ISO/IEC 17025 Registrars - I'm confused about "accredited" registrars for ISO 17025
WCHorn
Rubber, Too Glamorous?
I'm confused about "accredited" registrars for ISO 17025. I'm not satisfied with our current registrar and I want to use a different registrar. Which are the accreditation bodies for registrars and is there a source for a comprehensive list of registrars? Internet searches seem hit and miss.
Thank you,
Carl
Sidney Vianna
Post Responsibly
Re: ISO/IEC 17025 Registrars - I'm confused about "accredited" registrars for ISO 170
Hi Carl, hope all is well.
ISO/IEC 17025 is not a standard to which the registrars get accredited to, via, for example, ANAB, RvA or UKAS. If you go to the ANAB website and check their directory, you will see that they do not accredit registrars to this standard.
Typically labs get ACCREDITED to ISO 17025, via a lab accreditation body, such as A2LA, IAS, NAVLAB, etc...Check attached communique'.
Hershal
Metrologist-Auditor
Thanks Sidney, you are absolutely correct.....
Laboratories become accredited to (in the U.S.) ANS/ISO/IEC 17025 by accrediting bodies (ABs).....internationally to ISO/IEC 17025.....
Accreditation (e.g., ANS/ISO/IEC 17025) and Registration (e.g., ISO 9001) are not the same, and so the need for the difference in bodies required.
The best website to find another accrediting body in the U.S., where WCHorn is at, is:
http://www.aplac.org
Be sure that you review ALL the ABs listed for the U.S., or other countries should you desire. Discuss your needs with, and obtain quotes from, ALL the ABs that can service you - BEFORE - you sign with any AB. This is smart shopping and makes the AB.
Hope this helps.
Hershal
Helmut Jilling
Auditor / Consultant
Thank you,
Carl
Please clarify for us. Are you a Test Lab which is currently accredited to ISO 17025?
suedoe
more confused about 17025 accreditation bodies
These responses don't tell the whole story........how do you find the ABs--Accreditation Bodies for the US? The aplac.org link directs us to IAS, A2LA and NVLAP.....they aren't the only ABs are they? What about L.A.B.? And what about Orion Registrars, NSAI, or Perry Johnson, etc. who claim they can get you 'certified"?? I understand that you need accreditation and not registration, but I am still not clear who those people actually are, in the U.S.!!
thanks
Sue
:nopity:
Hershal
Metrologist-Auditor
suedoe, you are correct that there are others.....but the question then becomes "Do you only need paper on the wall?" in which case, there are several options.....if one needs recognition as it is known, whether from APLAC or ILAC, then there are four in the U.S......IAS, A2LA, NVLAP, and ACLASS.
Other recognized options available in North America include Canada (SCC or CLAS) and Mexico (EMA), which are also signatories.....
Hope this helps.
Hershal
lindal
Re: more confused about 17025 accreditation bodies
thanks
Sue
:nopity:
I have a question about this too. One of our testing houses is accredited through BSI for their quality system, but is their conformance to 17025 is accredited by Perry Johnson Laboratory Accreditation, inc.
I am preparing for an audit and am usually concerned when I see PJ anywhere, I didn't know that they were qualified to "certificate" labs. Is this normal? I'm used to seeing accreditation by A2LA or NVLAP.
Should I just relax?
Rmuse
Sue,
Hershal is correct in that right now there are only 4 recognized Accreditation Bodies in the US. They are ACLASS, A2LA, IAS and NVLAP. Most companies are running into trouble with a Perry Johnson accreditation because PJL is not an ILAC signatory. This means that a great number of companies will not acknowledge your accreditation. This is especially true in the last year or so. Some companies are just now realizing this now becasue the regulators, OEM, specifiers, etc are recently requiring accreditation by an ILAC signatory.
Roger Muse
ACLASS Accreditation Services
Mr Niceguy
From a UK perspective, with only UKAS as the national AB, I was interested in this thread. From the UKAS website I find that the ILAC mutually recognised ABs in the USA are the 4 mentioned above ACLASS, A2LA, NVLAP, IAS and no other. Therefore my first thoughts were that, when faced with a testing/calibration certificate originating with Perry Johnson, I could not accept its equivalence. On going to the PJ website my second thoughts were that I might be premature not to accept its equivalence. At least the full scopes of the labs are published with expiration dates. But then there were third thoughts ! PJ say they they are recognised as ABs by NACLA and give the link - but NACLA don't list them as recognised on their website. They are listed as full members of APLAC on the APLAC website but not as signatories of the APLAC Mutual Recognition Arrangment. All in all a few inconsistencies.
WCHorn
I work for a manufacturer that has captive laboratory that is accredited by a non-signatory to ILAC (PRI/NADCAP). We need the accreditation to avoid subcontracting a lot of testing to ISO 17025 accredited laboratories. Technically, we are not required by out customers or contracts to have accreditation by ab ILAC signatory, but I've heard that that will change in the not-too-distant future.
