ISO/TS 16949 - 7.3.3.2 Manufacturing Process Design Output
Andrews
The subject clause says
manufacturing process deisgn out put shall include
- process appproval acceptance criteria
- methods of rapid detection and feedback of product / manufacturing process non conformities.
Can some one explain with example what this means?
qusys
Re: 7.3.3.2 manufacturing process design output
You are referring to ISO TS.
for item 1: Process approval can be referred to materials, services, specs used in process flow, including risks as well as cost analysis. The results shall be assessed versus the expectations to provide the acceptance.
for item 2: Some examples could be related to lean manufacturing such poka yoke, inventory control, production control systems, visual checks , production layout and staff like that, with the intent to reduce/eliminate dead times and waste.
Waiting for other Covers feedbacks.
Hope this helps in meantime:bigwave:
Based on response from qusys above, this thread is now moved to ISO/TS 16949 - International Automotive Quality Systems Standard sub-forum.
Jen Kirley
Quality and Auditing Expert
To expand on qusys response, "methods of rapid detection and feedback" are intended to focus on timely recognition and resolution of issues that can result in product defects and even missed goals like on-time shipments. Process monitoring such as SPC is not only in place, but is being actively used to find issues as quickly as possible. Response mechanisms are expected to be effective to help ensure no defective product is shipped, but also to help eliminate causes in the process so defective product is not repeatedly being produced.
morteza
Hi
Acceptance criteria for process approval are those indices, if would be met, show that the manufacturing process is capable to deliver the expected outputs. Some of these criteria can be Cpk, defect rate, RPN, production rate and so on.
These criteria are used for process validation according to clause 7.3.6.
Methods of rapid detection and feedback of product / manufacturing process non-conformities, are methods which are used for detection and alarming of nonconformities in product/process. We use some sensors in our manufacturing processes which automatically check the product characteristics and process parameters (especially for heat treatment process). When characteristics/parameters are out of range, the machine will stop and start to alarm by a big red light and in some cases by sound.
This requirement has a relationship with clause 8.2.1.1.
For more information you can search about ANDON.
Hope this helps:)
Andrews
Thanks for your input.
Item 1: Can actual production output and defect ppm be considered as process approval acceptance criteria
Item 2 : Error proofing are separately given as an manufacturing process design output in clause 7.3.3.2. Can hourly inspection be considered as "methods of rapid detection and feedback"
qusys
Yes, I think so
bettsaj IATF 16949 manufacturing cell in ISO 9001 factory? IATF 16949 - Automotive Quality Systems Standard 15
Crimpshrine13 Is VDA 6.3 required for Manufacturing Process Audit (ISO/TS 16949)? Manufacturing and Related Processes 5
Q TS 16949 Manufacturing Site uses ISO 9001 Corporate Laboratory IATF 16949 - Automotive Quality Systems Standard 2
L ISO/TS 16949 Cl 8.2.3.1 - Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 3
M ISO/TS 16949 Manufacturing Audits - Check List Questions - 8.2.2.2 General Auditing Discussions 23
Sidney Vianna Tesla Lacks Major Automotive Quality Certifications such as IATF 16949 and ISO 9001 IATF 16949 - Automotive Quality Systems Standard 15
W Looking for IATF 16949 (and ISO 17025) QMS software Suggestions Quality Tools, Improvement and Analysis 8
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 7
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
S Necessity of Legal Register to conform to ISO 9001, ISO 14001, IATF 16949 ISO 14001:2015 Specific Discussions 6
A ISO / IATF 16949 Requirements for Second Party Services IATF 16949 - Automotive Quality Systems Standard 10
Coury Ferguson Report the CB... Certification Audit (IATF 16949) not to ISO 17021 Registrars and Notified Bodies 3
eule del ayre IATF 16949 / ISO 9001:2015 audit criteria IATF 16949 - Automotive Quality Systems Standard 17
xfngrs How similar or different are IATF 16949 Vs. ISO 13485 IATF 16949 - Automotive Quality Systems Standard 0
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
J 3 Questions about Management Review - ISO 9001 and IATF 16949 Management Review Meetings and related Processes 4
QMMike ISO (in search of) IATF 16949 vs. TS 16949 changes summed up IATF 16949 - Automotive Quality Systems Standard 7
Cats Clause Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
F IATF 16949 - Cl. 8.4.2.3 - Which type of suppliers could be exempt of ISO 9001 IATF 16949 - Automotive Quality Systems Standard 16
M ISO TS 16949 Transfer to another CB (Certification Body) IATF 16949 - Automotive Quality Systems Standard 3
K Top Executive Management ISO 9001:2015 and IATF 16949 Overview IATF 16949 - Automotive Quality Systems Standard 4
A ISO/TS 16949 - Sharing Certification Audit Report (NCR's) with the Customer IATF 16949 - Automotive Quality Systems Standard 8
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
Anerol C IATF or ISO TS 16949 rules about Scope of QMS IATF 16949 - Automotive Quality Systems Standard 7
Q Gap assessment on TL9000 with respect to ISO TS 16949 TL 9000 Telecommunications Standard and QuEST 3
Crimpshrine13 ISO/TS 16949 CBs & Auditors not following up on the schedules IATF 16949 - Automotive Quality Systems Standard 43
Crimpshrine13 ISO/TS 16949 vs. ISO 9001 IATF 16949 - Automotive Quality Systems Standard 7
M Exclusions clause 7.3 - Our organization doesn?t design products - ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
M Risk analysis - ISO/TS 16949 clause 7.2.2.2 IATF 16949 - Automotive Quality Systems Standard 2
K Can anyone recommend some good book explaining ISO/TS 16949 requirements? Book, Video, Blog and Web Site Reviews and Recommendations 9
K What are the current ISO/ TS 16949 Semiconductor Manufacturer Requirements IATF 16949 - Automotive Quality Systems Standard 12
C Special Characteristics - ISO/TS 16949 Clause 7.3.2.3 IATF 16949 - Automotive Quality Systems Standard 8
A We passed our ISO TS 16949 initial certification Covegratulations 3
F ISO/TS 16949 - Auditing supporting activities IATF 16949 - Automotive Quality Systems Standard 1
F ISO/TS 16949 internal audit scope and annual plan Internal Auditing 2
S Quality Manual and ISO TS 16949 Standard IATF 16949 - Automotive Quality Systems Standard 5
D Internal Audit Checklist for the latest ISO/TS 16949 standard IATF 16949 - Automotive Quality Systems Standard 11
