ISO13485 Incoming Receiving Parts Verification
cnrestina
Hello all,
I need help understanding what inspection results need to be retained as records. A company uses an AQL for inspecting incoming bar stock. They will "inspect" the AQL level but only record the high and low on the receiving inspection report and throw the other results out. Is this a violation of the standard? Is this a violation of 21CFR part820? I am getting conflicting information and would like to run it by the knowledgable people of the forum. Thank you for your time and consideration!
somashekar
NO
NO
If that is the way you have set your inspection record to be, and it has been giving you necessary effectiveness, keep maintaining it.
So you are not using the other results for any statistical analysis. You may not need it from the PASS / FAIL identification viewpoint.
May I ask what are the parameters the "inspect" contains, and what you mean by high and low.
Marcelo
In cases like this, my suggestion always is:
- Perform an analysis of the information: do you need the information to show compliance to anything? Do you need it for traceability purposes?
- If the answer is that you need, you will need to keep the results.
_ If the the answer is no, don?t keep the results, but record the analysis and decision, because probably someone will ask.
cnrestina
NO
NO
So you are not using the other results for any statistical analysis. You may not need if from the PASS / FAIL identification viewpoint.
Thank you for reply! No results are used in a statistical analysis.
The parameters are dimensions of the bar stock width/thickness/height with +/- according to drawing. They use the highest result and the lowest result and record those results onto the inspection report. My debate is using an AQL, taking the samples inspected, and only recording the highest and lowest results on report. Why use the AQL if you are only recording 2 results? How do we know that the inspector actually looked at 13 pieces from a 50 piece lot (AQL=1.0)?
cnrestina
Thank you for the reply. The information gained and written on the incoming inspection report ensures purchased product meets specified purchase requirements.
Ronen E
Problem Solver
Moderator
Pretty strange to me. AQL decision making is based on numbers of "pass'es" and "fail's". If only min and max are recorded, there's no way of challenging or verifying the inspection retrospectively. This basically means this process is hardly auditable and hence lacks a feedback loop, which makes it hard to improve or at least maintain at an acceptable level.
It all comes down to how important this process is in the overall picture.
Cheers,
Ronen.
somashekar
Your AQL inspection record will mention that the random samples of 13 # were verified from a 50 # lot.
The record will also have the lot decision status. PASS or FAIL
Now it is entirely your requirement to record the individual 13 sample values, or just the High and Low or nothing at all.
As long as the verification activity ensures that the purchased product meets specified requirement, you are good.
What comes into the record is your risk based decision.
U
uhohraggy
I'm surprised at most of these responses. If your AQL said you should measure 13 and you only recorded the measurement of the high and low, you have no evidence that you measured the other 11 or that they were in fact in between the high and low recorded. All results should be documented as the golden rule applies (If it isn't documented it didn't happen)
Marcelo
The "golden rule" works well if you don?t know what you are doing or if you want to be on the very high end of the safer side. Unfortunately, this creates bloated systems and a lot of paperwork that serves nothing.
From a quality management standpoint, everything should first be analyzed for need and then defined as really required.
The trend on a risk-based approach is really this, first analyze stuff, then do whatever you need after the analysis. Hopefully this will help create streamlined systems.
U
uhohraggy
You are correct since this is an ISO board. I deal with US marketed products only. I can tell you the golden rule applies to the FDA and they would find this deficient without question.
