ISO/TS 16949 Section 7.6.3 - Use of Manufacturer to Calibrate
#11
The manufacturer is preferred for service for not only business reasons (Low cost) but for their expertise. You should not be forced to use an inferior source in order to pass an audit.
Not always true! I know of at least a couple of OE's where they possessed ZERO capabilities to calibrate their equipment! In one (bizarre) situation, the equipment was actually a safety related item and the manufacturer's response was 'it self calibrates'...:rolleyes:
miken11
#12
I know it is not 'always'; true. I was only offering another option to explain the decision to the auditor. I believe the auditor 'should' allow them to use good business judgment and protect their own customers by use of the manufacturer for service and calibration in the case cited. I was not trying to make a general case for all manufacturers.
#13
Howard pointed out earlier that the manufacturer's ISO 9001 status is irrelevant. You must either use a 17025-accredited calibration provider or get customer approval for a non-accredited source. Those are the only options available.
There is a third option. If the manufacturer refuses to adopt a lab scope, tell the auditor that a corrective action is beyond your resources. The manufacturer is preferred for service for not only business reasons (Low cost) but for their expertise. You should not be forced to use an inferior source in order to pass an audit.
There is no third option. If an auditor decides on her own to create one where none exists, the auditor is wrong. The OP is talking about a "shadowgraph" or optical comparator there are lots of qualified, 17025-accredited sources available, so lack of providers isn't in question. Just this week I had two optical comparators and four surface plates calibrated by an accredited supplier and the total bill was less than US$1000, so expense shouldn't be an issue either. Maybe the OP needs to shop around.
#15
Jim Wynne made the point in his post, the requirement is the requirement. The auditor cannot and shouldn't be 'bent' to a persuasive client, using such statements as 'good business judgement'. Good in whose eyes? A cheap, unqualified calibration could come home to haunt that decision.
miken11
#16
The information provided did not indicate any issue withe competence of the manufacturer or their ability to calibrate their own equipment. All this discussion of the 'what ifs' is a waste of time. As I said, in MY OPINION, the case cited should have fallen within the scope of using a qualified manufacturer. The auditor was being way too picky IN MY OPINION.
Golfman25
#18
So let me get this straight. They can manufacture the shadow graph, and all that entials, but they can't calibrate it, even though they provide those services?
If you have no other choice but to use a more expensive source (who has the required piece of paper), then maybe you can consider putting it on a longer calibration schedule. Good luck.
#19
Indeed! I'd be intrigued to see why a shadowgraph needs calibration on a yearly schedule! This may be another clear indication that the company doesn't understand that, if they use the data, the periodicity can be extended - they just want your money! In actual fact, by using an accredited lab, you may save money over what you're currently paying! Go figure!
BatteryHen
#20
The equipment is not stated on any control plan for a specific part. It is used to help calibrate a visual camera system that is tho - we compare the readings of the shadowgraph against the camera readings - and becasue we use it for internal calibration we have to ensure that it was covered by clause 7.6.3.2.
- something we had not considered either!
So, to get round this we have decided to develope a different calibration method that will use normally externally calibrated items, such as slips, which we send to an accredited house anyway. The shadowgraph will continue to be used for comparison work in house but not used as an aid for calibration.
