ISO/TS 16949 Questions About clause 7.1.2. Attribute Data Sampling
  • Thread starter qualityengineer
  • Start date
Q
qualityengineer
TS 16949 7.1.2. says: "...For attribute data sampling, the acceptance level shall be zero defects (see 8.2.3.1.).
For example, we measured the wall thickness of a rubber hose (lets say in final control) and find the first sample out of spects. Does this mean we should not try another sample and directly start %100 control?
Another example: We cut a 5 g. sample from a 30 kg mix of rubber and find out it's properties are out of specs. Does this mean that we should not try another sample from the lot and run the previous process (mixing), i.e. rework.
Can anybody provide some explanations on this requirement?
Regards
ScottK
Not out of the crisis
Hi qualityengineer - I don't have an answer, but I modified the thread title to make it clearer to get more responses.
please let me know if misinterpreted the topic.
Eric ng
Regards
Sound like you are using the "Zero Acceptance" Sampling Plan. Since TS clause clearly stated that the acceptance, c=0, then you have to reject the entire lot and decide on the appropriate disposition method. To minimize the chances of rejection, you have work on your process capability.
Eric Ng
Howard Atkins
Forum Administrator
Regards
If you are measuring the wall thickness then this is variable data not attribute data
Attribute data is yes /no etc.
Variable
In the good old days of Mil Std etc the tables worked with acceptance numbers and it was possible to find X defects and accept.
The trend now is to say , if I find 1 then I have to decide what to do.
You can define this yourself, re sample etc. The important aspect is to ask the question when you find 1 and not X
zero acceptance plans are in place so that no lot of material is accepted "knowing that there are defects in the lot". (even if you were to remove the defective parts)
So if you find a single defect in your sample the lot is considered rejected and you must 100% inspection/screen OR rework OR scrap...
P
pinpin - 2009
I agree with Bev D, but if what Howard says is acceptable to CB auditors, it is good for qualityengineer and all of us....what is the view of CB auditors?
Howard Atkins
Forum Administrator
This is in fact another way to say
My main point was that acceptance figure is 0 non conformances.
P
pinpin - 2009
Dear Bev D and Howard,
TS clause 7.1.2 states "For attribute data sampling....", this means either Mil-std 105E or ANSI/ASQC Z1.4? :thanks::thanx:
wak125
Registered Visitor
The clause does not state that only “Mil-std 105E or ANSI/ASQC Z1.4” are the solution, it emphasize that acceptance criteria shall be defined, therefore any mutually agreed Sampling Plan can also work and customer approval is the final solution
P
pinpin - 2009
Dear Wak125,
Understand, but I want to be sure, say we now using Mil-Std 105 E, different sampling size there will be different Ac and Re numbers 0, 1, 2, 3, etc) in this Mil-Std 105 E, but TS just requires Ac to be 0 (zero) right?
J 3 Questions about Management Review - ISO 9001 and IATF 16949 Management Review Meetings and related Processes 4
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
R ISO/TS 16949:2009 Questions related to Work Flow IATF 16949 - Automotive Quality Systems Standard 1
M Two different questions about ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 1
Y Questions about ISO/TS 16949 Requirements and what businesses must be certified IATF 16949 - Automotive Quality Systems Standard 2
smryan Several questions about TS 16949 including associated ISO 9001 certificate IATF 16949 - Automotive Quality Systems Standard 15
P ISO/TS 16949 certification questions IATF 16949 - Automotive Quality Systems Standard 23
M ISO/TS 16949 Manufacturing Audits - Check List Questions - 8.2.2.2 General Auditing Discussions 23
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
S Necessity of Legal Register to conform to ISO 9001, ISO 14001, IATF 16949 ISO 14001:2015 Specific Discussions 6
B IATF 16949 manufacturing cell in ISO 9001 factory? IATF 16949 - Automotive Quality Systems Standard 15
A ISO / IATF 16949 Requirements for Second Party Services IATF 16949 - Automotive Quality Systems Standard 10
Coury Ferguson Report the CB... Certification Audit (IATF 16949) not to ISO 17021 Registrars and Notified Bodies 1
eule del ayre IATF 16949 / ISO 9001:2015 audit criteria IATF 16949 - Automotive Quality Systems Standard 17
xfngrs How similar or different are IATF 16949 Vs. ISO 13485 IATF 16949 - Automotive Quality Systems Standard 0
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
QMMike ISO (in search of) IATF 16949 vs. TS 16949 changes summed up IATF 16949 - Automotive Quality Systems Standard 7
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
F IATF 16949 - Cl. 8.4.2.3 - Which type of suppliers could be exempt of ISO 9001 IATF 16949 - Automotive Quality Systems Standard 16
M ISO TS 16949 Transfer to another CB (Certification Body) IATF 16949 - Automotive Quality Systems Standard 3
K Top Executive Management ISO 9001:2015 and IATF 16949 Overview IATF 16949 - Automotive Quality Systems Standard 4
A ISO/TS 16949 - Sharing Certification Audit Report (NCR's) with the Customer IATF 16949 - Automotive Quality Systems Standard 8
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
Anerol C IATF or ISO TS 16949 rules about Scope of QMS IATF 16949 - Automotive Quality Systems Standard 7
Q Gap assessment on TL9000 with respect to ISO TS 16949 TL 9000 Telecommunications Standard and QuEST 3
Crimpshrine13 ISO/TS 16949 CBs & Auditors not following up on the schedules IATF 16949 - Automotive Quality Systems Standard 43
Crimpshrine13 ISO/TS 16949 vs. ISO 9001 IATF 16949 - Automotive Quality Systems Standard 1
M Exclusions clause 7.3 - Our organization doesn?t design products - ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
M Risk analysis - ISO/TS 16949 clause 7.2.2.2 IATF 16949 - Automotive Quality Systems Standard 2
K Can anyone recommend some good book explaining ISO/TS 16949 requirements? Book, Video, Blog and Web Site Reviews and Recommendations 9
K What are the current ISO/ TS 16949 Semiconductor Manufacturer Requirements IATF 16949 - Automotive Quality Systems Standard 12
C Special Characteristics - ISO/TS 16949 Clause 7.3.2.3 IATF 16949 - Automotive Quality Systems Standard 8
A We passed our ISO TS 16949 initial certification Covegratulations 3
F ISO/TS 16949 - Auditing supporting activities IATF 16949 - Automotive Quality Systems Standard 1
F ISO/TS 16949 internal audit scope and annual plan Internal Auditing 2
S Quality Manual and ISO TS 16949 Standard IATF 16949 - Automotive Quality Systems Standard 5
D Internal Audit Checklist for the latest ISO/TS 16949 standard IATF 16949 - Automotive Quality Systems Standard 11
P I want to make a system audit in accordance with ISO / TS 16949 IATF 16949 - Automotive Quality Systems Standard 4
F What is the scope for "Total Numbers of Employees on site" per ISO/TS 16949 ? IATF 16949 - Automotive Quality Systems Standard 4
M ISO/TS 16949 Rules about Commodities IATF 16949 - Automotive Quality Systems Standard 4
