ISO 9001 Surveillance Audit Nonconformance - Thermometers not Calibrated
Golfman25
#31
Do you have the room temp. standard documented? Does it say somewhere that the room has to be kept to 70 +/- 5? Are the room temps. documented each day, week, or month? If so, I can see why your auditor might want calibration. Maybe you can change your requirement to reference 70 degrees. Sounds to me like calibration would be overkill, but you might need to pick you battles on this one. Good luck.
BradM
#32
We have a building control system which monitors all building operations like lights, temperatures, doors, etc.
It is monitored.
Like I said Chance, I might have some verification done on it every so often so you can prevent nuisance alarms, or a situation when it should have alarmed but didn't. Other than that, I wouldn't worry about it.
Chance
#33
NO. My QMS only say" monitor the XX room storage. Current condition is 70 degrees +/- 5. It does not indicate that it "shall be 70 degrees +/-5".
They are just there so we can visually observe the temperatures in the room. The thermometers are read and observed every time the storage guy enters the room, not recorded however. The thermometers are not used as a definitive measurement, it is used as a check.
Exactly, that is why I bring this up here. I will have my closing meeting with him next week. I need to make sure I pick a good :mad:.
#34
Re: ISO 9001 Surveillance - Thermometers not calibrated
The reason why we have to set a certain temperature limit ex: not to exceed 70 degrees +/- something is because if we let these materials set in a very hot temp ex: 100 degrees, over time, it may become worthless...
So, if your temperature monitoring devices are not accurate you could end up throwing away money.
These materials are used for product development, like used for pilot runs. If these materials are being exposed to temperature outside tolerance, it would still be okay as long as it is not for months time of exposure...
Product development processes should be controlled according to ISO9001. I have been involved in design projects (plural) where the designers arrived at incorrect conclusions about their verifications due to glue that didn't hold parts together (expiry date passed), potting compounds that didn't set properly (material settling, no barrel rotation as required), and even bad solder joints (tin oxide preventing good joints on lead free bolts not stored in a sealed container as required).
The old Covers know that I'm all about avoiding needless calibration. In this case, though, I think I'd buy one decent digital thermometer and get it validated (just checked for accuracy) or calibrated (physically tweaked to best accuracy and precision) on an annual basis.
Chance
#35
We don't take responsibility of verifying false alarms because we contracted that with third party. The facility guy receives alarm everytime that happens. If we do verification, we overkill the process. It's like when you have your car serviced, you don't verify the service guy's process.
Chance
#36
So you want me to buy one thermometer that is calibrated even if we don't have that requirement. What is my nonconformity against what if I don't?
#37
You have a requirement for Preservation of Product, 7.5.5. Even if said materials are not going to ship to a customer, if you are making decisions based on the performance of those materials as part of Design and Development Verification or Validation, 7.3.5 & 7.3.6, I'd say you have something to address.
Do you not validate your designs with controlled measuring devices?
BradM
#38
I am too.
And needless instrumentation/equipment. :D
I am continually questioning calibrations before they occur. Hey... where did you find this? Has it been used since your last calibration? Has anyone used it? Is there ever any error when you check it? Blah.. blah blah. There's stuff being removed all the time, put in storage, sold, reassigned, etc. But someone needs to be continuously looking at the process(es) and seeing what is needed. If this is being done, only needed equipment will be there. And that needed equipment, should be verified.
Needless calibrations cause prices to go up, and frankly, isn't much fun. That precious money can be spent elsewhere, like procuring redundant standards and instrumentation to perform in-house verification, when needed.
harrysons
Realistic Quality
#39
The process does not involve anything related to FDA. The process does NOT require tight/precise readings. We just don't want the room to be so hot like 100 degrees. And if the temperature goes up like 100 degrees,it automatically sends an alarm to our facility guy. So yes, the thermometer is just a fancy thing that we have in there.
hi chance,
my undestanding, thermometer is using to read the temperature on your storage room or certainly area. this seem like the control the temperature over the product requirement, Is it your thermometer related to "6.4 Work Environment?" if not related and unnecessary to used and you might be able to remove it. that's only my opinion. :rolleyes:
qusys
#40
Hi Chance,
I read now the post about this argument.
I would like to know what countermeasures you have in place, if any, if the temperature of the room is not what you expect.:bigwave:
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
K Bi-Annual ISO 9001 Surveillance Audit Help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
R Frequency of ISO 9001 Surveillance Audit after Recertfication Audit General Auditing Discussions 2
H ISO 9001:2008 Surveillance Audit Frequency Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
J ISO/AS Surveillance Audit - Minor for not updating my QA Manual to ISO 9001:2008 Quality Management System (QMS) Manuals 95
M When is the ISO 9001 Surveillance Audit? Certification process for ISO9001:2000 General Auditing Discussions 4
P Is it necessary to undergo the ISO 9001 surveillance audit before going for TPM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
L Surveillance Audits for ISO 9001:2000 - defined intervals ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Need Advise on upcoming ISO 9001:2000 Surveillance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Need suggestions for Top Management Preparedness for ISO 9001 surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
Claes Gefvenberg An interesting audit coming up - First combined ISO 9001 / 14001 surveillance audit General Auditing Discussions 6
CarolX Surveillance Audits under the ISO 9001:2000 version Registrars and Notified Bodies 8
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 2
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
