ISO 9001 Surveillance Audit Nonconformance - Thermometers not Calibrated
Chance
#91
Ah... didn't know you have 13 of these. That makes the economics different.
Whatever accuracy you feel you need the instruments in the freezer rooms, then you want a standard that is sufficiently more accurate than those. So in general, if you are going to have them at +/-°F, then your standard needs to be 1°F; and, it should be reliable and repeatable.
So I would invest a couple of hundred in a decent instrument. Set it for one year interval. Since these are freezers, I would get an extension long enough for the probe, where the meter sat outside the chamber. I would perform a once a month verification on the rooms/thermometers, and log on a sheet you keep by the rooms.
Brad, I found one thermometer for 50 dollars. According to the manufacturer, it is portable I can carry it from room to room with +/- 1 degree C accuracy, more accurate than my internal procedure (+/- 3 degrees C). It also comes with a certificate traceable to NIST.
According to the manufacturer, usually this is the kind used by others who do stuff like we do.
The good thing about this is that, the acclaimation time is within seconds. That means if I bring it in one room it detects/stablilize and will give the accurate reading within seconds.
Chance
#92
If my internal procedure accuracy is +/-3 degrees C, should I get a new and calibrated thermometer with 1 degree or 0.5 degree accuracy? According to Brad, I should get a 1 degree accuracy. Why would I get a 1 degree accuracy and not 0.5 degree. Thanks.
BradM
#93
How much will that unit cost you for re-certification? That needs to figure into the equation. :)
If your instrument accuracy is 3 degrees, then you should get a thermometer with .5°F accuracy. You are going to have some uncertainty given the testing environment, so you need as much accuracy as you can afford.
I know you are watching your dollars. But... I would think you should look at spending a couple of hundred on a decent instrument. Also, you will probably want to keep two of them, so you can keep them staggered while one is out for calibration.
Big Jim
#94
At $50.00 for a new one with certs, why would you send it out? Just buy a new one.
Chance
#95
I thought +/- 1 degree is acceptable.
BradM
#97
You can, but how do you know the previous ones were in tolerance?
There are all kinds of ways to cut the cake. :D I just prefer to have confidence in my calibrating instruments. Otherwise, if something changes in the process, you end up second-guessing everything, including the standard.:)
Golfman25
#99
What kind of climate control system do you have that can keep a room +/- 3 degrees? Seems kind of tight to me.
BridgeGap
Respectfully, I think the question has been answered and the discussion is getting into management's thought process. Clearly they have determined the temperature to be an important process variable. The thermometer should be calibrated. Reasons have already been cited.
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
K Bi-Annual ISO 9001 Surveillance Audit Help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
R Frequency of ISO 9001 Surveillance Audit after Recertfication Audit General Auditing Discussions 2
H ISO 9001:2008 Surveillance Audit Frequency Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
J ISO/AS Surveillance Audit - Minor for not updating my QA Manual to ISO 9001:2008 Quality Management System (QMS) Manuals 95
M When is the ISO 9001 Surveillance Audit? Certification process for ISO9001:2000 General Auditing Discussions 4
P Is it necessary to undergo the ISO 9001 surveillance audit before going for TPM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
L Surveillance Audits for ISO 9001:2000 - defined intervals ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Need Advise on upcoming ISO 9001:2000 Surveillance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Need suggestions for Top Management Preparedness for ISO 9001 surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
Claes Gefvenberg An interesting audit coming up - First combined ISO 9001 / 14001 surveillance audit General Auditing Discussions 6
CarolX Surveillance Audits under the ISO 9001:2000 version Registrars and Notified Bodies 8
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
