ISO9001:2015 9.1.2 - Customer Satisfaction Feedback
ISO_Man
Regarding the requirement for organizations to obtain customer feedback, can this be satisfied by providing the opportunity for customers to provide feedback? I'm wondering of one is considered out of compliance if, for example, only 25% of customers provide feedback through scorecards, etc.? Essentially we cannot force customers to provide feedback, so if they choose not to do so, how accountable are we as the product/service provider?
Sidney Vianna
Post Responsibly
Welcome to The Cove. Your organization can't be penalized if most customers suffer from survey fatigue and don't respond to traditional satisfaction feedback requests. On the other hand, if your organization is truly interested in customer feedback, one can be creative in developing alternative methods to seek the information.
This issue has been discussed many times here, so, if you do a search, I am sure, you will be able to find previous discussions. Scroll down the page for similar discussions, to start with. Another way to find similar discussions: I added 3 tags to the discussion (look at the top of the page, under the title of the thread; if you click on customer satisfaction or customer satisfaction survey tags, other threads with those tags will be listed.
Good luck.
It's very normal for there to be a low response rate for surveys. Don't forget that you are NOT required to measure customers' satisfaction - but evaluate their perception (paraphrasing). If they keep placing repeat orders and you have few complaints or low #s of negative feedback, you can consider that acceptable. Of course, maybe changing HOW you survey customers can be changed,,,,
ISO_Man
Thanks - but 9.1.3 says that one of the things to be evaluated is "the degree of customer satisfaction."
Yes, the "degree" is derived from perception... It wouldn't contradict the 9.1.2 requirements which states the word "degree" as well... Think of it like a trip to a restaurant. You ate the food, maybe leaving some items on the plate only partially touched/tasted and on the way out the staff ask you "Was everything OK"? What was the degree to which you were satisfied?
Pjservan
Another way to defend your point is if you are receiving 25% of customer satisfaction data from scorecards but these translate to be from your largest or more strategic customers, then you can argue that your data is meaningful. You do not need to be sending surveys out every year either, specially if you are receiving scorecards. Surveys can be useful but unfortunately they are over use in the attempt to collect data and misuse once the data becomes available.
somashekar
While I believe customer satisfaction is always about Customer telling his satisfaction levels., the standard (in NOTE) gives you examples of how customer perception levels can be monitored. As you can see, some are direct and some are indirect methods.
While the 9.1.2 heading says Customer Satisfaction, the body of the 9.1.2 never uses the word satisfaction. Then again in 9.1.3 b) you need to evaluate the degree of customer satisfaction.
So your perception of Customer satisfaction has to be evaluated by any which way you choose, direct / indirect or a combination. Its not necessary that customer always needs to provide feedback through scorecard.
When the direct does not work for you, go the indirect way.
Also note that what the NOTE tells as examples in the standard are not exhaustive. You business can have your unique method.
L Customer Waiver in ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M How to answer ISO9001:2015 audit finding of old revisions of documents being used? Document Control Systems, Procedures, Forms and Templates 8
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S ISO9001:2015 Clause 9.1 - What the external auditor will look at? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S ISO9001:2015 6.3 - Planning of Changes - OFI from auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
L Is writing out the ISO9001:2015 standard full name a requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
E Interesting Discussion Was this the fastest ever stage 2 ISO9001:2015 audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 76
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod ISO9001:2015 Cl. 9.1.1 and 9.1.3 evidenced with only improvement actions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Effect of ISO9001 2015 transition on ISO IEC 80079-34 Other ISO and International Standards and European Regulations 3
A ISO9001:2015 Process Matrix with clauses General Auditing Discussions 13
S ISO9001:2015 Cl. 4.4.1 - What Processes Do I Need Documented ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q ISO9001:2015 Cl. 6.1 - What evidences of risk addressing is needed? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B Bare Bones/Under the Radar ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Is ISO9001:2015 required for AS9100:2016 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Icy Mountain ISO9001:2015 & IATF 16949:2016 Gap Analysis Tool IATF 16949 - Automotive Quality Systems Standard 7
D Internal Audit During the Transition Period from ISO9001:2008 to ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Does ISO9001:2015 require any specific "processes"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N ISO9001:2015 clause 7.1.5 "Resources" (Formerly "Equipment") ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Icy Mountain ISO9001:2015 Upgrade Diary ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO9001:2015 and ISO14001:2015 Readiness/Self Evaluation Checklists wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Understanding ISO9001:2015 - 8.3: Design and Development of Products and Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO9001:2015 - Clause 7.5.2 - Requirements for Creating & Updating Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Process Map Transition from ISO9001:2008 to ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Auditor Training Materials Training - Internal, External, Online and Distance Learning 2
M ISO9001:2015 Clause 8.4 Control of External Processes and Purchased Goods & Materials ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
L Corporate Manual - Global Multi-Site ISO9001:2015 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A ISO9001:2015 comparison with AS9100:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Auditing Clause 5 - Leadership in ISO9001:2015 Internal Auditing 4
S Informational ISO9001:2015 Process Interactions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S ISO9001:2015 Section 4.4.1 - Support Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Risks involved in requesting Cert to ISO9001:2015 right when released ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Changes in ISO9001:2015 to the requirements for a management representative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L Lean in the ISO9001:2015 World Lean in Manufacturing and Service Industries 1
A Has anyone made an ISO9001:2015 vs. ISO9001:2008 Matrix ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S ISO9001 QMS: Quality Manual Examples & Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
T Transition from ISO9001 to AS9100D: O&G to Aerospace AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Pau Calvo Quality Management process is mandatory in ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
I Form templates for software (iso9001) Document Control Systems, Procedures, Forms and Templates 0
T COVID, Furlough and ISO9001 Surveillance Audit Coffee Break and Water Cooler Discussions 2
D ISO9001 for one man company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S What's meant by ISO9001 clause 8.7 non conforming output? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Calibration: Conforming to ISO9001 Requirements General Measurement Device and Calibration Topics 6
H Communication plan according to ISO9001 - Pharmaceutical field Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
N Is consultant prohibited in ISO9001 audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
