ISO/TS 16949 vs. QS 9000 - Comparison of the two standards
#11
SteelWoman said:
:confused: Has anyone here who has made it through a TS upgrade audit successfully argued AGAINST having an audit checklist, and if so, how?
:confused: How did you then answer to the "organization shall audit it's quality management system to verify compliance with this technical spec" thingee? Do you have your QMS listed as a SEPARATE process in your system?
I do not use a checklist or the specification.
Having said that; the checklist that is required is found in the AIAG manual "Quality System Assessment Checklist". Based on the errata sheet for this manual this checklist is now "highly Recommended". Too satisfy that requirement I insert my COP definition in the appropriate spot.
What I use is a process flow diagram and a "crib" sheet listing questions based on Man, Machine, Material, Method, Measurement, inputs and outputs.
IMO a QMS is a process and should be audited as such. Develop and define the COP's using the specification, the CSR's and the turtle diagram. The turtle diagram will aid in further defining the process.
Once you have identified your COP's and determined the interaction then you can audit the entire QMS as a process using the method described above.
howste
Thaumaturge
#12
Pennington said:
Don't bother - this is simply the requirements put in tabular form, clause by clause and the audit questions don't add any value . One just does not audit in this way...
I agree that one "does not audit in this way," but that wasn't the intent of the checklist as it is written. When I audit, I audit processes in whatever order I want, then record evidence in the appropriate place on the checklist. That checklist was written to do 2 things:
1) As SteelWoman wanted, to make sure that all requirements of the standard have been met
2) Give an examples of questions that might be asked for auditors-in-training.
True, every question may not be the best, but if a new auditor is having trouble getting started, it at least is a starting point.
SteelWoman
#13
Two things:
1) Isn't the IATF checklist booklet intended for use by Registrars? When our registrar first pointed it out to me, it was as a reference document, something THEY had to use, but not us. Am I wrong on that? The language of the whole book and even the Errata statement seem to imply that. When the auditor was telling us about it she had just completed HER certification to TS, and was saying they are so "element" leery that they were not allowed, in their training, to HAVE the checklist on their person, but at the end of the audit they were expected to fill it out?? That falls in line with the Errata statement about it being a tool, and process audits are not to be ELEMENT driven.
2) I actually took my original "gap analysis" I did for TS, that listed every "shall" and showed how we did (or early on, did NOT) meet the shall, and then after all was said and done only modified that document slightly and kept it as a "Shall Matrix" tool for my internal auditors. For each shall, it shows the procedure(s) we have that addresses it, references the process that applies to it, etc. One of my internal auditors, after using it for the first time, said "This Shall Matrix ROCKS!!!" (obviously an "under 30 yr-old auditor). It's been a useful tool to give both experienced and inexperienced auditors a "launching point" when preparing to audit a process.
#14
SteelWoman said:
Two things:
Yes it does apply to the CB auditor, however they may ask you to fill in the blanks.
The gap analysis is a good tool to use in determining where all the "shalls" are described, however, if you cannot provide traceability "FROM" the specification and the CSR's "TO" your process definitions and vice/versa, then your processes are not effective or efficient.
mangard
#15
Checklists
8.2.2.4 Internal audit plans - states, in a note, that 'Specfic Checklists shoud be used for each audit'.
Your auditor is therefore right to expect some kind of checklist.
How you implement this is a matter for you.
Like you, I'm not in favour of checklists at all. They go completely against the spirit of the process approach! Accomplished internal auditors would be able to carry out an audit or any area, without any specific aids and pin-point problems and areas for improvement.
Some form of 'checklist', however is a valid tool, particularly for new auditors. I suggest a 'dynamic checklist' based around the tutle diagram. Every audit you do under TS is likely to be 50% planning and review of the performance data with the other 50% as a verification exercise. The 'checklist' would come out of this initial activity.
It would be acceptable to construct a turtle diagram of the area being audited, highlighting areas of interest and concern for physical review. Add the clauses and you can then used that to demonstrate areas seen.
Keep all notes, etc... those can be presented as evidence of a checklist and line of investigation.
Another useful device is to list each audit in a matrix and cross reference against the main clauses of the standard. Over time, you will then be able to see which clauses have been been covered by a review.
Hope this helps.
Ramesh Manga
Helmut Jilling
Auditor / Consultant
#16
SteelWoman said:
By the way, let me throw one more question out there.... when our auditor was last here, back in November or so, doing our hopefully FINAL audit to QS, she mentioned that it was a REQUIREMENT that an audit checklist be utilized. I told her I didn't think that was true, but at the time I didn't have a moment to look it up. Sure enough (it's difficult always being right :rolleyes: ) the standard says it's a "should" not a shall.
We've never utilized audit checklists, and with the move AWAY from Procedure audits to Process audits, I'm even less inclined to put them into place. I was approaching this from the angle where the Mgmt Rep would maintain a "master checklist" each audit cycle of the clauses in the standard to make sure we hit them all during the audit cycle, but that's a rather laborious task for me to complete post-audit and I can't find any real value in doing so.
