ISO/IEC 17025:2017 3rd Ed. Changes from 2nd Ed.
Douglas E. Purdy
"This third edition cancels and replaces the second edition (ISO/IEC 17025:2005), which has been technically revised.
The main changes compared to the previous edition are as follows:
— the risk-based thinking applied in this edition has enabled some reduction in prescriptive requirements and their replacement by performance-based requirements;
— there is greater flexibility than in the previous edition in the requirements for processes, procedures, documented information and organizational responsibilities;
— a definition of “laboratory” has been added (see 3.6)."
I do not know the ISO/IEC Directives, Part 1 & 2 Directives and Policies but I wonder if the above changes as given in the Forward would 'pass mustard' in dealing with document / revision control. If this is the Example by ISO/IEC and CASCO, then I don't think I would be expecting much in regards to 8.2.3 c).
ISO/IEC 17025:2017
"8.3.2 The laboratory shall ensure that:
a) documents are approved for adequacy prior to issue by authorized personnel;
b) documents are periodically reviewed, and updated as necessary;
c) changes and the current revision status of documents are identified;
d) relevant versions of applicable documents are available at points of use and, where necessary, their distribution is controlled;
e) documents are uniquely identified;
f) the unintended use of obsolete documents is prevented, and suitable identification is applied to them if they are retained for any purpose.
dwperron
I'm really not sure what you are driving at here.
8.3.2 says that changes and revision status of documents are identified. How your organization chooses to accomplish it is based on what you need for controls, and what risk it presents. Simple and straightforward.
The 17025:2005 covers this in section 4.3.3. That throws in many requirements on how to control a document:
* Changes shall be reviewed and approved by the same function that performed the original review...
* altered or new text shall be identified in the new document...
* amendment of documents by hand....
* procedure to describe how changes in documents in computerized systems are maintained...
Some of these "requirements" are outdated. Few add value to the process.
The new edition moves away from these "prescriptive requirements", we are now given flexibility to determine our own best practices.
Would this "pass muster" under the old system? No.
That's why we needed a new system.
Douglas E. Purdy
Thanks for catching my mistake on the idiom!
What I mean is that the Forward indicated a change where the Term 'laboratory' was defined. In actuality the 3rd Ed added 9 Terms, of course 6 of those have 'Source' referenced, but what about the term 'decision rule'? Granted that the 3rd Ed gives you a link to the Online Browsing Platform https://www.iso.org/obp - which is great! Oops that is a change! Are the expanded requirements for Complaints [Clause 7.9] a change? Were these changes identified to your satisfaction? Does that 'pass muster'?
dwperron
Looking over your comments again I think I am getting what you are looking for, but I'm not sure.
Are you expecting the authors of the 17025 revision to have and apply the same document control rules found in 17025?
Douglas E. Purdy
All I know is that if you do not maintain a detailed 'revision history' one tends not to remember what has changed. Are the 3 'main changes' listed in the Forward adequate in identifying what changed in the 3rd Edition? Do they 'pass muster' for you?
What is good for the goose should be good for the gander.
Besides isn't there a saying about what may happen if you forget your history?
dwperron
I was afraid that was what you were getting at.
This document is not a "revision" of the 2005 edition:
"This third edition cancels and replaces the second edition (ISO/IEC 17025:2005)"
Any changes to this new original document should have standard document control and revision control. But these ISO documents tend to stand as is until they are replaced, not revised.
Douglas E. Purdy
Thanks for enlightening me! I never actually had any formal training as to the differences between Revisions and Editions. Apparently it is not like the differences between 'editing' VS 'revising'. I guess I have shown my ignorance enough.
