ISO 9001 prohibits auditors auditing their 'own work' while other standards don't?
#11
Re: ISO 9001 prohibits auditors auditing their 'own work' while other standards don't
The original intent of the audit was to detect weaknesses in the QMS that were in need of "shoring up", to improve the effectiveness of the QMS. Now, many auditors speak about "auditing for compliance, not noncompliance".
Really? Where did that come from?
My understanding has (always) been that the purpose of internal audit was to confirm for management - through a set of unbiased eyes - if the qms was being implemented,as planned. The proclivity for people to attended Lead Auditor courses since the early 1990s has corrupted this, IMHO! Lead auditor courses teach evaluation of suppliers for some form of award, in the main, be it a certificate or a PO award.
Randy
#12
Good points all around! This has been an ongoing debate since the Standard was released in 1987.
In my personal experience as a CEO, Plant Manager, and consultant, is to view nonconformities and audit findings as opportunities to improve. Indeed, if my QMS is audited and the auditor(s) do not report any findings, I question their auditing ability - no QMS is perfect. All can be improved and I expect the auditor(s) to find ways to improve mine - what value do I receive from an audit report with no findings? I expect to obtain some value from the audit experience, which is an improved QMS!
I apologize for getting dangerously close to a lecture, there, but this subject has always "raised my Irish"!!:thanx:
Thanks for all the great ideas and opinions!!:thanks:
You are so incorrect on a variety of levels. (I'll just do 2 of them)
#1...The purpose of the internal audit is most clearly stated in 8.2.2 and it is...
8.2.2 Internal audit
The organization shall conduct internal audits management system
a) conforms to the planned arrangements (see the quality management system requirements
b) is effectively implemented and maintained.
Nowhere is it stated that weakness is to be looked for. It is the detected lack of conformance when it is identified through a representative sampling process we find weakness. If our quest for weakness was the intent then I would argue at this ponit we need go no further than top management and the weakness in awareness of the requirements for their own management system which would have the potential to become pandemic across the organization
#2.... The word "finding" is also being used incorrectly....A "finding"is the result of evaluating evidence found during an audit against the criteria of the audit and could demonstrate conformance, nonconformity or opportunities for improvement...Check it out in ISO 19011:2002 . If an auditor has no "findings" then I question wheteher or not an audit was actually performed because in the end you gotta come up with something.
I'll stop before this turns into a lecture.................
#13
If I work in a molding process, then there may be some things that I don't see that someone not as involved in the process as I might detect. Moving me to a similar process may result in me still missing the same sort of things.
Then, I'd suggest that a competency evaluation - which should have been performed - needs to be revisited...
P
pthareja
#14
I agree to the fact that one should not audit one's own (quality) process but at the same time if the process does have some environmental aspects, the EMS part (but not the QMS) of this process can be audited by an auditor who is although, not independent of this process, yet demonstrates (or can demonstrate) 'objectivity & impartiality' to his/her own process.
Auditing of both QMS and EMS is covered by auditing standard ISO 19011.
In the Samsung's view, I believe, it's cognizance to metrics. If Rules and measures are defined, then one can easily distinguish between a counterfeit coin and a dime!
Priyavrat Thareja
samsung
#15
Priyavrat Thareja
19011 is a guidance document for auditing whereas requirements are prescribed by the standards and the two under discussion differ to a certain extent although they are based on the same management principles.
Still I couldn't precisely follow your second statement. :confused:
P
pthareja
#16
Priyavrat Thareja
I couldn't precisely follow your second statement.Samsung
if Rules of the game are well defined, decision taking becomes simpler:cool::cool:
amanbhai
#17
The same question I have raised during my ISO/ IEC 17025:2005 Lead auditor course. Auditing requirements are that auditor can not audit his own work.
The reason behind is that no two organizations are same, some organizations are smaller ......... there are tests which are very special and we don't have the 2nd person who could audit this specific test.
The response from the trainer was.......... the lab (organization) shall arrange internal auditor from other organizations.
samsung
#18
Though the rules (requirements) in all the standards are clearly defined yet it's 9001 only that clearly prohibits auditing our 'own work' whereas other standards clearly don't. Does it suggest one can audit one's own work relating to EMS or OHS?
Paul Simpson
#19
Are we over thinking this? All of the standards require objectivity and impartiality. Perhaps we can just ask ourselves: " Are there any situations where you are auditing your own work when you can be objective / impartial?"
FWIW my answer to the question is "No."
Dean Frederickson
#20
So I guess if we have 2 internal auditors neither of us can audit the internal audits we have completed over the past 3 years, is this right? I understand that we can't audit our own work but could I audit the audits the other auditor has completed and vice-versa?:(
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G National Structural Steel Specification 7th Edition - Do I now have to be audited against ISO 3843-3 as well as ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Sister-company providing parts is only ISO 9001 registered IATF 16949 - Automotive Quality Systems Standard 7
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G Logistic organization and controls - IATF/ISO 9001 audit Nonconformance and Corrective Action 2
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
