ISO/TS 16949 Clause 7.6.3.1 - Internal Laboratory - Requirements
Mikey324
Hello again. I am stumped on another 3rd party audit finding. We were recently told that 7.6.3.1 applies to our new stamping operation (our company has no previous experience in this area). The only "testing" we will be doing is standard dimensional measurement using digital calipers, micrometers, height gage/dial indicator. I was not aware this could be considered an internal lab because this is an end of production line inspection. We have the equipment calibrated by 17025 companies, or calibration is traceable to 17025 standards. We have instructions and procedures for internal calibration in place. Is our auditor correct or is this leaning toward opinion based on the definition in 3.1.4?
qusys
Re: TS 16949 Clause 7.6.3.1 - Internal Laboratory - Requirements
Hi Mikey,
Could you please write the statement of the non conformance?
I did not understand the problem well.
Do you mean that a part of the production line was seen by the external auditor as an internal lab?
Mikey324
Statement of NC is lab scope not defined. Very basic. We did not define a scope because we didn't know this section applied. The testing being done is only dim. checks recorded on an inspection sheet. This is done on the line, we do not have an actual lab that parts are taken into.
qusys
I do not know. it results very strange to me.
Did you show your process flow to your external auditor? Did you show the PPAP that you should have signed off with your customer?
If what you say it is not a lab and it is included in the process flow you inserted in the PPAP signed by the customer, I would not see an issue.
Probably I may wrong and I do not have all available details , waiting for other experts' considerations and contribution on it.:bigwave:
Mikey324
It has not been approved by our customer (installation still under way), we are still working on the PPAP. As i said, very new process. We have multiple blanking PPAPs approved, no mention ever from the customer requireing a lab scope. Even for the future.
qusys
Understood.
I know 3.1.4 definition of a lab in ISO TS.
If you had shown a process flow chart of your product realization ( from incoming to shipping, also requested to trigger FMEA and Control), you coud have avoided the ncn, if , as you say, this is an inline control and not lab in strict sense of the term.:bigwave:
ddonben
If I am understanding your original statement that some of your gauges are calibrated internally, then the auditor is correct.
There must be a lab scope, procedures for the gauges you calibrate.
For the external labs, you need to have both a copy of their 17025 certificate and their lab scope.
Mikey324
Understood.
Process flow charts are not completed at this time because process design is still in process. This was explained.Process flow, minus this operation, was shown. My opinion is the same as yours, this is an online control used to verify product is within spec. If we were testing for function i might understand...
qusys
Reading again the original post, I did not catch if they calibrate tools internally...but probably I am wrong. If it is so, you are right as well as the external auditor.:bigwave:
Golfman25
The way you describe it, I think the auditor is correct (at least from my experience). However, why wouldn't your current "lab" scope cover it. I assume you already use the standard gages you listed to make dimensional checks. And your currently have calibration requirements, etc. If not, you simply need to add them to your current "lab" scope -- doesn't need to be real complicated. And don't get caught up in the word "lab" -- stampers "labs" are usually their shop floor. Good luck.
