I
Re: ISO9001 certification for an entire group?
When developing the QMSs for 8 organizations, it might be a good time to consider the volume of QMS documentation that would result, depending on the approach that is used. So, I hope this discussion is not entirely off-topic. One tasked with implementing 8 systems might be interested in how the approach chosen impacts how much documentation is left to control. I hope not to belabor the point further in this thread, however, beyond the following.
Using the process approach, the right number of procedures for each company is the number that should be written--based on the processes of the organization. Using the elemental approach, the same twenty-odd procedures might be adopted by each organization. (Or, if you really just want the certificate, you only need six documented procedures and they could be the same for all 8 companies. But this is not the right solution from the perspective of quality assurance.)
Based upon the approach you take, you will need:
160some QMS procedures (based upon the standard, assuming each company operates its own QMS; bear in mind this approach invites more layers of documentation to address the real processes--the ones being operated before ISO 9000 came along), or
OR
using the process approach, here are those numbers:
If we assume each organization operates 6 realization processes (for example: Sales, Design, Procurement, Production, Shipping and Receiving, and one more unnamed realization process for good measure), and each has 6 supporting procedures, that's a dozen procedures in each company. That's 96 procedures in total for all the companies. And these procedures actually reflect what you do, and they won't change much due to future changes in the standard--since your QMS is then based upon your own processes, rather than merely being a collection of documents pandering to the standard.
OR
