ISO13485 Folder Structuring for Medical Device
itsasupernova
I am a fresh grad working for a Medical Device (Class II) company that is a startup.
I don't have previous experience in organizing the folders such as QMS, DMR, DHF etc..
From your current or previous experiences, how have companies organized their documentation?
blackholequasar
The Cheerful Diabetic
Hello and best of luck with your endeavors!
I think that it's a bit subjective, based on the organization of the QMS and how it interprets the standard. The way that my current company works, they have an SOP for each section of the ISO cert, though they aligned it such that their documentation matches what the standard outline was. I do NOT recommend doing this as the standard is prone to edition and the numbering will change.
DMRs, DHF, inspection reports, ect are all kept in product folder on a server here (each product line has its own folder), but I have seen people successfully use Sharepoint. Again, it all depends on how you guys are doing things there - if they are paperless or want hardcopy documents.
ChrisM
"From your current or previous experiences, how have companies organized their documentation? "
Sometimes.... very badly.
Unfortunately, you need some experience of using "organised" folders to find out the good and bad ways.
The way of organising them can also depend to a large extend on the number of employees regularly using the folders/documents, how often they have to be amended (constant product improvements and hence change notes, or very infrequent changes) etc etc.
As an example, for QMS documentation if you have a very small company with 1 product and maybe 1 dozen employees maximum, you may find that one electronic folder will be sufficient to hold all your procedures and work instructions, whereas for a multi-site company with thousands of employees, you will need a totally different way of organising the documents with numerous folders
Tidge
I would first suggestion recognizing that the QMS, the DMR(s) and the DHF(s) all serve different purposes, and have different constraints, so I wouldn't presume that there is a common organizational methodology for them. There are features that they may share (i.e. the concept of 'revision history') and elements may be subject to common processes (e.g. 'change control') but they are IMO quite different things.
QMS: Typically these are arranged in a hierarchy, with something like a Quality Policy (that rarely changes) at the top, with subordinate system policies below it, each with their own subordinate work instructions (that can include forms and/or templates). The QMS and its structure is established (at the top, by executive management) and employees train on the diverse parts as their job requires. Elements of the QMS are subject to change control... there is required training, but there should be no material impact when QMS elements change. Superseded QMS elements are never used again.
DMR: This is the recipe for making your marketable device. These are product structures with the apex of the structure being the finished good. Work instructions (and inspection procedures) will be part of the product structure; these are NOT part of the QMS... rather they are (generally) required by the QMS. The elements of the DMR are subject to revision control as 'things' change... could be acceptance criteria, could be supplier information, could be part swaps, could be process changes... these are 'design changes' so the DMR structure has to be established in such a way that supports design changes. Superseded DMR changes have to be available for review, because products with them are still going to be in the field! Changes to DMR almost always have material impact.
DHF: The DHF is essentially the recorded narrative of how a device got to market in the first place. Elements of a DHF are NOT subject to change... it is true that a new revision of some DHF element (think:, 'Rev B of a development plan') could be approved, but the 'Rev A' doesn't get tossed. If you want a 'neutral third party' (would be a NRTL, NB, or a regulator) you are essentially sending them the DHF for review. The DHF is 'alive', but it preserves the entire history of the life, whereas the QMS and DMR are pretty much only snapshots of the currently 'alive' system/good. There needs to be a system that controls how information gets into the DHF, but there is no formal need to consider life-cycle activities for the records inside a DHF.
John C. Abnet
Teacher, sensei, kennari
Good day @itsasupernova ;
The others have already provided you with some wise counsel.
If I may add another consideration....
Regardless of what your naming/structure is, I would recommend that your documents have a hierarchy and are established within unique "categories" . In other words, if your organization has....
- Procedures-
- SOP,s
- work instructions
- ES,s
- forms
- etc...etc...
I would recommend that your organization proceduralizes each of these categories by ...
a) DEFINING them (i.e. what is the purpose and application of each.
b) ESTABLISH a numbering scheme/naming convention for each.
e.g. may be SOP,s are number 4- ABC- 567, where ..
- "4" = the site/location
- ABC= the process
- 567 = numerical sequence
Proceduralizing this prevents "creep" (i.e 'other' categories/types of documents are randomly created and undermine the intended structure/foundation, and assists with navigation through documents.
Likewise establishing a SCALABLE numbering scheme/naming convention ensures that a logical name/pattern is applied as new documents are introduced and also assists with navigation through documents.
Hope this helps.
Be well.
FRA 2 FDA
I was in your shoes a year and a half ago. I was tasked with setting up our QMS and had never worked with one before. I think the most important things are 1) to make sure that your released/ approved documents are very clearly segregated from your archived revisions and working drafts under edit and 2) as John said above, to organize your documents in folders that make sense. I have folders for forms, lists, SOPs, policy docs and templates as well as for CAPAs and DCNs. The other bit of wisdom I can share is that it's hard to know how something will be set up to be functional if you haven't used it yet. We have restructured our QMS and DMR 3 times because as we used them more and more and our processes became more mature and had more history, the way we needed to use these systems changed. Don't be afraid to try something to get started and adjust as you go. Assuming this start up you work for is small (both documentation and people), changing/adjusting should be relatively easy.