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
M Exclusions clause 7.3 - Our organization doesn?t design products - ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
M Risk analysis - ISO/TS 16949 clause 7.2.2.2 IATF 16949 - Automotive Quality Systems Standard 2
C Special Characteristics - ISO/TS 16949 Clause 7.3.2.3 IATF 16949 - Automotive Quality Systems Standard 8
T Clarification for ISO/TS 16949 Clause 7.5.1.5 & 7.5.1.6 IATF 16949 - Automotive Quality Systems Standard 1
F ISO/TS 16949 - Definition Clause, sub clause, section, element IATF 16949 - Automotive Quality Systems Standard 8
Q ISO TS 16949 Clause 7.6.3.2 - Requirements for External Laboratories IATF 16949 - Automotive Quality Systems Standard 9
M ISO/TS 16949 Clause 8.1: Full of Repetitive Requirements? IATF 16949 - Automotive Quality Systems Standard 1
Q How to meet Clause 7.1.2 Acceptance Criteria in ISO TS 16949 IATF 16949 - Automotive Quality Systems Standard 7
J Clause 7.5.5.1 (Storage and Inventory) requirements in ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 8
R ISO/TS 16949:2009 Clause 4.1 General Requirements (Outsourcing) Clarification IATF 16949 - Automotive Quality Systems Standard 6
Q Sampling Plan Acceptance Criteria - ISO TS 16949 Clause 7.1.2 IATF 16949 - Automotive Quality Systems Standard 8
L Customer Verification at Supplier?s Premises - ISO TS 16949 Clause 7.4.3 IATF 16949 - Automotive Quality Systems Standard 2
M ISO TS 16949 Clause List or Manual IATF 16949 - Automotive Quality Systems Standard 11
Q ISO/TS 16949 Questions About clause 7.1.2. Attribute Data Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
M ISO/TS 16949:2002, clause 1.2:Application IATF 16949 - Automotive Quality Systems Standard 3
Q PFMEA and Semi Conductor Supplement - ISO/TS 16949 Clause 7.3.3.2S FMEA and Control Plans 3
V What is a US National Equivalent to ISO 17025? TS 16949 Clause 7.6.3.2 ISO 17025 related Discussions 6
R Special Characteristics - ISO/TS 16949 Clause 7.3.2.3 - Required by auditor IATF 16949 - Automotive Quality Systems Standard 54
K ISO/TS 16949:2000, Clause 7.4.1.2 ? What are you doing to foster supplier quality man Supplier Quality Assurance and other Supplier Issues 14
T ISO 17025 and ISO/TS-16949 Clause 7.6.3.1 Requirements - In-House Laboratory ISO 17025 related Discussions 2
K TS 16949 Clause 7.4.1.2 - Supplier Development and ISO 9000 Registration Requirement Supplier Quality Assurance and other Supplier Issues 22
B Procedure for ISO/TS 16949 Clause 4.1.7 Impact on Society IATF 16949 - Automotive Quality Systems Standard 1
D ISO 16949 Clause 4.1.6 - Employee motivation in a low skilled workforce Preventive Action and Continuous Improvement 20
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
S Necessity of Legal Register to conform to ISO 9001, ISO 14001, IATF 16949 ISO 14001:2015 Specific Discussions 6
B IATF 16949 manufacturing cell in ISO 9001 factory? IATF 16949 - Automotive Quality Systems Standard 15
A ISO / IATF 16949 Requirements for Second Party Services IATF 16949 - Automotive Quality Systems Standard 10
Coury Ferguson Report the CB... Certification Audit (IATF 16949) not to ISO 17021 Registrars and Notified Bodies 3
eule del ayre IATF 16949 / ISO 9001:2015 audit criteria IATF 16949 - Automotive Quality Systems Standard 17
xfngrs How similar or different are IATF 16949 Vs. ISO 13485 IATF 16949 - Automotive Quality Systems Standard 0
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
J 3 Questions about Management Review - ISO 9001 and IATF 16949 Management Review Meetings and related Processes 4
QMMike ISO (in search of) IATF 16949 vs. TS 16949 changes summed up IATF 16949 - Automotive Quality Systems Standard 7
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
F IATF 16949 - Cl. 8.4.2.3 - Which type of suppliers could be exempt of ISO 9001 IATF 16949 - Automotive Quality Systems Standard 16
M ISO TS 16949 Transfer to another CB (Certification Body) IATF 16949 - Automotive Quality Systems Standard 3
K Top Executive Management ISO 9001:2015 and IATF 16949 Overview IATF 16949 - Automotive Quality Systems Standard 4
A ISO/TS 16949 - Sharing Certification Audit Report (NCR's) with the Customer IATF 16949 - Automotive Quality Systems Standard 8
