to be answered.
For my reply, the answer is going to be based on the 'scope' and 'criteria' of the audit. In the case where you might be on a construction site, then there are multiple topics to choose from: Without that it's going to be difficult to advise and the stage of the construction is going to be a factor.
If you are pouring concrete, then you could follow the process, from arrival of the readimix on site (if that's applicable and it's not mixed on site) ensuring the slump test is done before discharge, the mix is correct type/grade, etc. etc. through pouring into the formwork, etc.
Often in construction, the internal auditor has to plan their audit to coincide with these stages, so if you can tell us we can give a more complete answer.
L
Limmeng
Thanks Andy,
The construction company is a main contractor - performing tendering, do management work, until the tender being awarded to them.
Having won the contract, the company selects sub-contractors to perfom on-site work.
Assuming, the scope is construction management and related ancillary work, how does one perform "process approach" auditing?
For work that can be repaired (touch up) most of the time, how do they record "control of non-conforming work"?
Hopefully my english is well understood.
Thank you.
Lim Ah Meng
joshua_sx1
...exactly the one I have before… main contractor - and if contract has won, subcontracts the works… (I don’t really know how they’re winning contract for that, but they are)…
…anyway, you’ll be involved more on contract review… both from your company-to-customer contract and company-to-supplier contracts… and of course, the monitoring of your customer satisfaction (in the form of client inspection and/or audit) and your suppliers' performances (in the form of your inspection and/or audit)…
…process approach auditing for this type of company, also deals with the ISO mandatory procedures (e.g. document control, record control, internal audit, etc…)… the thing that is going to be more specific is the project’s scope of work, that’s why you have to be knowledgeable of the project contract and its scope of work... any changes, additional works to be carried-out should be covered by your contract review…
…at the construction site, project plan alone is already a huge audit… the work progress as the time of the audit… competency of your project team… any corrective and/or preventive action taken or will be taken… control of non-conforming works… s curves… perp (if you are using)… drawings revision control including their distributions (if not covered by your document control generic procedure)… and so on…
…and speaking of “non-conforming work”... how to record a simple touch-up repair will be depend on your project management prerogative… let say, recording it will be insignificant since you are going to spend more on recording it than doing the actual repair, or accordingly, your project management does not considered it as non-conforming works since “retouching” is part of your scope of work… unless of course you have a histogram showing that this “retouching” is giving you a huge cost that minimizing it (if not totally eliminating) would be beneficial as cost cutting programs…
…I experienced before in one of our project that this “retouching” is not being given an attention and therefore not even considering it as nonconformity… until the project management realized that it cost them so much on this activity… and therefore, revised the project plan in such a way that the “retouching” activities would be in the last phase of the project… and started monitoring the cause of every retouching done…
…your English is very well understood, by the way…
L
Limmeng
Dear Joshua.
Thanks for the reply. Indeed it is helpful.
So please help me with the internal audit plan. As I understand from your reply, my (process) audit plan will have "something like" - 1) Management activities - including client focus, corrective/preventive actions, client complaints, internal audit 2) Tendering Process, 3) Contract Review 4) Site Audit - including control of non-conforming work and PQP 5) Human Resources/Training 6) Purchasing and Sub-contractor selection.
This may be what I can figure out from your reply. Any additional inputs perhaps - or did I understand it correctly?
What is normally audited during "Contract Review"?
Thanks again,
Lim.
joshua_sx1
…exactly as you understood for the internal audit plan… well, you can add or deduct later on as part of your continual improvement… don’t try to be perfectionist on your 1st (or 2nd, 3rd, etc) audit – you will not move with that thinking… that’s why ISO includes continual improvement, because they knew that it would be impossible for organization to achieve perfection… those things you have given are already an excellent starting points… and adopt continual improvement as required and/or as you see the necessity of improving it…
…contract review as per clause 7.2.2 review of requirements related to product should cover review before your company’s commitment to do it (e.g. submission of tenders, contracts acceptance, changes or revision, etc.) – you have to have records of this review and that they are properly reviewed, signed and agreed by both parties…
…the two most important things to consider for the review are; when your customer provides no documentation of their requirements, you’ll have to create one based on your SOP and you’ll have to confirm this before acceptance and of course before the commencement of the project… and, for every changes of project requirements (either from your customer or from your project management), you should have records of these amendments including their review & approval and that relevant personnel should be made aware of these changes (specifically those who are on site personnel that is going to implement the changes)…
L
Limmeng
Dear Joshua, thanks.
The more I ask, the more I want to know - I guess.
Where do the following activities fit in, in terms of ISO 9001 clause?
1. safety precaution required - is it related to 6.4 Infra-structure or is it to compliance? I noticed a lot of effort has to be put into documentation on this.
