ISO 9001 prohibits auditors auditing their 'own work' while other standards don't?
samsung
As far as Internal Auditing goes, ISO 9001 specifically prohibits the auditors against auditing their 'own work' in the following requirement:
The selection of auditors and conduct of audits shall ensure objectivity and impartiality of the audit process. Auditors shall not audit their own work.
whereas the other PDCA based management systems such as ISO 14001, OHSAS 18001 etc. that too advocate the need for 'Internal Auditing' in the same way as 9001 does, don't specify this 'additional' requirement that leaves me questioning:
1. Whether the concept of 'internal auditing' among all the management system standards is not identical ? or
2. Ensuring 'objectivity and impartiality of the audit process' is altogether different from 'not auditing one's own work' ?
3. The term 'own work' has some different meaning in the context of QMS ?
4. Do other standards don't have anything that can be rated as one's 'own work' ? And if they do, can it be audited unlike ISO 9001's specific requirement ?
Your inputs would certainly help me understand the rationale behind this particular requirement.
Thanks in advance,
Re: ISO 9001 prohibits auditors auditing their 'own work' while other standards don't
Yes, it's not identical in requirements, but the concept is similar (not identical)
Even if you don't audit 'your own work' auditors still need to be selected for the lack of bias etc. There are plenty of people who have an 'axe to grind' about other functions in an organization.
In small organizations, it's often difficult to provide sufficient quantity of auditors, so the minimum is, don't audit your own work.
In ISO 14000, for example, responsibilities for the environmental impacts and aspects are somewhat different to product quality. Hence no 'your work'...
Randy
Maybe "narrow-mindedness" of the people that wrote 9001 along with not paying attention to the documents own "Scope"
tomvehoski
I believe it is an attempt at eliminating potential bias. I also believe it is impossible to do that. As long as audit findings are treated like demerits or speeding tickets, an individual will have the desire to avoid being tagged with one. If I have that attitude and audit my own work, I am obviously not going to find anything wrong with it.
Problem is, there are many ways that bias can appear even if you don't audit your own work. Bob may want to make his department look better than another, so he hits that department with as many findings as he can. John might be afraid of getting in trouble because the Purchasing Manager golfs with his boss every weekend, so he is not going to write him up. The consultant I hire as an internal auditor wants to come back to my plant near the beach for a long weekend (at my expense), so he issues tons of findings that require follow up. Even my registration auditor may be biased to either be hard on the system to get a follow up audit day, or easy to prevent me from dumping him for another auditor.
I believe that is why the 1994 standard required independence, but that became an issue for the small organizations.
If internal audits findings were treated as good things and a benefit (in the long run) vs. a detriment, many of those bias reasons would go away. Nothing can eliminate all motivation for bias.
ISO 9001 uses a process-based approach. It is only logical that one should not audit their own process. They are too close to it and might not be see if for what it really is.
ISO 14001 and OHSAS 18001 tend to flow across processes, and many of the envirommental management (and safety) system programs tend to involve everyone in the organization. It would be difficult to say that a person cannot audit the paper recycling program because that person participates in the recycling.
In all cases, the standards do say that the selection of the auditors and conduct of the audits need to ensure objectivity and impartiality.
What you're describing is the result of poor audit management - something which no accredited training course (perhaps the most popular type of auditor training) even touches upon. Without effective audit management you will get these symptoms...
Dave, surely a process isn't the same as work? Why couldn't a person from one molding process - one they work on - go and audit a process that produces a similar product by molding?
samsung
I agree to the fact that one should not audit one's own (quality) process but at the same time if the process does have some environmental aspects, the EMS part (but not the QMS) of this process can be audited by an auditor who is although, not independent of this process, yet demonstrates (or can demonstrate) 'objectivity & impartiality' to his/her own process.
Let's take the example of one manufacturing process - packaging & despatching e.g. - This process can have many significant environmental aspects, e.g., air pollution (packaging of powdery material), use & disposal of torn/ unusable bags, noise generated by machines/ lorries / workmen, generation of solid waste etc. etc. Now, 9001 clearly defines the requirement & hence no confusion whatsoever but insofar, 14001 is concerned, IMO, the auditor, if s/he happens to be the process owner/ participant, must not even audit the EMS part of this process because s/he won't be able to do any justice to the auditing process. But, based on the stated (& unstated as well) requirements of ISO 14001, the auditor (process owner/ participant) can do so. If s/he is allowed to audit this process, s/he wouldn't show that there's environmentally anything wrong with this process.
My point is - what constitutes one's own work ? If it matters so much for QMS, why shouldn't the same philosophy be applicable to other standards. After all the process owner is equally answerable to someone for everything he does (or doesn't do) to the quality or to the environment).
L
LSS Master
Good points all around! This has been an ongoing debate since the Standard was released in 1987.
The original intent of the audit was to detect weaknesses in the QMS that were in need of "shoring up", to improve the effectiveness of the QMS. Now, many auditors speak about "auditing for compliance, not noncompliance".
In my personal experience as a CEO, Plant Manager, and consultant, is to view nonconformities and audit findings as opportunities to improve. Indeed, if my QMS is audited and the auditor(s) do not report any findings, I question their auditing ability - no QMS is perfect. All can be improved and I expect the auditor(s) to find ways to improve mine - what value do I receive from an audit report with no findings? I expect to obtain some value from the audit experience, which is an improved QMS!
I apologize for getting dangerously close to a lecture, there, but this subject has always "raised my Irish"!!:thanx:
Thanks for all the great ideas and opinions!!:thanks:
If I work in a molding process, then there may be some things that I don't see that someone not as involved in the process as I might detect. Moving me to a similar process may result in me still missing the same sort of things.
Q Quality Awareness 7.3 ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Quality Management-ISO 9001:2015 General Auditing Discussions 1
E Sources of every single paragraph of the ISO 9001 standards? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
B ISO 9001:2015 vs ISO 13485:2016 Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 5
I Does BSI require suppliers to be ISO 9001 Certified? EU Medical Device Regulations 12
Ron Rompen ISO 9001 Sanctioned Interpretations and FAQs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 5
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
K ISO 9001 Clause 8.3 & 8.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
H R&D Lab ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Can an ISO 9001 Certificate have Remote Locations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D ISO 9001 - 8.4.1 Evaluate All Suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
Sidney Vianna ISO 9001 News ISO 9001 Quality Check - spinning facts in LinkedIn ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A ISO 9001 Internal Audits - No production right now due to furloughs Internal Auditing 5
T Do we need an SOP for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K ISO 9001 Auditing in a Healthcare setting Process Audits and Layered Process Audits 15
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
