Randy
Just played that game this week during the audit I did...........Oops!Do not "name" the person, unless you want to change things every time someone leaves the job. Title is more than sufficient.
As a job shop, most likely all of the regulatory requirements will be flowed down from your customer.From what I know, we are not 'regulated' by any authority that imposes QMS requirements,
We are a job shop, so ultimately any requirements that come to us are specific to the customer contracts relating to the job, and are always changing based on the work we are currently doing
The wording trips me up at the 'stat/reg qms requirements'. How are those different than customer regulatory requirements such as RoHS or REACH or something similar? From what I understand, those don't impose any requirements relating to the QMS.
For the second answer, our flow chart has the name of the process, the inputs and outputs, the connection to other processes, and the owners. But owners are not defined by name, rather by position. So Production would have the process owner "Production Manager". I'm assuming this is enough to meet the requirement, since there isn't anything mandating that the process owners be named.
Is this an adequate interpretation?
Your help is much appreciated
I see. I could write this into our quality manual:ITAR compliance in the context of an organization in the Aviation, Space and Defense supply chain is a commonly mentioned legal requirement which might affect you.
Not necessarily an additional regulation, but in a sector where counterfeit material and components are such a serious risk, failure to properly manage the origin and traceability of metal parts could, in an extreme case, bring the feds knocking on your door.
I'm a fan of rolling everything into as compact and readable form as possible, so it made sense to me to address who owns the processes directly in the flow chart. Good to know it works out.Let's start with the concept of a management system. This implies that all parts are working together for a common goal. Interpreting the requirements on an organization is what the management system needs to do. So, the need to integrated statutory and regulatory requirements into the system is what the is needed.
While the statutory and regulatory requirements may not impose requirements to the "QMS", they must be met by the organization.
If a new management team was put in place in your organization, would the document information (Quality Manual) ensure this new team would be aware of all of the requirements that impact the organization?
In the context of the organization section of the quality manual, a brief mention that the organization complies with all RoHs and REACH requirements would be a good addition.
Yes, this sounds good. I applaud the decision to use titles in the flow chart, as well.
There are companies that have a process called "Production", and the process owner is the "Manufacturing Manager". IMHO, that is where it really helps to define the process owner.
As a contrast, if the process owner has the title "Production Manager", it cannot be assumed that is the process owner, as it may be the 'Director of Finance" that is actually the process owner. So it is good when this is all documented and has Top Management consensus.
I wouldn't do that in the quality manual. Too many things change, so you want something easily changeable. I would put some boilerplate language in the manual if you have to. But I would use a simple matrix to identify what regulatory requirements you follow, and possibly include the reason why.I see. I could write this into our quality manual:
"The organization is registered with the Controlled Goods Program. The requirements relevant to GCP compliance are addressed, and can be found in the Security Plan.
Additionally, requirements for statutory and regulatory compliance may be imposed onto the organization, such as when they are stated as a part of a purchase order, contract, or other agreement.. Examples include: RoHS, REACH, DFAR, CUSMA, etc. The organization complies with any such requirements as needed.
Anything I could improve here? I'm under the impression that I should mention how exactly those requirements are addressed, but I don't want to get too prescriptive in the manual.
I like what you propose.Customer and applicable statutory and regulatory requirements are also addressed.
I hope your February audit was productive. I want to encourage you that I have been exactly where you are and the absolute best results come from you and your team taking that manual and changing it. The only value in the manual you got is hopefully a good structure. Other than that, you need an ally on the production team and a clear understanding of the difference between required and best-practice. There is a light at the end of the tunnel and it is not a train. After that, you hope and pray for auditors that will give you NC's so you get better and not to punish you. The NC's are your ticket to get management behind resolving them and in the process, making your system more robust.We moved the stage 2 audit to late February.
I have a much better understanding of the requirements now, but still scrambling to pull everything together.
We are using color coded travelers and staff are generally learning the new procedures, which is good
Since I am simultaneously building the procedures, auditing my own work, and trying to train people, (and having to deal with confused or confrontational staff members) its proving to be pretty challenging. Especially since i am finding many nonconformities. I am in a constant dilemma. I could stop everything and simply do an internal audit, but due to time pressure and since i am the only one able to interpret the standard, any findings just come back to me, so it seems my best action is to just make decisions on my own.
The most major issue I noticed, is that information seems to ripple and lag through the organization, and im afraid i do not have the power to change that on my own
Management means well, and i am treated well, but are super limited in resources and are not able to be fully engaged in the qms development
Some days I wonder if i am biting off more than i can chew,
Having a good consultant would be incredibly useful, but due to budget and time we are most likely gonna have to ride this one out.
P.S @Randy it looks like he's worked with these standards:
QS 9000, M1003, ISO 13488, 14001, 9001, 13485, 16949, 18000, 22000
Thank you for your sentiments, it's much appreciated. I'm doing my best to stay on top of it, and to change things as we go to better fit our actual work process. I'm learning more and more as I go, and am starting to feel more comfortable giving guidance in regards to quality. Thankfully, all members of management are on board with this. They just don't often have the resources to be actively involved.I hope your February audit was productive. I want to encourage you that I have been exactly where you are and the absolute best results come from you and your team taking that manual and changing it. The only value in the manual you got is hopefully a good structure. Other than that, you need an ally on the production team and a clear understanding of the difference between required and best-practice. There is a light at the end of the tunnel and it is not a train. After that, you hope and pray for auditors that will give you NC's so you get better and not to punish you. The NC's are your ticket to get management behind resolving them and in the process, making your system more robust.
By a wild stroke of luck and some long hours, we passed the audit with 1 minor nonconformity.
See? No need to worry as long as the CB auditor is incompetent.But, maybe, the same auditor will be relaxed as well and write up just a handful of minor nonconformities.
I'm glad you're getting your certificate! Hopefully, your management doesn't take this the wrong way and think you're done.As for the audit:
If you have any advice on working with management, conflict avoidance, how to get everyone on the same page, etc. it would be greatly appreciated.
