ISO 9001 requirement for SPC (Statistical Process Control)
PABSR
Hi everybody!
Does ISO 9001 requires a manufacturer to perform SPC (Statistical Process Control) studies as a way to demonstrate process stability? Could I demonstrate process effectiveness and stability by simply analyzing data (i.e. percent of scraps, percent of returns/rejections?
When must I use SPC including Cpk studies?:bonk:
:thanx:
Re: ISO 9001 requirement for SPC
Nope! There used to be an allusion to selection appropriate statistical techniques in the previous version of ISO 9001/2.
Are you being asked to do this by anyone (in particular)? Obviously, if you apply SPC to monitor and control a manufacturing process, it is more in line with the principles of defect prevention, on which an effective qms is supposedly based, rather than inspection of parts at the end of the process. So, really counting scrap etc. isn't truly effective, but it is a way to show effectiveness - yield is one way to do this.
Again, who's asking about this?
brahmaiah
SPC is required in ISO9001 only if it is documented so in your manuals. if a perticuler customer requires SPC as a supply condition it becomes a requirement for his supplies only.Otherwise ISO9001 does not require SPC.
v.j.brahmaiah:agree:
bobdoering
Stop X-bar/R Madness!!
Does ISO 9001 require a manufacturer to perform SPC (Statistical Process Control) studies as a way to demonstrate process stability?
No. But it can be the best way.
Effectiveness and stability? Maybe. Capability? No. But, you can do a capability study - and that does not have to be from a SPC chart specifically.
When you want to know the baseline variability of a process (Cpk) and have enough information to know when the process is not acting as expected, or when to make an adjustment (SPC). If that information is of no value to you, then you may not want to do SPC and capability studies. To me, no SPC it is like driving with a broken gas gage. You can do it, but would you want to?
What kind of processes are you dealing with? It is impossible to accurately answer questions on SPC, capability and effectiveness correctly without some idea of what processes you are dealing with. Some are straight forward - some are complicated.
Eric ng
SPC is surely a very powerful and necessary analytical tool for process capability studies and process control. This will be specified under Section: Measurement, Analysis and Improvement of ISO 9001. The 2000 version does don't specifically require you to use SPC.
Eric Ng
PABSR
Thank you all for your replies. My apologies for the delay in my comments.
We haven't been asked to perform SPC, although some customers have questioned the lack of it to demonstrate process stability. Our products are not high tech and mostly the quality is evaluated on terms of pass/no pass (attributes). One way to demonstrate process stability has been to measure the amount of seconds and scrap (%) daily, weekly and monthly (on different stages of the processes), but I don't know how much value it could add to perform SPC in this kind of processes. :) Also, I believe that SPC has to come together with a commitment to reformulate or analyse each process, but if top Managment won't allow to make big changes in the processes (even if you'd demonstrate the possible improvement) , then I believe SPC would be mostly a waste of time in this type of organization and with its current Managment.:mad:
Thank you all...I will be waiting for your comments!:thanx:
Randy
It's their time to waste and you get paid to do it, so enjoy. I know it doesn't make sense, but what other choice do you have?
bobdoering
I am glad you posed your questions to the folks here. I do want to make some notes on your comments:
Really, SPC is not something you should have to be "asked" to do, although it seems some folks only consider it when a gun is put to their head. (Well, if that is what it takes...) Anyway, it is simply a tool, similar to a chart recorder, but with statistical limits that tell you either the process is wandering off, or an adjustment is due. If your process does not have those kinds of measureables, or your process offers no adjustment, then SPC is not likely going to help you. But that should be your analysis of the process - not your customer's.
If you have no scrap, and no risk of scrap leaving your plant in shipments, then SPC may have little to add to your current controls. It may reduce your controls (if done correctly), but that may not be a problem for you.
Also, I believe that SPC has to come together with a commitment to reformulate or analyse each process, but if top Management won't allow to make big changes in the processes (even if you'd demonstrate the possible improvement)...
I do not agree that SPC has to come together with a commitment to reformulate a process. Analyze? Yes. But it is just as good of a tool to maintain the current process. Now 6 sigma will never get off the ground with your management, for sure!