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
S The (E) in ISO/IEC 17025:2017(E) ISO 17025 related Discussions 3
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V IS/ISO/IEC 17025:2017 Clause 4.1 Impartiality ISO 17025 related Discussions 3
D Laboratory Manual ISO/IEC 17025 Example wanted ISO 17025 related Discussions 2
Douglas E. Purdy ISO/IEC 17025:2017 3rd Ed. Changes from 2nd Ed. ISO 17025 related Discussions 6
Douglas E. Purdy ISO/IEC 17025:2017 Clause 8 & Annex B ISO 17025 related Discussions 11
Ajit Basrur Informational ISO/IEC 17025:2017 Published - November 2017 ISO 17025 related Discussions 8
M Does Calibration to ISO/IEC 17025 conform to Z540.3? ISO 17025 related Discussions 1
D ISO/IEC 17025 Implementation Workshop Ideas ISO 17025 related Discussions 2
Hershal ILAC is preparing to start the possible revision to ISO/IEC 17025 ISO 17025 related Discussions 2
J ISO/IEC 17025 - Which External Documents require control? ISO 17025 related Discussions 6
Z Force & Strain Calibration Uncertainty for ISO/IEC 17025 ISO 17025 related Discussions 2
R Implementation of ISO/IEC 17025 Requirement for our Test Laboratory ISO 17025 related Discussions 2
K Where to buy ISO/IEC 17025:2005 ISO 17025 related Discussions 4
G A2LA's ISO/IEC 17025 and Accreditation Training - Opinions from previous attendees ISO 17025 related Discussions 2
M Does ISO/IEC 17025:2005 require the Laboratory to have separate ISO 9001 Procedures ISO 17025 related Discussions 4
P NABL ISO/IEC 17025 Manual Requirements ISO 17025 related Discussions 3
QMMike TS 16949 - A2LA or ISO/IEC 17025 required for material testing? ISO 17025 related Discussions 6
N Measurement Uncertainty Explanation per ISO/IEC 17025:2005 clause 5.10.4.2 ISO 17025 related Discussions 3
G Is Agilent?s automated network analyzer verification ISO/IEC-17025 compliant? ISO 17025 related Discussions 4
R Example of ISO/IEC 17025 Implementation Project Plan ISO 17025 related Discussions 8
I Unapproved Accreditation Bodies offer ISO/IEC 17025 Accreditations ISO 17025 related Discussions 3
suildur Assuring the Quality of Test and Calibration Results - ISO IEC 17025 Clause 5.9 ISO 17025 related Discussions 13
Hershal Training in ISO/IEC 17025:2005 - May 2010 Washington, DC ISO 17025 related Discussions 3
A Compliance with ISO/ IEC 17025:2005 Clause 5.9 for Calibration Laboratories ISO 17025 related Discussions 6
A How to comply with ISO/IEC 17025 Laboratory Requirements ISO 17025 related Discussions 7
D Calibration Frequency of CMM as per ISO/IEC 17025 ISO 17025 related Discussions 11
Hershal Training in ISO/IEC 17025 and 17020 ISO 17025 related Discussions 0
V ISO/IEC 17025 Clause 4.4 - Review of requests, tenders and contracts ISO 17025 related Discussions 4
T Calibration Procedures - ISO/IEC 17025, Clause 5.5.9 - Outsourced Calibration ISO 17025 related Discussions 10
Hershal Update from MSC........ ISO/IEC 17025 - Challenges and Solutions ISO 17025 related Discussions 1
Hershal Reviving the discussion on ISO/IEC 17025 ISO 17025 related Discussions 4
Hershal Introduction to ANS/ISO/IEC 17025 and Z540 ISO 17025 related Discussions 2
Hershal ISO/IEC 17025:2005 Clause 4.1.5 and 4.1.6 ISO 17025 related Discussions 5
S Project Kick-Off - First visit agenda to kick off a ISO/IEC 17025:2005 ISO 17025 related Discussions 1
D Do Supplier's Laboratories Need to be Accredited to ISO/IEC 17025 ISO 17025 related Discussions 15
S Laboratory is accredited to ISO/IEC 17025 but that is not stated on the Cal Cert ISO 17025 related Discussions 7
B What Laboratories are the 'National Equivalent' of Accredited to ISO/IEC 17025? ISO 17025 related Discussions 3
Hershal ISO/IEC 17025 and ISO/IEC 17020 training ISO 17025 related Discussions 2
D Appropriate Equipment for ISO/IEC 17025:2005 Clause 5.6.3.3 - Intermediate Check ISO 17025 related Discussions 5
A Linearity and Eccentricity Point Definitions - Ref: ISO/IEC 17025:2005 ISO 17025 related Discussions 1
J ANSI/NCSL Z540-1-1994 vs. ANSI/ISO/IEC 17025:2000 ISO 17025 related Discussions 4
Hershal For accredited labs that expect more - Certification of ISO/IEC 17025 assessors ISO 17025 related Discussions 4
A Sampling - What does it mean by Sampling in ISO:IEC 17025 ISO 17025 related Discussions 1
Hershal Measurement Uncertainty - Need help with ANS/ISO/IEC 17025 and MU ISO 17025 related Discussions 0
Hershal Measurement Uncertainty Training - ANS/ISO/IEC 17025, ISO/IEC 17020 ISO 17025 related Discussions 0
A ISO/IEC 17025 Training in Pakistan, or any other country in that region ISO 17025 related Discussions 4