M ISO13485:2016, MDSAP and Internal Audits ISO 13485:2016 - Medical Device Quality Management Systems 8
A When will ISO13485 Update be Released? EU Medical Device Regulations 1
J Do Software Subcontractors need to be ISO13485 compliant in the EU? EU Medical Device Regulations 3
A Is it mandatory to obtain ISO13485 certificate prior to CE marking? EU Medical Device Regulations 8
M Address change for a company with CE/ISO13485 EU Medical Device Regulations 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
K ERP System Software Validation - ISO13485 2016 4.1.6 Design and Development of Products and Processes 8
N Can a (class I) medical device be manufactured in a GMP certified site with no ISO13485? EU Medical Device Regulations 18
V Iso13485 certification vs CE technical audit ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO13485:2016 name and ownership changes questions ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO13485:2016 7.5.6 Process Validation Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 1
D Customer Audit Finding ISO13485:2016 7.6 ISO 13485:2016 - Medical Device Quality Management Systems 7
CPhelan Do you require MDSAP for CE Marking of a Medical Device or is ISO13485:2016 with clinical data sufficient? CE Marking (Conformité Européene) / CB Scheme 6
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S PPT for ISO13485:2016 Employee Training (Request) ISO 13485:2016 - Medical Device Quality Management Systems 0
qualityegghead ISO13485:2016 4.2.4 Control Of Documents - Lifetime of the Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 3
S Nonconformance to a Note in ISO13485 clause 6.2 Human Resources Effectiveness ISO 13485:2016 - Medical Device Quality Management Systems 13
C ISO13485 exclusions for design and automation company ISO 13485:2016 - Medical Device Quality Management Systems 2
R ISO13485/ISO9001 Convenient Document Management System Document Control Systems, Procedures, Forms and Templates 3
S ISO13485 2016 - What the upshot is of failing to upgrade on a medical diagnostic device ISO 13485:2016 - Medical Device Quality Management Systems 1
R ISO9001 & ISO13485 QMS for 2 types of products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M ISO13485 Documentation packs (manual, procedures, forms etc) ISO 13485:2016 - Medical Device Quality Management Systems 3
H ISO13485:2016 Measurement System - Methods General Measurement Device and Calibration Topics 4
C ISO13485/9001 clause 6.3 (Infrastructure) ISO 13485:2016 - Medical Device Quality Management Systems 3
G ISO13485:2016 Cl. 7.5.1 - Production and Service Provision - Medical Device Repairs ISO 13485:2016 - Medical Device Quality Management Systems 3
M Looking for Cross reference of AS9100:2016 to ISO13485 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M ISO13485:2016 - Exemption vs. Not Applicable ISO 13485:2016 - Medical Device Quality Management Systems 16
K Implementing ISO13485:2016 in the Middle of a New Device Project ISO 13485:2016 - Medical Device Quality Management Systems 1
T ISO13485:2016 Clause 6.3 - Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 1
R ISO13485:2016 Clause 4.2.3 - Changes in Technical File Requirements ISO 13485:2016 - Medical Device Quality Management Systems 18
T ISO13485 cert expired - Product still CE Marked CE Marking (Conformité Européene) / CB Scheme 1
V Revised ISO std vs ISO13485:2003 - Help Please!!! ISO 13485:2016 - Medical Device Quality Management Systems 4
C Is there a strong market out there for ISO13485 certification? ISO 13485:2016 - Medical Device Quality Management Systems 11
B Must a Design Outsourcing Company have ISO13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
L ISO13485 past practice labeling vs customer requirement Other ISO and International Standards and European Regulations 2
S CMDCAS ISO13485 - Bilateral agreement with SAI global to conduct Certification Audits ISO 13485:2016 - Medical Device Quality Management Systems 7
Q Multiple Quality Standards - AS9100 and ISO13485/9001 Cross Reference Matrix Quality Manager and Management Related Issues 3
Q ISO13485 Section 7.5.1.1 and 7.5.2.1 for a Distributor ISO 13485:2016 - Medical Device Quality Management Systems 2
W Setting up from scratch - Looking for help (ISO9001 / ISO13485) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Outsource Production Line need ISO13485 Certificate ISO 13485:2016 - Medical Device Quality Management Systems 1
somashekar Clause 7.5.5. as in the text and in the Annex B (ISO13485:2003) ISO 13485:2016 - Medical Device Quality Management Systems 1
U Do we have to have foreign legal documents? (ISO13485 4.2.3 document control) ISO 13485:2016 - Medical Device Quality Management Systems 3
0 Medical Device Distribution Centre and Implementing ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
C Writing a Sterilization Procedure when the Process is Subcontracted - ISO13485 Quality Management System (QMS) Manuals 1
J ISO13485 Certification Scope - Registering a Subset of our Products ISO 13485:2016 - Medical Device Quality Management Systems 9
J ISO13485 Clause exclusions for a Medical Software Company ISO 13485:2016 - Medical Device Quality Management Systems 9
P How to streamline different documents in a multi plant ISO13485 QMS ISO 13485:2016 - Medical Device Quality Management Systems 8
D FDA Guidance on Interim Use of ISO13485 for Medical Device Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 3
S Implementing ISO13485 in a new startup company - Neurological devices ISO 13485:2016 - Medical Device Quality Management Systems 12
