ISO 9001 Section 7.6 - Customer has supplied torque specifications
StevePenney
I was just wondering if a company was using cheap uncalibrated torque wrenches to assemble customer product would it be considered a major non-conformance under ISO 9001:2008 Section 7.6? Assume the customer has supplied torque specs. I believe it is, others disagree. What do you think?
Is it a major, minor non-conformance, or really not necessary.
ScottK
Not out of the crisis
Did the customer provide an application or removal torque specification?
I was in bottle making and filling for years and removal torque was the important thing, so application torque heads were never calibrated. The removal torque tester was.
pkost
It is certainly a non conformance. There are many discussions here about the difference between major and minor, but I would probably rate this as a major as it cannot be adequately be determined that the correct torque is being set and therefore the product may be out of spec.
edit: ScottK is right and my answer was not clear enough...the fundamental question is "can it be demonstrated that the product in in specification"
ScottK
The torque specs would be for tightening.
Steve
In that case I would agree with you that the tool used for applying the torque is measurement equipment and should be calibrated... or possibly verified on a shift/day basis with a calibrated tool with records kept of the verification. That way you don't have spend a lot on a calibration but can maintain traceability to a standard.
As to degree of nonconformity... that depends on your system. For internal audits I tend not use Critical/Major/Minor since a nonconformity is nonconformity.
Many of my customers do, however.
I think many of those customers would consider this a Major if there is little history of complaints about this characteristic. If there is history of complaints then it would be critical.
Sorin
Steve
In that case it would be a major. What's there to debate? We have customer requirements and unable to provide proof that we comply with them because wrench(es) are not calibrated and thus unable to make proof of a controlled process.
Jeff Frost
It could very well be a major finding if it indicates a major failure of your process associated with clause 7.6. Here are a few questions to ask:
Does my organization understand the requirements of Clause 7.6 as it applies to measurement and test equipment?
Though Clause 7.6 relates to assuring both process equipment and inspection instruments are accurate is may company only applying it to inspection instruments?
What within my process allowed this wrench to be used when the customer specified a requirement I must meet?
What other equipment within my system should be calibrated or verified that has not been?
H
haithamae
according to clause no 7.6 ISO 9001:2008 the measuring equipments should be calibrated so, is it required to calibrate avometers and multimeters.
and if yes, what is meant by (where necessary ) which mentioned in that clause.
is it means it is not mandatory, waiting for your esteemed feedback
The standard says that calibration is necessary "Where necessary to ensure valid results..." This means that you have to consider, for each relevant device or device type, the risks presented by not calibrating. There are some people, including some auditors, who believe that the clause means that everything in sight must be periodically calibrated whether it makes any sense to do so or not. If you have production measurement devices that you chose not to include in your calibration program, you will need to be able to rationally justify the choice.
howste
Thaumaturge
I agree with Jim. The standard says "Where necessary to ensure valid results..." Using uncalibrated torque wrenches may be acceptable if the torque process is validated at a frequency sufficient to give confidence that the torque applied is good. If there is no other method to "ensure valid results" then it's definitely a nonconformity. In the aerospace or automotive industries, because of they way they define the term, it would be considered major.
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Relevant internal and external communication - ISO 9001:2015 section 7.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Applicability of ISO 9001:2015 Section 8.5 - Engineering company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001, section 4.3 Determining the scope of our QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 Section 7.6 - Computer Software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K ISO 9001:2015 Section 8.5.3 - Property belonging to customers or external providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K ISO 9001 Section 7.3 Design and Development Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Exemption from Section 7 clauses of ISO 9001 - Scientific Research Company Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L ISO 9001 Section 6 - Human Resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R ISO 9001:1987 or 1994 - Wording of Purchasing in section 6.0 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
H ISO 9001 Section 7 when you don't manufacture anything? Service Industry Specific Topics 6
T Updating to ISO 9001:2008 - I need to add section 7.3 Design and Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
I Clarification of ISO 9001: 2008 Section 7.6 - Monitoring and measuring equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K No Formal Design Process - Audit Finding - Help with Section 7.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
G Can a testing laboratory exclude section 7.3 of ISO 9001? Quality Management System (QMS) Manuals 2
D ISO 9001:2000 Checklist for Auditing Personnel/HR section Internal Auditing 12
M Confused about measurement of software - Section 7.6 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Plug Gage Calibration Report does not include actual data - ISO 9001:2000 section 7.6 General Measurement Device and Calibration Topics 3
T Addressing ISO 9001 Section 7 in the Quality Manual when Design is Excluded Design and Development of Products and Processes 6
Q Training Records - Proof of "training" per ISO 9001 section 6.2.2 (b) Records and Data - Quality, Legal and Other Evidence 33
U ISO 9001:2000 Section 1.0 Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S ISO 9001 Section 7 Requirements - Contract assembly ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A Need help with section 7.5 of ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Differences in ISO 9001:2000 Section 8.3 vs. ISO13485:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Nuclear - ASME Section III N-Stamp - Requirements over and above AS9100 and ISO 9001 Various Other Specifications, Standards, and related Requirements 12
T ISO 9001:2000 Section 8 - Measurment Analysis and IMPROVEMENT requirement? Preventive Action and Continuous Improvement 1
C How to to become an ISO 9001:2015 consultant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A QMS Roll out with guidance from ISO 9001 Quality Management System (QMS) Manuals 8
C Computerized System Validation in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Experience Records - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A ISO 9001 & API Q1 Approved Supplier/Sole Agent ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Matrix to determine what's needed to create a QMS v ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Integrating ISO 9001:2015 audits with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO 9001: 2015 MR Outputs - "any need for changes to the quality management system' Management Review Meetings and related Processes 13
L ISO 9001, 14001, 45001 Audit Questions for a Security & Corporate Affairs Department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
giavannatabbs ISO 9001:2015 Control of Records - QMS Communications? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H ISO 9001:2015 - 8.5.1 - Routers not being signed Manufacturing and Related Processes 9
Q Documented information ISO 9001:14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Is there a mandatory requirement to notify customers of the complaint resolution in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J ISO 9001:2015 Document Revison History ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q KPI rules for ISO 9001 first certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
Sidney Vianna Tesla Lacks Major Automotive Quality Certifications such as IATF 16949 and ISO 9001 IATF 16949 - Automotive Quality Systems Standard 15
Cats Clause ISO 9001 - verification of Tape Measures and Steel rules ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
S ISO 9001 Quality Management System and its processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
M Preservation of Raw Materials in ISO 9001:2015 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Assignment on the link between Quality Gurus & ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
jeancloude17 Advice for ISO 9001 for software Design and Development of Products and Processes 2