S Expiry and re-certification of ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 3
J Document hierarchy for Process mapping for ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
D 6 mandatory documents for ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
L ISO13485:2016 and Subsidiary Company ISO 13485:2016 - Medical Device Quality Management Systems 4
C ISO13485 scope as Legal Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 2
L Non Applicability of Clauses in ISO13485 for Medical Devices Medical Device and FDA Regulations and Standards News 4
S ISO13485:2016 7.3.9 design and development change ISO 13485:2016 - Medical Device Quality Management Systems 3
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
B ISO13485 Risk managment implementation for suppliers ISO 14971 - Medical Device Risk Management 2
chris1price ISO13485: 2016 Amendment coming? ISO 13485:2016 - Medical Device Quality Management Systems 13
B ISO13485 Standard Documentation Packages ISO 13485:2016 - Medical Device Quality Management Systems 2
J The necessity and benefit of ISO13485:2016 for a manufacturer of class I devices ISO 13485:2016 - Medical Device Quality Management Systems 3
F Is USB-IF standard compliant with ISO13485? Medical Device and FDA Regulations and Standards News 3
M ISO13485:2016, MDSAP and Internal Audits ISO 13485:2016 - Medical Device Quality Management Systems 9
A When will ISO13485 Update be Released? EU Medical Device Regulations 1
J Do Software Subcontractors need to be ISO13485 compliant in the EU? EU Medical Device Regulations 3
A Is it mandatory to obtain ISO13485 certificate prior to CE marking? EU Medical Device Regulations 8
M Address change for a company with CE/ISO13485 EU Medical Device Regulations 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
K ERP System Software Validation - ISO13485 2016 4.1.6 Design and Development of Products and Processes 11
N Can a (class I) medical device be manufactured in a GMP certified site with no ISO13485? EU Medical Device Regulations 18
V Iso13485 certification vs CE technical audit ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO13485:2016 name and ownership changes questions ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO13485:2016 7.5.6 Process Validation Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 1
D Customer Audit Finding ISO13485:2016 7.6 ISO 13485:2016 - Medical Device Quality Management Systems 7
CPhelan Do you require MDSAP for CE Marking of a Medical Device or is ISO13485:2016 with clinical data sufficient? CE Marking (Conformité Européene) / CB Scheme 6
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S PPT for ISO13485:2016 Employee Training (Request) ISO 13485:2016 - Medical Device Quality Management Systems 0
qualityegghead ISO13485:2016 4.2.4 Control Of Documents - Lifetime of the Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 3
S Nonconformance to a Note in ISO13485 clause 6.2 Human Resources Effectiveness ISO 13485:2016 - Medical Device Quality Management Systems 13
C ISO13485 exclusions for design and automation company ISO 13485:2016 - Medical Device Quality Management Systems 2
R ISO13485/ISO9001 Convenient Document Management System Document Control Systems, Procedures, Forms and Templates 3
S ISO13485 2016 - What the upshot is of failing to upgrade on a medical diagnostic device ISO 13485:2016 - Medical Device Quality Management Systems 1
R ISO9001 & ISO13485 QMS for 2 types of products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M ISO13485 Documentation packs (manual, procedures, forms etc) ISO 13485:2016 - Medical Device Quality Management Systems 3
H ISO13485:2016 Measurement System - Methods General Measurement Device and Calibration Topics 4
C ISO13485/9001 clause 6.3 (Infrastructure) ISO 13485:2016 - Medical Device Quality Management Systems 3
G ISO13485:2016 Cl. 7.5.1 - Production and Service Provision - Medical Device Repairs ISO 13485:2016 - Medical Device Quality Management Systems 3
M Looking for Cross reference of AS9100:2016 to ISO13485 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M ISO13485:2016 - Exemption vs. Not Applicable ISO 13485:2016 - Medical Device Quality Management Systems 16
K Implementing ISO13485:2016 in the Middle of a New Device Project ISO 13485:2016 - Medical Device Quality Management Systems 1
T ISO13485:2016 Clause 6.3 - Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 1
R ISO13485:2016 Clause 4.2.3 - Changes in Technical File Requirements ISO 13485:2016 - Medical Device Quality Management Systems 18
T ISO13485 cert expired - Product still CE Marked CE Marking (Conformité Européene) / CB Scheme 1
V Revised ISO std vs ISO13485:2003 - Help Please!!! ISO 13485:2016 - Medical Device Quality Management Systems 4
C Is there a strong market out there for ISO13485 certification? ISO 13485:2016 - Medical Device Quality Management Systems 11
B Must a Design Outsourcing Company have ISO13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
L ISO13485 past practice labeling vs customer requirement Other ISO and International Standards and European Regulations 2
S CMDCAS ISO13485 - Bilateral agreement with SAI global to conduct Certification Audits ISO 13485:2016 - Medical Device Quality Management Systems 7
