ISO TS 16949 Clause 7.6.3.2 - Requirements for External Laboratories
qusys
Is this requirement referred to only the gauge/tools that are mentioned in control plan?
I mean if an organization uses some tools ( such as caliper, multimeter etc...) that are not inserted in the control plan , is an ISO TS organization obliged to send out to ISO 17025 accredited external labs in the case it does not have any internal lab for calibration and it wants to have them calibrated anyway?:bigwave:
Jen Kirley
Quality and Auditing Expert
Re: ISO TS 16949 Clause 7.6.3.2 - Requirements for External Labs
If I was looking at this circumstance I would expect the tools are used in a process that is not listed in the certification scope.
The requirement is not to send to a 17025 accredited lab, but to use a lab with a defined scope that includes the capability to perform the required test or calibration, and is either 17025 accredited or is acceptable to the customer without 17025 accreditation. In other words, using non-accredited labs is permitted so long as the customer approves. It follows that some record of the approval should be available.
qusys
So, the fact that they are not mentioned in the control plan is not influent ?
Is a waiver of the customer enough or is it need an assessment of second part on not accredited ISO 17025 labs?
Jen Kirley
The reason I made reference to certification scope is an expectation that AIAG and the automotive customers it serves is trying to avoid dual management systems in the same organization: one for automotive, the other for non-automotive.
But I need to point out that I am operating with a limited set of information. I have done a Google search for AIAG guidance on specifics like this one, and found nothing I can feel sure gives you the certainty you are asking for. Until I finish AIAG's course and exam and qualified for CB Lead Auditor under the the TS 16949 standard my insights are limited to that of internal auditor.
I would love to see what responses others offer. :cfingers:
Howard Atkins
Forum Administrator
The control plan requirement only applies to MSA clause 7.6.1
If you use an external lab for inspection, test or calibration services , this includes functional and material tests not only calibration it must be an accredited laboratory of approval from the customer.
If for example you outsource a salt test then this must be in a ISO 17025 which has in its scope- or at a lab approved by your customer in advance,
You need always to request the scope of any lab that you use to ensure that the test that the work that you order is within its scope
morteza
Hi qusys,
Clause 7.6.3.2 also applies for calibration of any gauge used for providing valid results (see 7.6), whether the gauge included in CP (such as a gauge used for checking the part by operator) or not (such as a micrometer which is used by a product auditor).
So, the organization shall use a lab which has been accredited to ISO/IEC 17025 or approved by customer.
qusys
Hi qusys,
Approved by customer, how? With a second part audit or its audit on the the supplier?
In which phase could be the approval or the waiver from the customer could happen?:bigwave:
qusys
The clause of ISO TS is very controversial, expecially in the case the calibration is only assured by the manufacturer of the gauge. :bigwave:
morteza
Hi qusys,
All OEM usually provide a list of approved labs in their website or via a formal letter, for their suppliers.
As mentioned in NOTE 1 under clause 7.6.3.2, approval of labs by customer may be obtained by customer or its representative(s) assessment to check whether the laboratory meets the intent of ISO/IEC 17025 or not.
For calibration, many OEM usually approve labs which have been accredited to ISO/IEC 17025. But for test or inspection, they also introduce labs which only approved by them.
If you use a lab which has not been accredited to ISO/IEC 17025 or has not been approved by customer, you should inform the customer and arrange for lab visit by customer, and , if it is possible, to get a letter of approval from customer.
V
vanputten
My understanding is that 7.6 and its sub-clauses generally apply to "equipment needed to provide evidence of conformity of product to determined requirements." This needed equipment may or may not be listed on a control plan.
The type of evidence needed that the external lab is acceptable to the customer(s) is not specified so it is up to the organization to determine if they have the evidence. Evidence could be written approval from the customer based on the organization's audit of the lab or the customer's audit of the lab. It could be evidence of approval from the customer based on a justification letter sent to the customer. It could be that the lab is listed on a customer's list of approved inspection, measuring or test service providers. I am sure there are other forms of evidence that could be acceptable to show the customer's approval.
