ISO / IATF 16949 Requirements for Second Party Services
Azaarus
Hi. Long time lurker, first time asking a question.
I work in quality at a certified IATF 16949 / ISO 9001: 2015 plastic injection molding company. Our annual IATF audit is coming up and we are doing some prep work.
We send our scrap parts out to a second-party for repelletization (basically recycling), then they bring it back to us. The scrap we send is quarantined by material type.
The second-party is NOT IATF/ISO certified. Since they are providing a service to us, shouldn't we be able to perform a second-party audit to continue using their services, or has that changed? There have been many different discussions on how to proceed with this, but we are at a stand still because no one seems to know! If anyone can answer this or direct me to where I can find an answer, please reply.
I have the newest Sanctioned Interpretations, but we are still unclear.
Golfman25
They don't have to be certified. In the standard it shows the steps to take for "supplier development." And to boot, they have no affect on product conformity.
Rameshwar25
the SI is for scrap material suppliers and not for said services.
you need to follow all requirements of 8.4.2.3 (supplier development) and also to conduct second party audits ONLY IF if you reuse the material received from your supplier for further manufacturing of product (like recycling).
if quarantined material is further sold out as scrap, you can waive off.
Sebastian
Please read FAQ#11 https://www.iatfglobaloversight.org...018/11/IATF-16949-FAQs_Oct-2018_12Nov2018.pdf
Rendering of nonconforming parts before disposal is a process. Manufacturing site may decide to outsource this process to service provider.
It shall be identified within organizational system documentation as outsourcing, then all requirements related to supplier selection, control and development shall be implemented. Due to eligibility limitations target QMS development level for service supplier can't be IATF 16949, but ISO 9001 should be enough.
In case of doubts it is example of 8.4.1 c).
Sidney Vianna
Post Responsibly
How so? If the repelletized plastic is used as raw material, it sure can affect product conformity. The level of approval for this supplier should be, at least, the same for raw material; maybe even more because a recycled material might impact product properties even more, depending on the percentage of recycled pellets being used.
Golfman25
They are simply changing the form of the materials - from molded parts and runners to regrind. Most molders do it right at the press. The pct regrind to use would be set by the material manufacturer's recommendation and the molder.
eule del ayre
mr. sidney is right, it depends on the percentage of the recycled pellets, if the ratio is 3:2 in favor of recycled if you're company is reducing the cost, there's a right certificate for recycled plastic.
UncleFester
You should assess the requirements for supplier selection dependent upon the risk to your business, as in Cl. 8.4.1.2.
Cl. 8.4.2.3 permits the first stage as compliance to ISO9001 by 2nd party audit. Compliance is not the same as certification, which would be the next step in supplier development.
If you have assessed your suppliers by risk as in 8.4.1.2a, and there is the need for the raw material supplier (of the new plastic pellets, not recycled waste) to have ISO9001 certification, then there may be a similar requirement for your waste recycler.
Golfman25
Actually, this is a case to use the "unless otherwise approved by the customer" out. If all they are doing is regrinding the OPs scrap and returning it, the risk is low. As long as they are keeping track and not contaminating the regrind is there really a need for the complexity of ISO?
Azaarus
Yes, you are correct. We are using the material when they send it back as regrind, and the appropriate percentage (usually it is 20%) is being used.
Thank you!
Sidney Vianna Tesla Lacks Major Automotive Quality Certifications such as IATF 16949 and ISO 9001 IATF 16949 - Automotive Quality Systems Standard 15
W Looking for IATF 16949 (and ISO 17025) QMS software Suggestions Quality Tools, Improvement and Analysis 8
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 7
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
S Necessity of Legal Register to conform to ISO 9001, ISO 14001, IATF 16949 ISO 14001:2015 Specific Discussions 6
bettsaj IATF 16949 manufacturing cell in ISO 9001 factory? IATF 16949 - Automotive Quality Systems Standard 15
Coury Ferguson Report the CB... Certification Audit (IATF 16949) not to ISO 17021 Registrars and Notified Bodies 3
eule del ayre IATF 16949 / ISO 9001:2015 audit criteria IATF 16949 - Automotive Quality Systems Standard 17
xfngrs How similar or different are IATF 16949 Vs. ISO 13485 IATF 16949 - Automotive Quality Systems Standard 0
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
J 3 Questions about Management Review - ISO 9001 and IATF 16949 Management Review Meetings and related Processes 4
QMMike ISO (in search of) IATF 16949 vs. TS 16949 changes summed up IATF 16949 - Automotive Quality Systems Standard 7
Cats Clause Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
F IATF 16949 - Cl. 8.4.2.3 - Which type of suppliers could be exempt of ISO 9001 IATF 16949 - Automotive Quality Systems Standard 16
K Top Executive Management ISO 9001:2015 and IATF 16949 Overview IATF 16949 - Automotive Quality Systems Standard 4
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
Anerol C IATF or ISO TS 16949 rules about Scope of QMS IATF 16949 - Automotive Quality Systems Standard 7
B Rules for Achieving IATF Recognition: 4th edition for ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 97
F ISO/TS16949 (to become IATF 16949:2016) alignment to ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 79
S ISO/TS 16949 IATF Rules: 2.9 Management of Impartiality IATF 16949 - Automotive Quality Systems Standard 8
J Certification Scheme for ISO/TS 16949:2002 - Rules for achieving IATF Recognition IATF 16949 - Automotive Quality Systems Standard 4
automoto Requirements of certification bodies recognized by IATF for ISO/TS 16949:2002 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 12
Sidney Vianna Ten CB's have had their IATF contract terminated - ISO/TS 16949:2002 Registrars and Notified Bodies 3
Icy Mountain IATF Guidance to ISO/TS 16949:2002 - Not auditable? IATF 16949 - Automotive Quality Systems Standard 16
Marc IATF SIGNIFICANTLY Changes ISO/TS 16949:2002 'Rules' ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 5
H IATF approved vs. ISO 9001 / TS 16949 Auditor Requirements IATF 16949 - Automotive Quality Systems Standard 11
A Rules for Achieving IATF Recognition - A Second Edition for ISO/TS 16949:2002 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 10
T IATF Guidance to ISO/TS 16949:2002 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 10
R Do I need to get calibration certificate from ISO 17025 for IATF Audit IATF 16949 - Automotive Quality Systems Standard 8
malasuerte Resourcing for ISO and or IATF? IATF 16949 - Automotive Quality Systems Standard 0
D "certified" in ISO 19011, as well as IATF required? IATF 16949 - Automotive Quality Systems Standard 6
G Logistic organization and controls - IATF/ISO 9001 audit Nonconformance and Corrective Action 2
P Are red non-conformance bins required anywhere in the ISO or IATF standards? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K What is IATF equivalent of "ISO Coordinator" IATF 16949 - Automotive Quality Systems Standard 4
M Anyone Dropping IATF and going back to ISO ? IATF 16949 - Automotive Quality Systems Standard 18
H ISO/IATF Internal Auditor Recommendations For Manufacturer In California, USA Internal Auditing 3