Many thanks to everyone for your invaluble insights and assistance!:thanx:
F ISO/TS 16949 - Definition Clause, sub clause, section, element IATF 16949 - Automotive Quality Systems Standard 8
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
S Necessity of Legal Register to conform to ISO 9001, ISO 14001, IATF 16949 ISO 14001:2015 Specific Discussions 6
B IATF 16949 manufacturing cell in ISO 9001 factory? IATF 16949 - Automotive Quality Systems Standard 15
A ISO / IATF 16949 Requirements for Second Party Services IATF 16949 - Automotive Quality Systems Standard 10
Coury Ferguson Report the CB... Certification Audit (IATF 16949) not to ISO 17021 Registrars and Notified Bodies 1
eule del ayre IATF 16949 / ISO 9001:2015 audit criteria IATF 16949 - Automotive Quality Systems Standard 17
xfngrs How similar or different are IATF 16949 Vs. ISO 13485 IATF 16949 - Automotive Quality Systems Standard 0
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
J 3 Questions about Management Review - ISO 9001 and IATF 16949 Management Review Meetings and related Processes 4
QMMike ISO (in search of) IATF 16949 vs. TS 16949 changes summed up IATF 16949 - Automotive Quality Systems Standard 7
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
F IATF 16949 - Cl. 8.4.2.3 - Which type of suppliers could be exempt of ISO 9001 IATF 16949 - Automotive Quality Systems Standard 16
M ISO TS 16949 Transfer to another CB (Certification Body) IATF 16949 - Automotive Quality Systems Standard 3
K Top Executive Management ISO 9001:2015 and IATF 16949 Overview IATF 16949 - Automotive Quality Systems Standard 4
A ISO/TS 16949 - Sharing Certification Audit Report (NCR's) with the Customer IATF 16949 - Automotive Quality Systems Standard 8
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
Anerol C IATF or ISO TS 16949 rules about Scope of QMS IATF 16949 - Automotive Quality Systems Standard 7
Q Gap assessment on TL9000 with respect to ISO TS 16949 TL 9000 Telecommunications Standard and QuEST 3
Crimpshrine13 ISO/TS 16949 CBs & Auditors not following up on the schedules IATF 16949 - Automotive Quality Systems Standard 43
Crimpshrine13 ISO/TS 16949 vs. ISO 9001 IATF 16949 - Automotive Quality Systems Standard 1
M Exclusions clause 7.3 - Our organization doesn?t design products - ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
M Risk analysis - ISO/TS 16949 clause 7.2.2.2 IATF 16949 - Automotive Quality Systems Standard 2
K Can anyone recommend some good book explaining ISO/TS 16949 requirements? Book, Video, Blog and Web Site Reviews and Recommendations 9
K What are the current ISO/ TS 16949 Semiconductor Manufacturer Requirements IATF 16949 - Automotive Quality Systems Standard 12
C Special Characteristics - ISO/TS 16949 Clause 7.3.2.3 IATF 16949 - Automotive Quality Systems Standard 8
A We passed our ISO TS 16949 initial certification Covegratulations 3
F ISO/TS 16949 - Auditing supporting activities IATF 16949 - Automotive Quality Systems Standard 1
F ISO/TS 16949 internal audit scope and annual plan Internal Auditing 2
S Quality Manual and ISO TS 16949 Standard IATF 16949 - Automotive Quality Systems Standard 5
D Internal Audit Checklist for the latest ISO/TS 16949 standard IATF 16949 - Automotive Quality Systems Standard 11
P I want to make a system audit in accordance with ISO / TS 16949 IATF 16949 - Automotive Quality Systems Standard 4
F What is the scope for "Total Numbers of Employees on site" per ISO/TS 16949 ? IATF 16949 - Automotive Quality Systems Standard 4
M ISO/TS 16949 Rules about Commodities IATF 16949 - Automotive Quality Systems Standard 4
R Corrective Action for Nonconformity in ISO/TS 16949 Recertification Audit IATF 16949 - Automotive Quality Systems Standard 2
B Would compliance with ISO/TS 16949:2009 mean also compliance with ISO 9001:2015? IATF 16949 - Automotive Quality Systems Standard 1
J ISO/TS 16949:2009 Remote Support Provided By Sister Plants IATF 16949 - Automotive Quality Systems Standard 2
M Using our parent company's ISO/TS 16949 Quality Manual IATF 16949 - Automotive Quality Systems Standard 11
Crimpshrine13 Is VDA 6.3 required for Manufacturing Process Audit (ISO/TS 16949)? Manufacturing and Related Processes 5