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
M Exclusions clause 7.3 - Our organization doesn?t design products - ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
M Risk analysis - ISO/TS 16949 clause 7.2.2.2 IATF 16949 - Automotive Quality Systems Standard 2
C Special Characteristics - ISO/TS 16949 Clause 7.3.2.3 IATF 16949 - Automotive Quality Systems Standard 8
T Clarification for ISO/TS 16949 Clause 7.5.1.5 & 7.5.1.6 IATF 16949 - Automotive Quality Systems Standard 1
F ISO/TS 16949 - Definition Clause, sub clause, section, element IATF 16949 - Automotive Quality Systems Standard 8
M ISO/TS 16949 Clause 8.1: Full of Repetitive Requirements? IATF 16949 - Automotive Quality Systems Standard 1
Q How to meet Clause 7.1.2 Acceptance Criteria in ISO TS 16949 IATF 16949 - Automotive Quality Systems Standard 7
Mikey324 ISO/TS 16949 Clause 7.6.3.1 - Internal Laboratory - Requirements IATF 16949 - Automotive Quality Systems Standard 19
J Clause 7.5.5.1 (Storage and Inventory) requirements in ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 8
R ISO/TS 16949:2009 Clause 4.1 General Requirements (Outsourcing) Clarification IATF 16949 - Automotive Quality Systems Standard 6
Q Sampling Plan Acceptance Criteria - ISO TS 16949 Clause 7.1.2 IATF 16949 - Automotive Quality Systems Standard 8
L Customer Verification at Supplier?s Premises - ISO TS 16949 Clause 7.4.3 IATF 16949 - Automotive Quality Systems Standard 2
M ISO TS 16949 Clause List or Manual IATF 16949 - Automotive Quality Systems Standard 11
Q ISO/TS 16949 Questions About clause 7.1.2. Attribute Data Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
M ISO/TS 16949:2002, clause 1.2:Application IATF 16949 - Automotive Quality Systems Standard 3
Q PFMEA and Semi Conductor Supplement - ISO/TS 16949 Clause 7.3.3.2S FMEA and Control Plans 3
V What is a US National Equivalent to ISO 17025? TS 16949 Clause 7.6.3.2 ISO 17025 related Discussions 6
R Special Characteristics - ISO/TS 16949 Clause 7.3.2.3 - Required by auditor IATF 16949 - Automotive Quality Systems Standard 54
K ISO/TS 16949:2000, Clause 7.4.1.2 ? What are you doing to foster supplier quality man Supplier Quality Assurance and other Supplier Issues 14
T ISO 17025 and ISO/TS-16949 Clause 7.6.3.1 Requirements - In-House Laboratory ISO 17025 related Discussions 2
K TS 16949 Clause 7.4.1.2 - Supplier Development and ISO 9000 Registration Requirement Supplier Quality Assurance and other Supplier Issues 22
B Procedure for ISO/TS 16949 Clause 4.1.7 Impact on Society IATF 16949 - Automotive Quality Systems Standard 1
D ISO 16949 Clause 4.1.6 - Employee motivation in a low skilled workforce Preventive Action and Continuous Improvement 20
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
S Necessity of Legal Register to conform to ISO 9001, ISO 14001, IATF 16949 ISO 14001:2015 Specific Discussions 6
B IATF 16949 manufacturing cell in ISO 9001 factory? IATF 16949 - Automotive Quality Systems Standard 15
A ISO / IATF 16949 Requirements for Second Party Services IATF 16949 - Automotive Quality Systems Standard 10
Coury Ferguson Report the CB... Certification Audit (IATF 16949) not to ISO 17021 Registrars and Notified Bodies 3
eule del ayre IATF 16949 / ISO 9001:2015 audit criteria IATF 16949 - Automotive Quality Systems Standard 17
xfngrs How similar or different are IATF 16949 Vs. ISO 13485 IATF 16949 - Automotive Quality Systems Standard 0
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
J 3 Questions about Management Review - ISO 9001 and IATF 16949 Management Review Meetings and related Processes 4
QMMike ISO (in search of) IATF 16949 vs. TS 16949 changes summed up IATF 16949 - Automotive Quality Systems Standard 7
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
F IATF 16949 - Cl. 8.4.2.3 - Which type of suppliers could be exempt of ISO 9001 IATF 16949 - Automotive Quality Systems Standard 16
M ISO TS 16949 Transfer to another CB (Certification Body) IATF 16949 - Automotive Quality Systems Standard 3
K Top Executive Management ISO 9001:2015 and IATF 16949 Overview IATF 16949 - Automotive Quality Systems Standard 4
A ISO/TS 16949 - Sharing Certification Audit Report (NCR's) with the Customer IATF 16949 - Automotive Quality Systems Standard 8
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
