ISO/TS16949 MSA Requirement for Product Testing - Gloss and Grain Pattern
P
ppalm
Hi
I am confused.:bonk:
It´s clear for me that you must do som kind of MSA on the evaluations teqnices specified in the controlplan.
Say that there is an item in the controlplan for "processing foil" that says that you measure the gloss 1:sample/each batch. In this case its verry clear for me that the "gloss meassuring" shall have some kind of MSA studie done.
But say that there is going to be an uppdate the foil for, example new grain/pattern. This new "status" is testet/validated according to an validation plan in an internal laboratory and the internal laboratory measured the grain.
Shall the internal laboratory make MSA studies for such items?
On wich item can i as an intarnal ISO/TS auditor make nonconformity note?
Best regards Patrik
cuadra - 2010
I am not sure that I follow your argument but:
1- MSA is composed of several studies that allow you to understand if your measurement system is suitable for the intended application.
a) Gage R&R
b) Linearity
c) Stability
d) Bias
2- A TS certified company that has a test measurement device defined in the control plan (i.e. measuring product characteristic to assure conformity)
needs to have objective evidence and records of gage suitability (i.e. The measurement system precision and accuracy need to achieve specific levels of conformance).
cuadra
P
ppalm
Ok: items in controlplan must be verified with som kind of MSA.
But where is the requirement for MSA on verification tests/measurements specified in an validationplan? This is also important even when the internal lab performes validations at early stages of an new/update of a product.
Or is so that an validation plan for etc "new grain on foil" is an controlplan for prelaunch ??
Regards. Patrik
This would be a good issue to take up with your customer. You should also be able to pose the question to your registrar. The primary requirement for MSAs is for gages on the control plan. However, different customers may have additional expectations.
Since you are now receiving answers, I will delete your duplicate post in the other forum.
BHobbs_Busche ISO/TS16949:2009 - MSA requirements for common gages IATF 16949 - Automotive Quality Systems Standard 5
B Nonconformance about MSA (Measurement Systems Analysis) in ISO/TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 9
G Is ISO/TS16949 Extension Available? IATF 16949 - Automotive Quality Systems Standard 3
B ISO/TS16949 In-House Non-Product Laboratory IATF 16949 - Automotive Quality Systems Standard 3
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
B Checklist for ISO/TS16949 for review and comment IATF 16949 - Automotive Quality Systems Standard 5
B ISO/TS16949 8.2.3.1 IATF 16949 - Automotive Quality Systems Standard 1
B ISO/TS16949 6.2.2.3 IATF 16949 - Automotive Quality Systems Standard 1
M Comparing the MMOG (v3 or v4) with ISO / TS16949 Customer and Company Specific Requirements 3
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
B How to maintain documentation under ISO/TS16949 Clause 4.2.3 IATF 16949 - Automotive Quality Systems Standard 8
M Is a separate ISO/TS16949 certificate required for an extension site? IATF 16949 - Automotive Quality Systems Standard 4
B Meeting the requirements of ISO/TS16949 Clause 6.2.2.3 IATF 16949 - Automotive Quality Systems Standard 4
E Gap Analysis for VDA 6.3:2010 and ISO/TS16949:2009 VDA Standards - Germany's Automotive Standards 5
N IATF Appeals on ISO/TS16949 Rules - 4th Ed. - Removal of Site Extensions IATF 16949 - Automotive Quality Systems Standard 2
S Will ISO TS16949 be impacted by ISO 9001:2015? IATF 16949 - Automotive Quality Systems Standard 3
R General ISO/TS16949:2009 Implementation Primer Needed IATF 16949 - Automotive Quality Systems Standard 2
L Product=Service in ISO 9001 and ISO 9001 Requirements vs. TS16949 Requirements IATF 16949 - Automotive Quality Systems Standard 2
S ISO 9001:2008 / ISO TS16949:2009 Comparison ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Can we be both TS16949 for Automotive Customers and ISO 9001 for other Customers IATF 16949 - Automotive Quality Systems Standard 8
F ISO/TS16949 (to become IATF 16949:2016) alignment to ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 79
W Is there a difference between TS16949 and ISO/TS16949? IATF 16949 - Automotive Quality Systems Standard 5
K ISO 26262 vs. TS16949 - Differences Other ISO and International Standards and European Regulations 4
C ISO/TS16949 Requirements for Internal Audit Trainer IATF 16949 - Automotive Quality Systems Standard 10
R These countries require ISO/TS16949 or ISO9001 to General Motors Mexico to export? IATF 16949 - Automotive Quality Systems Standard 5
Q Rule for ISO/TS16949 Triennial Audit of Multiple Sites (Remote Locations) IATF 16949 - Automotive Quality Systems Standard 2
S New to ISO/TS16949 - Our QS-9000 certification has expired IATF 16949 - Automotive Quality Systems Standard 3
A Which training companies are best for ISO/TS16949:2009 Auditor Training? Training - Internal, External, Online and Distance Learning 7
Q Differences Between TS16949 and ISO 13485 IATF 16949 - Automotive Quality Systems Standard 16
P Integrating ISO 9001, TS16949, ISO 14001 & NOSA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D TS16949 and ISO 9001 Lead Auditor (Assessor) Training Recommendations Training - Internal, External, Online and Distance Learning 9
Raffy ISO/TS16949:2009 Lead Auditor Course Expectations Training - Internal, External, Online and Distance Learning 5
QMMike Repercussions of letting your ISO/TS16949 RR date pass.... IATF 16949 - Automotive Quality Systems Standard 3
B ISO/TS16949:2009 Standard Should be ISO 16949:2009? IATF 16949 - Automotive Quality Systems Standard 4
Y Can ISO 9001 Lead Auditor lead all the other Audits (TS16949, ISO14001 & ISO13485)? General Auditing Discussions 6
D TS16949 Implementation - Can one implement TS 16949 without being ISO 9001 first? IATF 16949 - Automotive Quality Systems Standard 10
D ISO/TS16949 Internal Calibration Lab need to include Production Equipments IATF 16949 - Automotive Quality Systems Standard 26
B What is the difference between ISO 9001:2000 and TS16949? IATF 16949 - Automotive Quality Systems Standard 8
J ISO 17025 Accredited Suppliers from a QMI TS16949 Auditors Perspective? ISO 17025 related Discussions 2
S ISO/TS16949: 2002 Lead Auditor Training organised By SMMTIF. Training - Internal, External, Online and Distance Learning 7
D Process audit in compliance with ISO/TS16949 Process Audits and Layered Process Audits 3
P Does ISO/TS16949 registration include ISO 9001 registration? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S ISO/TS16949 Surveillance Audit Frequency IATF 16949 - Automotive Quality Systems Standard 10
H Where does the 16949 number in TS16949 come from? ISO Numbering System IATF 16949 - Automotive Quality Systems Standard 1
K How can I demonstrate meeting 5.6.2.1 and 6.3.1 of ISO/TS16949 requirements? IATF 16949 - Automotive Quality Systems Standard 2
E Intergrating TS16949 with ISO 14001 Management Systems ISO 14001:2015 Specific Discussions 8
P ISO/TS16949 Lead Auditor requirements - Transitioning from QS9000 to ISO/TS16949 General Auditing Discussions 6
E ISO / TS16949 Quality Manual example needed Quality Management System (QMS) Manuals 2
I AS9100 vs. QS9000 vs. ISO-TS16949 - Similarities and Differences AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
