ISO 9001 requirements for what Internal Audits must cover
O
onestout
I searched and couldn't find what I was looking for so if there is already a thread on this I apologize.
Does ISO have any requirements on what must be audited? as in do they state the points that must be audited, all of them?
This may be to vague but I thought this would be a good start, if this has been covered before could you point me in the right direction? Thanks
Michael
insect warfare
QA=Question Authority
Re: Internal Audit question
Strictly speaking ISO 9001:2008, all sections of clauses 4 thru 8 are "auditable". Clauses 1-3 are information only.
The standard also allows an organization to claim specific exclusions from section 7 (Product Realization). The requirement here is that any exclusions, along with details of, and any justifications, must be stated in your quality manual per 4.2.2(a).
Also refer to paragraph 8.2.2 (Internal Audit).
Brian :rolleyes:
bluepagen
Hi, in answer to your question, you have to audit to be sure your system meets the requirements of the standard and any additional requirements that may be stated in your procedures.
I would suggest you look at the top of the page, between the light house and lightening strike for the free attachments and the post attachments. These are listed alphabetically and you can check for internal audit checklists, there will be many, and in multiple standards. If you need quality, 14001, automotive standard, medical standard, multiple checklists will show up. You will be able to see what some of the others in the cove are looking for.
Hope this helps. Try the search. If you have troubles finding anything, email me and I will try to assist further. Good luck.
insect warfare
Re: ISO requirements for what Internal Audits must cover
Michael
You can also try these search results. Happy hunting...
Brian :rolleyes:
Michael
Michael- you have to audit your management system, based on status and importance. If you find something about your management system, you can extrapolate to ISO 9001. So, for example, if you are auditing the manufacturing shop floor, and you find a number of drawings or specs which aren't the correct issue, or work instructions which have been redlined without approvals,then it should be easy to see that document control is an issue and that's a requirement of ISO 9001. Or, if you find someone on second shift has been hired and they tell you no-one has spent any time with them determining is they can do the job correctly (and their supervisor confirms this), then you can confirm the process and also than ISO 9001 requires competent people...
Simples!
ssz102
generally speaking: what have you done during established QMS, you can audit what these contents or documents and records
O
onestout
thanks for the info, that is what I thought. I also need to edit our manual to exclude the design clause, we don't design at our facility, that's done in a different plant. Thanks
somashekar
Go straight to the descriptions of the interaction between the processes of your quality management system, as you have made in your quality manual (see ISO9001:2008, clause 4.2.2)
Your internal audit must address all those processes, as well as how they are interacting.
So a good and complete capturing of your processes and interactions is a good lead for your internal audit programme.
Can you see how your internal audit process here is interacting with your quality manual ... ???
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N ISO 9001:2015 Customer Complaints Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G ISO 9001 8.4 applied to 7.1.3 - Suppliers of infrastructure requirements - IT and Print solutions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G ISO 9001 Legal Compliance and Legal Register Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E ISO 9001:2015 - Record requirements for out of calibration tool ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
K ISO 9001 Requirements for Raw Material Supplier Assessment and Approval ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod ISO 9001:2015 8.5.1 f - Scope with customer special process requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P ISO 9001:2015 Supplier Certification Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J ISO 9001:2015 8.2.3 - Review of Requirements (Clarification on compliance) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Crusader Training Requirements for ISO 9001:2015 Training - Internal, External, Online and Distance Learning 10
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
S ISO 9001:2015 Clause 8.2.1 e) - Requirements for Contingency Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A ISO 9001 Ergonomics and Manual Handling Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Organizational Knowledge Requirements - Meeting ISO 9001:2015 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 60
Moncia All the risk assessments - ISO 9001:2015 requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A 6 Requirements for an ISO 9001:2015 Transition Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
T ISO 9001 Calibration Requirements General Measurement Device and Calibration Topics 27
A Is the Labour Code one of the legal requirements of ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Do ISO 9001 and ISO 13485 have requirements for Shelf-Life? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
P ISO 9001 Requirements for ISO 17025 Accredited Calibration Laboratory ISO 17025 related Discussions 5
N Work Environment - ISO 9001 Clause 6.4 vs. OSHA Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Gman2 Internal Auditing Requirements before ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001:2015 vs. FAA, CASA, PNG 173 Requirements Federal Aviation Administration (FAA) Standards and Requirements 11
T Customer Specific Documents and Records - ISO 9001 Control Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L ISO 9001 Operation Process Control Requirements ("Carta de Control de Proceso") ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Question re: Meeting the Requirements of ISO 9001 Clause 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Product=Service in ISO 9001 and ISO 9001 Requirements vs. TS16949 Requirements IATF 16949 - Automotive Quality Systems Standard 2
R Requirements for Product Related Emails - ISO 9001 Clauses 7.3.4 and 4.2.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H ISO 9001 Document Control Requirements - Design and Development Department Checklists Document Control Systems, Procedures, Forms and Templates 3
H ISO 9001 Requirements for Control of Forms Document Control Systems, Procedures, Forms and Templates 24
C ISO 9001 Record Control Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Auditor transition requirements for ISO 9001:2008 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 7
S ISO 9001 - Training Record Content Requirements Training - Internal, External, Online and Distance Learning 5
D ISO 9001 documentation requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W ISO 9001:2008 Purchasing Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B On The Job Training (OJT) requirements in ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Requirements to become an ISO 9001 Lead Auditor Internal Auditing 8
B Internal Audit Requirements for ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Interpretation of ISO 9001 Clause 7.2.1 Development Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N ISO 9001 Applicable Requirements for a Company Website? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
J Quality Records Register Requirements - ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 31
Y Can we obtain ISO 9001 if there is only 1 person that understands the requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K How do ISO 9001 Requirements apply to 2 sets of specifications to 2 separate vendors? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S ISO 9001 Recertification Audit Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
