Food for thought maybe this may help........
Hi Eddie - I know you weren't asking for a critique of your flow chart, but I have a few comments you might consider in the interest of improvement:
1) The middle column in your flow chart is labeled
Process Activity but none of the headers in the column include activities. It looks like the process activities have been put under the
Input header. Inputs and process activities are different things. You might consider adding another
Process Activities header to list the activities for each process to avoid confusion, then the
Inputs header will only have inputs in it.
ISO 9000:2015 said:
3.4.1
process
set of interrelated or interacting activities that use inputs to deliver an intended result
2) In my opinion the real interactions between processes deal with the outputs and inputs. The outputs of each process should be inputs to other processes or to the customer. Similarly, the inputs to each process should be outputs of other processes or the customer. As I look at your flow chart I don't see very many inputs/outputs that line up with each other. For example, (in my opinion) the main output of the Purchasing process is purchased product. Purchased product is one of the main inputs to the Production process.
ISO 9000:2015 said:
Note 2 to entry: Inputs to a process are generally the outputs of other processes and outputs of a process are generally the inputs to other processes.
3) There seems to be a disconnect in some cases with the
Measurement and the
Reported in MR as metrics. For example the Production Measurement is "Process Performance and Product Conformity, RGA" but it's reported in MR as "On Time Shipments Average Days Late."
