ISO 9001 Surveillance Audit Nonconformance - Thermometers not Calibrated
Chance
Hi Covers,
We had a ISO 9001 surveillance very recently. Everything went very well except that the auditor said that our temperature readings taken from our system is not validated against a certified thermometer.
My question is, is it possible to calibrate a thermometer? If yes, how?
Also, there is no regulatory requirement nor ISO requirement that dictates that we have to do it.
ISO 9001 says that where necessary, to ensure valid results, we have to calibrate equipment.
Should I dispute his finding?
Stijloor
Re: ISO 9001 Surveillance - Thermometers not calibrated
What is purpose of the thermometers? Are they used to control a process or verify product specifications?
Stijloor.
Chance
Stijloor.
The thermometers are just used to verify that our temperature system is displaying the right temperature readings intended for a specific area. For example if the temperature system is suppose to maintain a certain area at 70 degrees, we validate that room temperature if it is maintaned at 70 degrees. Please comment. Thanks.:agree:
Chance
Our thermometer is use to verify that the temperature system is providing the temperature that we want. It is like you buy a thermometer at home to check if your thermostat is working as intended.
We use 2 separate device to make sure that both are displaying accurate readings. The auditor want us to buy another one that is certified as accurate. I believe its an overkill.
Stijloor
Are the thermometers essential for controlling a process and/or verifying product specifications?
These are important criteria for inclusion in a formal calibration system.
We can not answer your question based on your 2 previous posts. :confused:
Stijloor.
Ninja
Looking for Reality
Hi Chance,
This question is separate from your other and is easier.
Yes it is possible, but may require you to get a different temperature gage than what you are using now.
We use a digital temperature gage (cheapie from Cole Parmer) and have it calibrated by the same company that does our mics, calipers, etc. They won't do a glass/mercury or glass/whatever liquid type, but the electronic ones they do.
As to whether you NEED to have it done, the questions above are on point...is it part of validation or process control, or just a 'nice to know' data point?
Hi Covers,
If calibration isn't necessary to ensure valid results (for whatever the temperature readings are used for) you don't have to calibrate. I'm wondering, though, why this temperature business is documented as a requirement in your QMS. What happens if the temperature is 75°?
Sidney Vianna
Post Responsibly
:agree1: Or 65[sup]o[/sup]? Instead of simply asking if ISO 9001 requires this or that, we should put our thinking caps on and ..... think!
Currently, there are two non-calibrated gages providing a temperature reading! If I were the auditor, I would be thinking: this must be somewhat important; otherwise, why have a redundant temperature reading system? So, if it is important, the temperature reading should be reliable. In order to be reliable, I should have the thermometer (or gage) calibrated; if not, how can I trust the reading?
But the basic question is what Jim asked. What would be the impact to product conformity (if any) if the temperature was off by 2, 3, 5, 10 degrees? Until THAT question is answered, we are just speculating here.
Chance
Stijloor.
Controlling the process? NO. It is only use to verify whether our temperature system is working as intended ex: 70 degrees +/-5. Whatever is inside the controlled temperature area, does not go to our customer, no effect to our end products.
Chance
Our thermometers are not part of a process control. It is just for a nice to know data point to have.:agree:
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
K Bi-Annual ISO 9001 Surveillance Audit Help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
R Frequency of ISO 9001 Surveillance Audit after Recertfication Audit General Auditing Discussions 2
H ISO 9001:2008 Surveillance Audit Frequency Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
J ISO/AS Surveillance Audit - Minor for not updating my QA Manual to ISO 9001:2008 Quality Management System (QMS) Manuals 95
M When is the ISO 9001 Surveillance Audit? Certification process for ISO9001:2000 General Auditing Discussions 4
P Is it necessary to undergo the ISO 9001 surveillance audit before going for TPM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
L Surveillance Audits for ISO 9001:2000 - defined intervals ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Need Advise on upcoming ISO 9001:2000 Surveillance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Need suggestions for Top Management Preparedness for ISO 9001 surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
Claes Gefvenberg An interesting audit coming up - First combined ISO 9001 / 14001 surveillance audit General Auditing Discussions 6
CarolX Surveillance Audits under the ISO 9001:2000 version Registrars and Notified Bodies 8
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 2
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