2. customer satisfaction is not gauged. How can i exercise this? It always end up with handover of completed project.
Thanks again,
Lim.
joshua_sx1
Safety precaution?... well, obviously in absence of OHSAS to your management system, you can include it in 6.3 - actually for infrastructure since 6.4 is for work environment… you have to bear in mind, that ISO requires compliance on its specified requirements… if you are meeting the minimum requirements, you’ll be OK… if you go beyond minimum, that’s fine too! ISO will not oppose on that… (e.g. if you feel that “safety precaution” can directly affect the quality of your works, the more you have to include it in your QMS… on the other hand, if it is not, but you want to include it, then include it – it is not against ISO)…
Customer satisfaction can be achieved in many approach… if you will try to search the forum, you’ll find a lot of strategies on how to “exercise” it… but the usual approach in construction would be creating an appropriate questionnaire for you to come out with your satisfaction level – specifically when the project has completed… but I’ve seen some main contractor companies that getting customer satisfaction level on completion of each construction phase… meaning, for every completion of major works (e.g. civil, mechanical or electrical), they will ask the customer of their satisfaction level on that specific works… and again, this is not against ISO… if this strategy will help your project management to improve more on each specific scope of work, then adopt this strategy… the point is, you have to comply with ISO requirements but at the same time you have to evaluate the effectiveness of this system in your organization and improve it accordingly…
harry
Thanks again,
Lim.
If you are in Malaysia, safety comes under the Factories and Machineries department. It is an independent issue not related to ISO evidenced by the need to abide by it even if you are not ISO certified.
Handing over of the project is not the end. There's maintenance period during which the customer may have a different view of you. It really ends with the closing of project accounts.
D Impartiality of Internal Auditor ISO 9001/13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
D ISO 9001:2015 Internal Audit Training Advice Internal Auditing 10
W Where to begin with an ISO 9001:2015 internal audit Internal Auditing 13
E ISO 9001:2015 - Internal Audit Plan Clauses General Auditing Discussions 8
S Internal Audit - Risk and Opportunity (ISO 9001:2015 ) Internal Auditing 1
tony s An organization's Internal Audit Office certified to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
Tagin Does ISO 9001:2015 require a full internal audit annually? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
T Relevant internal and external communication - ISO 9001:2015 section 7.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Please review my ISO 9001:2015 Internal Audit Plan Process Audits and Layered Process Audits 7
Y ISO 9001:2015 Cl. 4.1 Note 1 - External and Internal issues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
qualprod External/internal issues removed as well? ISO 9001:2015 Cl. 4.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O ISO 9001:2015 Transition Internal Audit completion thread ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
J ISO 9001 Competency - Forklift License and Internal Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 - Internal Auditing - Audit to the Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
P Internal Audit Schedule Complexity (ISO 9001:2015 ) Internal Auditing 3
Z ISO 9001:2015 Internal Audit Template/Form Advice Document Control Systems, Procedures, Forms and Templates 4
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Thoughts on performing an ISO 9001:2015 Remote Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
L Auditing Design and Development in ISO 9001 (Internal Audit) Internal Auditing 1
F What is your favorite software for ISO 9001:2015 Internal Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
A Developing a ISO 9001:2015 Internal Audit Plan and Schedule Internal Auditing 40
A Internal Audit - Coverage for ISO 9001:2015 Internal Auditing 4
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
V Certified Internal auditor is necessary? ISO 9001 requirement? Quality Management System (QMS) Manuals 4
J Can I conduct Internal Audit for combined ISO 9001, ISO 13485 and ISO 14001? Internal Auditing 37
P Can internal ISO 17025 Auditor conduct ISO 9001 Audit ISO 17025 related Discussions 7
Gman2 Internal Auditing Requirements before ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L Who can perform ISO 9001:2008 Internal Audit prior to our Registration Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T ISO 9001 Internal Auditing Auditor Training in Amsterdam Training - Internal, External, Online and Distance Learning 1
T Should the Internal audit for ISO 9001 cover all elements of the standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Marc Does ISO 9001 *require* that Internal Audits be Process Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C ISO 9001 - 5.5.3. Internal Communication clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P ISO 9001 Internal audit rotation in a small company Internal Auditing 7
Colin What QMS Internal Audits must cover and ISO 9001 Internal Auditing 19
G ISO 9001 Internal Audit Checklist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
S Is software developed for Internal Use covered by ISO 9001:2008 Sec 7.3? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
O ISO 9001 requirements for what Internal Audits must cover Internal Auditing 7
I Types of Internal Audit findings based on ISO 9001 Clause 8.2.2 Quality Manager and Management Related Issues 10
L Internal Re-audit after Major Finding during ISO 9001 Re-Certification Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B Internal Audit Requirements for ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
