ISO 9001 Requirements for Control of Forms
Haddad9921
We are in the process of implementing ISO 9001. To start with, we have many forms that we are currently use and they are all over our production floor.
We were told that we need to control our forms. My question is;
Do we need to have form number and revision date printed on the footer of each form we are controlling? I know it is a good practice, but is it a requirement of the ISO 9001 standard under 4.2.3?
Any help will be appreciated.
Thank you
NikkiQSM
Re: ISO 9001 Control of forms
It is common practice to control documents with a number and rev level - but ISO does not require it to be controlled like that. It is up to you how you will control the documents.
The commonly used number and rev is the easiest way I have found.
Haddad9921
Does that mean that I can choose not to have any numbers at all at the footer and still control the forms?
I am just trying to find out if I have to reprint all the forms that they are out there with nothing on the footer and replace them.
Thank you
NikkiQSM
It doesnt have to be a number, but you have to have some sort of identification. The standard DOES specify that... You must identify the document. This includes identifying the version of the document (rev level).
leftoverture
Thank you
I would tend to think you do, in fact, have to reprint. If the revision is not printed on the form how will you know you're using the latest version short of reading through the whole form?
F
Frankie11
Thank you
Just change the master copy and as they run out of forms replace them with your new controlled version.
Be aware that some people like to photocopy new forms rather than go to the source so let everyone know what you're doing and why. And make it easy for them to access the new versions.
By only making the latest version available! Just like the bank notes in your pocket, you don't have to know what the latest version is, just that you have to get rid of the old ones when a new design comes out! Seriously!
leftoverture
If only it was that easy. But it has been my experience that people have forms stored in strange places and those old versions will pop out of the woodwork at the most inopportune times. As an auditor, I would definitely question the lack of revision info on the form.
What's difficult? And why, as an auditor would you question not seeing a rev on a form? It's not a requirement! You have to dig deeper than the superficial appearance of a rev number on a form to determine if document control is effective.
leftoverture
Indeed. But forms become quality records and often forms have instructions on them. So depending on what I see in any particular instance, I may need to understand if it is the correct form to understand if the applicable process is being followed. It could also be that the form is used to document process settings, and an incorrect revision form may not be consistent with the current process.
Remember that document control is about having the correct information available at the point of use. An outdated or incorrect form could mean that requirement is not being met. I would reference these excerpts of the standards:
4.2.3: Documents required by the quality management system shall be controlled.
c: to ensure that changes and current revision status of documents are identified
d: the ensure that relevant versions of applicable documents are available at the point of use
4.2.4: Records shall remain legible, readily identifiable, and retrievable.
That is how I see it. Always subject to interpretation, but in this case I would say it depends on the particular form and what it is used for.
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N ISO 9001:2015 Customer Complaints Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G ISO 9001 8.4 applied to 7.1.3 - Suppliers of infrastructure requirements - IT and Print solutions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G ISO 9001 Legal Compliance and Legal Register Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E ISO 9001:2015 - Record requirements for out of calibration tool ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
K ISO 9001 Requirements for Raw Material Supplier Assessment and Approval ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod ISO 9001:2015 8.5.1 f - Scope with customer special process requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P ISO 9001:2015 Supplier Certification Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J ISO 9001:2015 8.2.3 - Review of Requirements (Clarification on compliance) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Crusader Training Requirements for ISO 9001:2015 Training - Internal, External, Online and Distance Learning 10
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
S ISO 9001:2015 Clause 8.2.1 e) - Requirements for Contingency Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A ISO 9001 Ergonomics and Manual Handling Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Organizational Knowledge Requirements - Meeting ISO 9001:2015 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 60
Moncia All the risk assessments - ISO 9001:2015 requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A 6 Requirements for an ISO 9001:2015 Transition Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
T ISO 9001 Calibration Requirements General Measurement Device and Calibration Topics 27
A Is the Labour Code one of the legal requirements of ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Do ISO 9001 and ISO 13485 have requirements for Shelf-Life? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
P ISO 9001 Requirements for ISO 17025 Accredited Calibration Laboratory ISO 17025 related Discussions 5
N Work Environment - ISO 9001 Clause 6.4 vs. OSHA Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Gman2 Internal Auditing Requirements before ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001:2015 vs. FAA, CASA, PNG 173 Requirements Federal Aviation Administration (FAA) Standards and Requirements 11
T Customer Specific Documents and Records - ISO 9001 Control Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L ISO 9001 Operation Process Control Requirements ("Carta de Control de Proceso") ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Question re: Meeting the Requirements of ISO 9001 Clause 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Product=Service in ISO 9001 and ISO 9001 Requirements vs. TS16949 Requirements IATF 16949 - Automotive Quality Systems Standard 2
R Requirements for Product Related Emails - ISO 9001 Clauses 7.3.4 and 4.2.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H ISO 9001 Document Control Requirements - Design and Development Department Checklists Document Control Systems, Procedures, Forms and Templates 3
C ISO 9001 Record Control Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Auditor transition requirements for ISO 9001:2008 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 7
S ISO 9001 - Training Record Content Requirements Training - Internal, External, Online and Distance Learning 5
D ISO 9001 documentation requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
O ISO 9001 requirements for what Internal Audits must cover Internal Auditing 7
W ISO 9001:2008 Purchasing Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B On The Job Training (OJT) requirements in ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Requirements to become an ISO 9001 Lead Auditor Internal Auditing 8
B Internal Audit Requirements for ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Interpretation of ISO 9001 Clause 7.2.1 Development Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N ISO 9001 Applicable Requirements for a Company Website? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
J Quality Records Register Requirements - ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 31
Y Can we obtain ISO 9001 if there is only 1 person that understands the requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K How do ISO 9001 Requirements apply to 2 sets of specifications to 2 separate vendors? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S ISO 9001 Recertification Audit Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