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
S The (E) in ISO/IEC 17025:2017(E) ISO 17025 related Discussions 3
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V IS/ISO/IEC 17025:2017 Clause 4.1 Impartiality ISO 17025 related Discussions 3
D Laboratory Manual ISO/IEC 17025 Example wanted ISO 17025 related Discussions 2
Douglas E. Purdy ISO/IEC 17025:2017 Clause 8 & Annex B ISO 17025 related Discussions 9
Ajit Basrur Informational ISO/IEC 17025:2017 Published - November 2017 ISO 17025 related Discussions 8
M Does Calibration to ISO/IEC 17025 conform to Z540.3? ISO 17025 related Discussions 1
D ISO/IEC 17025 Implementation Workshop Ideas ISO 17025 related Discussions 2
Hershal ILAC is preparing to start the possible revision to ISO/IEC 17025 ISO 17025 related Discussions 2
J ISO/IEC 17025 - Which External Documents require control? ISO 17025 related Discussions 6
Z Force & Strain Calibration Uncertainty for ISO/IEC 17025 ISO 17025 related Discussions 2
R Implementation of ISO/IEC 17025 Requirement for our Test Laboratory ISO 17025 related Discussions 2
K Where to buy ISO/IEC 17025:2005 ISO 17025 related Discussions 4
G A2LA's ISO/IEC 17025 and Accreditation Training - Opinions from previous attendees ISO 17025 related Discussions 2
M Does ISO/IEC 17025:2005 require the Laboratory to have separate ISO 9001 Procedures ISO 17025 related Discussions 4
P NABL ISO/IEC 17025 Manual Requirements ISO 17025 related Discussions 3
QMMike TS 16949 - A2LA or ISO/IEC 17025 required for material testing? ISO 17025 related Discussions 6
N Measurement Uncertainty Explanation per ISO/IEC 17025:2005 clause 5.10.4.2 ISO 17025 related Discussions 3
G Is Agilent?s automated network analyzer verification ISO/IEC-17025 compliant? ISO 17025 related Discussions 4
R Example of ISO/IEC 17025 Implementation Project Plan ISO 17025 related Discussions 8
I Unapproved Accreditation Bodies offer ISO/IEC 17025 Accreditations ISO 17025 related Discussions 3
suildur Assuring the Quality of Test and Calibration Results - ISO IEC 17025 Clause 5.9 ISO 17025 related Discussions 13
Hershal Training in ISO/IEC 17025:2005 - May 2010 Washington, DC ISO 17025 related Discussions 3
A Compliance with ISO/ IEC 17025:2005 Clause 5.9 for Calibration Laboratories ISO 17025 related Discussions 6
A How to comply with ISO/IEC 17025 Laboratory Requirements ISO 17025 related Discussions 7
D Calibration Frequency of CMM as per ISO/IEC 17025 ISO 17025 related Discussions 11
Hershal Training in ISO/IEC 17025 and 17020 ISO 17025 related Discussions 0
V ISO/IEC 17025 Clause 4.4 - Review of requests, tenders and contracts ISO 17025 related Discussions 4
T Calibration Procedures - ISO/IEC 17025, Clause 5.5.9 - Outsourced Calibration ISO 17025 related Discussions 10
Hershal Update from MSC........ ISO/IEC 17025 - Challenges and Solutions ISO 17025 related Discussions 1
Hershal Reviving the discussion on ISO/IEC 17025 ISO 17025 related Discussions 4
Hershal Introduction to ANS/ISO/IEC 17025 and Z540 ISO 17025 related Discussions 2
Hershal ISO/IEC 17025:2005 Clause 4.1.5 and 4.1.6 ISO 17025 related Discussions 5
S Project Kick-Off - First visit agenda to kick off a ISO/IEC 17025:2005 ISO 17025 related Discussions 1
D Do Supplier's Laboratories Need to be Accredited to ISO/IEC 17025 ISO 17025 related Discussions 15
S Laboratory is accredited to ISO/IEC 17025 but that is not stated on the Cal Cert ISO 17025 related Discussions 7
B What Laboratories are the 'National Equivalent' of Accredited to ISO/IEC 17025? ISO 17025 related Discussions 3
Hershal ISO/IEC 17025 and ISO/IEC 17020 training ISO 17025 related Discussions 2
D Appropriate Equipment for ISO/IEC 17025:2005 Clause 5.6.3.3 - Intermediate Check ISO 17025 related Discussions 5
A Linearity and Eccentricity Point Definitions - Ref: ISO/IEC 17025:2005 ISO 17025 related Discussions 1
J ANSI/NCSL Z540-1-1994 vs. ANSI/ISO/IEC 17025:2000 ISO 17025 related Discussions 4
Hershal For accredited labs that expect more - Certification of ISO/IEC 17025 assessors ISO 17025 related Discussions 4
WCHorn ISO/IEC 17025 Registrars - I'm confused about "accredited" registrars for ISO 17025 ISO 17025 related Discussions 18
A Sampling - What does it mean by Sampling in ISO:IEC 17025 ISO 17025 related Discussions 1
Hershal Measurement Uncertainty - Need help with ANS/ISO/IEC 17025 and MU ISO 17025 related Discussions 0
Hershal Measurement Uncertainty Training - ANS/ISO/IEC 17025, ISO/IEC 17020 ISO 17025 related Discussions 0
A ISO/IEC 17025 Training in Pakistan, or any other country in that region ISO 17025 related Discussions 4