I think Manguard's answer (post #15) says it pretty well. Also, keep in mind, my information is that IATF rescinded the QSA checklist book. They really are nervous about auditors even hinting they are following a clause based checklist. Manguard gave good guidance, and when I audit, that could likely satisfy my search. Two additional items I'll add. For my consulting clients, I created a process based checklist. It is a generic six page template, covers the kinds of questions the turtle would address, and, very importantly, adds a list of common linkages to support processes to remind auditors what links to look for (training, doc control, gages, maintenance, customer complaints, performance metrics, objectives, etc.). Also, I encourage them to use their control plans, work instructions, etc, as "checklist" as well. They can mark questions and write answers right on their (uncontrolled copies). This all becomes part of the audit records. Works pretty well in audiotr training, because it gives them a (process-based) road map.
J TS 16949 requirements for an ISO 9000 customer IATF 16949 - Automotive Quality Systems Standard 6
G ISO 9000 and TS 16949 - CMMS (Computerized maintenance management software) Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9000:2000 to TS 16949:2000 Gap Assessment Tool IATF 16949 - Automotive Quality Systems Standard 2
B QS-9000 vs. ISO 9001:2000 vs. TS 16949 IATF 16949 - Automotive Quality Systems Standard 5
K TS 16949 Clause 7.4.1.2 - Supplier Development and ISO 9000 Registration Requirement Supplier Quality Assurance and other Supplier Issues 22
C From QS-9000 to ISO/TS 16949 and ISO 9001:2000 IATF 16949 - Automotive Quality Systems Standard 6
R TS 16949 Revision to ISO 9000:2000 Alignment IATF 16949 - Automotive Quality Systems Standard 12
A Differences / deltas between ISO/TS 16949 and QS-9000 IATF 16949 - Automotive Quality Systems Standard 9
K Should we move from QS-9000 to ISO / TS 16949 Registration? IATF 16949 - Automotive Quality Systems Standard 8
K How does ISO/TS 16949 differ from QS-9000? IATF 16949 - Automotive Quality Systems Standard 10
K Does TQM fit in with ISO 9001:2000 and QS-9000 (now TS 16949)? Preventive Action and Continuous Improvement 9
B Will TS 16949 be aligned to ISO 9000:2000 in the future? IATF 16949 - Automotive Quality Systems Standard 62
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
S Necessity of Legal Register to conform to ISO 9001, ISO 14001, IATF 16949 ISO 14001:2015 Specific Discussions 6
B IATF 16949 manufacturing cell in ISO 9001 factory? IATF 16949 - Automotive Quality Systems Standard 15
A ISO / IATF 16949 Requirements for Second Party Services IATF 16949 - Automotive Quality Systems Standard 10
Coury Ferguson Report the CB... Certification Audit (IATF 16949) not to ISO 17021 Registrars and Notified Bodies 1
eule del ayre IATF 16949 / ISO 9001:2015 audit criteria IATF 16949 - Automotive Quality Systems Standard 17
xfngrs How similar or different are IATF 16949 Vs. ISO 13485 IATF 16949 - Automotive Quality Systems Standard 0
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
J 3 Questions about Management Review - ISO 9001 and IATF 16949 Management Review Meetings and related Processes 4
QMMike ISO (in search of) IATF 16949 vs. TS 16949 changes summed up IATF 16949 - Automotive Quality Systems Standard 7
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
F IATF 16949 - Cl. 8.4.2.3 - Which type of suppliers could be exempt of ISO 9001 IATF 16949 - Automotive Quality Systems Standard 16
M ISO TS 16949 Transfer to another CB (Certification Body) IATF 16949 - Automotive Quality Systems Standard 3
K Top Executive Management ISO 9001:2015 and IATF 16949 Overview IATF 16949 - Automotive Quality Systems Standard 4
A ISO/TS 16949 - Sharing Certification Audit Report (NCR's) with the Customer IATF 16949 - Automotive Quality Systems Standard 8
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
Anerol C IATF or ISO TS 16949 rules about Scope of QMS IATF 16949 - Automotive Quality Systems Standard 7
Q Gap assessment on TL9000 with respect to ISO TS 16949 TL 9000 Telecommunications Standard and QuEST 3
Crimpshrine13 ISO/TS 16949 CBs & Auditors not following up on the schedules IATF 16949 - Automotive Quality Systems Standard 43
Crimpshrine13 ISO/TS 16949 vs. ISO 9001 IATF 16949 - Automotive Quality Systems Standard 1
M Exclusions clause 7.3 - Our organization doesn?t design products - ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
M Risk analysis - ISO/TS 16949 clause 7.2.2.2 IATF 16949 - Automotive Quality Systems Standard 2
K Can anyone recommend some good book explaining ISO/TS 16949 requirements? Book, Video, Blog and Web Site Reviews and Recommendations 9
K What are the current ISO/ TS 16949 Semiconductor Manufacturer Requirements IATF 16949 - Automotive Quality Systems Standard 12
C Special Characteristics - ISO/TS 16949 Clause 7.3.2.3 IATF 16949 - Automotive Quality Systems Standard 8
A We passed our ISO TS 16949 initial certification Covegratulations 3
F ISO/TS 16949 - Auditing supporting activities IATF 16949 - Automotive Quality Systems Standard 1