...then I believe SPC would be mostly a waste of time in this type of organization and with its current Management.:mad:
Yes...this is not an uncommon problem. :rolleyes:
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Does ISO 9001 Requirement for Document Approval (a service organization) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E Disaster Contingency - Is it a requirement in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V Certified Internal auditor is necessary? ISO 9001 requirement? Quality Management System (QMS) Manuals 4
S ISO 9001 Audit requirement for maintenance department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q ISO 9001 Requirement Dilemma - Security Aspects Quality Management System (QMS) Manuals 14
O Audit Result Breakdowns by ISO 9001 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q ISO 9001 Requirement(s) for the Review of Work Instructions Document Control Systems, Procedures, Forms and Templates 11
S Is an Annual Supplier Evaluation an ISO 9001 requirement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
F ISO/CD 9001:2015 - The 6 mandatory requirement (procedures) are extend to 9 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R ISO 9001 - Requirement for Process Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
smryan Satisfying the ISO 9001:2008 4.3.2.f External Document Control requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
smryan Satisfying the ISO 9001:2008 7.3.5 Design & Development Verification requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M ISO 9001 - Requirement for Work Instructions Document Control Systems, Procedures, Forms and Templates 20
B Requirement for ISO 9001 Flow Down to Supply Chain? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N What Documents are Required for each ISO 9001 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 9001/AS9100 Requirement for Management Responsibility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J ICT Assets and ISO 9001 Clause 7.5.3 - Where Traceability is a Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Is it a requirement of ISO 9001 or ISO 22000 that a document is reviewed? Food Safety - ISO 22000, HACCP (21 CFR 120) 9
Z Job Descriptions - Are job descriptions a requirement of ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Inventory Control as an ISO 9001 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
J ISO 9001 requirement for Sequencing Operation Service Industry Specific Topics 17
A Requirement for Accredited Suppliers - ISO 9001 Clause 7.4.1 Purchasing process Service Industry Specific Topics 4
B Requirement for Review and Re-Approval of Documents - ISO 9001 Clause 4.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Configuration Management - Is Configuration Management a requirement of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N "Where traceability is a requirement" Record - ISO 9001 Clause 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
S ISO 9001:2008 Requirement to Audit 'All Shifts' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
D Customer Property Identification Requirement - ISO 9001 Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 77
B Specific requirement for Internal Auditor training in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
T ISO 9001 Clause 7.3.2 (a) Functional & performance requirement - what does it mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Design Inputs not Quantitative - ISO 9001 Clause 7.3.2 requirement Design and Development of Products and Processes 19
N Process Maps - If not a requirement for ISO 9001:2000, why bother? Process Maps, Process Mapping and Turtle Diagrams 16
Sidney Vianna Sector Specific Standards based on ISO 9001 as a baseline requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Does ISO 9001 or TS 16949 have any requirement like 777 rules for control charts? Statistical Analysis Tools, Techniques and SPC 12
M SPC is not a direct requirement of ISO 9001:2000, correct? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Miner Poll: How do you comply with the ISO 9001 requirement for Mapping Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Marc ISO 9001 Three Year Recertification Audit Requirement(s) - Complete Reaudit Registrars and Notified Bodies 6
S TS 16949 supplier certification requirement - ISO 9001:2000? Supplier Quality Assurance and other Supplier Issues 2
J No equipment maintenance requirement in ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I The certification requirement for Tier II suppliers is ISO 9001:2000 Supplier Quality Assurance and other Supplier Issues 4
E ISO 9001:2000 - Document Disaster Recovery Program Requirement? Document Control Systems, Procedures, Forms and Templates 33
A Is there a ISO 9001:2000 Requirement for Job descriptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001 Requirement Review - Beverage delivery company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2000 Section 8 - Measurment Analysis and IMPROVEMENT requirement? Preventive Action and Continuous Improvement 1
Marc ISO 9001 - Meeting the INTENT vs. Meeting the REQUIREMENT ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
Marc ISO 9001 Management Responsibility Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
