ISO9001 in Quality Control Department - Control of Nonconforming Product
P
PG9001
Hi everyone!
I just started my first job at a big eletronic and home appliances retailer.
I was asked to organize the documentation of the quality control department. Well, not the entire department but the part that deals with the team that do the control of reception, devolution, wharehousing, etc.
To do this, I'm folowing ISO9001:2008 requirements. I know it's not the kind of ISO 9001 implementation you are used to see around here but just so you know, I dont want the certification, just to be in accordance with the Standards.
Having said that, I already did the quality manual, operational procedures, works instructions. Now I want to do the ISO's mandatory procedures and I'm having trouble adapting the Control of Nonconformities to my case! First things first: what's a nonconformity in a quality control process? The technicians allowing damaged appliances to enter the wharehouse?
:thanx:
insect warfare
QA=Question Authority
Re: ISO9001 in Quality Control Department
Welcome to the Cove, PG9001 :bigwave:
In ISO 9000:2005 (which contains the definition of terminology within ISO 9001:2008) the definition of nonconformity is simply a "non-fulfillment of a requirement". In comparison, the definition of defect is "non-fulfillment of a requirement related to an intended or specified use".
In most cases, nonconformity can apply to anything (process, function, product, etc.), while defect is mainly applied specifically to a product.
In the case of technicians allowing damaged appliances to enter the warehouse, you have nonconforming product under your control. This is where paragraph 8.3 (Control of Nonconforming Product) is considered applicable. It requires that you identify and control such product so that it doesn't leave your facility in a manner that you didn't intend to (such as a defective range-top oven ending up as someone's purchased item without taking some kind of action, like repair or rework, to make that range-top oven conform to specifications required by the original equipment manufacturer).
Since some range-top ovens cannot be repaired or reworked (as in the case of scrap), your facility still has an obligation to keep it from ending up in the hands of an actual end-user. There also may be legal ramifications if this actually happens, so it is absolutely critical that your processes can successfully route that NC range-top oven as was planned.
Basically, if product doesn't conform, you must know what it is, and you must have controls in place to keep it from being treated exactly like good product (unless you have some sort of approved deviation or waiver to use the product as-is, such as the case with used appliances). This is the bulk of what 8.3 intends for you to do.
Brian :rolleyes:
insect warfare
I should also add that you must have appropriate controls in place should NC product be discovered after delivery or after use has started. So even though it is physically out of your hands, you still must have procedures to handle and disposition that product, especially where legal ramifications are likely (such as product recalls).
Brian :rolleyes:
S ISO9001 QMS: Quality Manual Examples & Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
Pau Calvo Quality Management process is mandatory in ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Auditing ISO9001/AS9100 7.3 Design and Development Quality System Effectiveness Manufacturing and Related Processes 12
J ISO 13485 and ISO9001 Quality Management Implementation Start ISO 13485:2016 - Medical Device Quality Management Systems 6
J Does Every Staff need to read the ISO9001 Quality Manual from Cover to Cover? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
H How to integrate ISO/TS 16949 & ISO9001 Quality Systems - Plastic Injection Mold IATF 16949 - Automotive Quality Systems Standard 7
K How and where to start as Quality Management Representatives QMR (ISO9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Communicating Quality Objectives - Minor Nonconformance AS9100B/ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Quality Table Top Exercise - ISO9001 Awareness Training to the operators Training - Internal, External, Online and Distance Learning 13
Q Meeting requirements of Cl 5.4.1, ISO9001: 2008 (Quality Objectives) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Section 7.5 of ISO9001:2000 for a Quality Manual - Charity organisation Quality Management System (QMS) Manuals 9
U New to the Quality team - ISO9001 Audit Scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Supplier of my Supplier's Quality - Distributor is not ISO9001 certified Supplier Quality Assurance and other Supplier Issues 16
T Is there a minimum retention time for any of the Quality Records? ISO9001 Records and Data - Quality, Legal and Other Evidence 8
Colin Quality Plan for construction company - Certification to ISO9001, ISO14001 and OHSAS Document Control Systems, Procedures, Forms and Templates 3
S Quality for Hearing Impaired Run Restaurant - Food Services - ISO9001 Principles Service Industry Specific Topics 1
T ISO question at interview - Do you think ISO9001 is really about quality? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO9001:2000 QMS (quality management system) implementation in Banks Service Industry Specific Topics 13
Q Quality Manual vs. ISO9001:2000 Standard - Quality Manual doesn't address all of 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Identification of Quality Records (ISO9001 - 4.2.4) - How? Records and Data - Quality, Legal and Other Evidence 32
R ISO Communication Board - Pre-printed ISO9001 posters, quality slogans Misc. Quality Assurance and Business Systems Related Topics 1
J Framework for Establishing Quality Objectives - ISO9001 Clause 5.3 Quality Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V ISO9001:2000 Quality Work Instructions & Forms - Seeking Templates and Examples Document Control Systems, Procedures, Forms and Templates 41
M Stating the ISO9001 Version / Edition in our Quality Manual QS-9000 - American Automotive Manufacturers Standard 8
J The Implications of ISO9001 - Quality Improvements vs. Customer Pressure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
L IATF and ISO9001 IATF 16949 - Automotive Quality Systems Standard 15
D Deltas ISO9001 to TL 9000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K ISO9001:2015 clause 8 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
G Legal & Reg. Requirements - ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
S ISO9001 Major for repeat issue. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
M Management Review Inputs ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Exclusions to ISO9001:2015 Manufacturing and Related Processes 9
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M How to answer ISO9001:2015 audit finding of old revisions of documents being used? Document Control Systems, Procedures, Forms and Templates 8
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
T Transition from ISO9001 to AS9100D: O&G to Aerospace AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
I Form templates for software (iso9001) Document Control Systems, Procedures, Forms and Templates 0
T COVID, Furlough and ISO9001 Surveillance Audit Coffee Break and Water Cooler Discussions 2
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
D ISO9001 for one man company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S What's meant by ISO9001 clause 8.7 non conforming output? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G Calibration: Conforming to ISO9001 Requirements General Measurement Device and Calibration Topics 6
H Communication plan according to ISO9001 - Pharmaceutical field Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
S ISO9001:2015 Clause 9.1 - What the external auditor will look at? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Is consultant prohibited in ISO9001 audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
S ISO9001:2015 6.3 - Planning of Changes - OFI from auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
I ISO9001:2015 9.1.2 - Customer Satisfaction Feedback ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
