ISO9001 Process Organisation Diagram - Does this make sense to you?
Brian Hunt
HI
I'd be grateful for comments on how well the logic of the attached diagrams work. I've started with the idea of the customer to customer chain being a specific viewpoint on the QMS so the diagram is similar to an IDEF0 one with controls and constraints going into the top and resources into the bottom of the chain.
Brian
HI
Brian
A couple of observations--I think the third page--the actual process flowchart--should be able to stand alone. I find diagrams like the one on your first page confusing and mostly non-helpful. This is not your fault-- I think the problem lies in trying to get too much information on a single page, and also trying to convey information that might not need to be conveyed, and this type of diagram is endemic.
By contrast, the process flowchart is very nicely executed. The only thing I see, which is fairly minor, is that an apparent endless loop is created when submitting estimates to customers, and revising them if the estimate is rejected. There's probably a point at which you'll decide that you can't revise any further, and that's not accounted for.
Q
Quality_Steve
It's evident you have put a lot of time and thought into this diagram. :applause:
One thing I did see missing was 4.2.3 Document Control.
Brian Hunt
Thanks Jim - good points made. I might ditch page one or put in in a process map bin, away from the mainstream quality documentation.
Agreed - I do need criteria to exit out of that feedback loop. I'll think on that.
Brian
Brian Hunt
Steve - thanks for your kind comments. Re the document control - I've left that out of the main customer to customer flow as I see this as a QMS maintenance task. I'll add a note in the text to make that clear.
Brian
Pau Calvo Quality Management process is mandatory in ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A ISO9001:2015 Process Matrix with clauses General Auditing Discussions 13
C Process Map Transition from ISO9001:2008 to ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Informational ISO9001:2015 Process Interactions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
Y The challenge of why should we have ISO9001 and process audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Recycling Procedure (ISO9001) - Do I need a documented process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T VDA 6.3 Process Audit - but we're ISO9001:2008 VDA Standards - Germany's Automotive Standards 7
Y ISO9001 Implementation for Business Process Outsourcing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T What is clause ISO9001:2008 for Acc/Rej Criteria and Verifying QA process Internal Auditing 2
Q Outsourced Process - Why certain "processes" are not included - ISO9001-2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
J Software Development Process - How ISO9001 relates to Software Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q AS9100 Certification Process - It would automatically include ISO9001 Registration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Process Matrix to cover all ISO9001 Clauses Internal Auditing 8
B Process Flows/Turtles and ISO9001 - How and when they should be used ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Special Process Validation - ISO9001 Clause 7.5.2 - How do I go about it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
ScottK What defines the need for the ISO9001 Design & Development process? Design and Development of Products and Processes 15
M When is the ISO 9001 Surveillance Audit? Certification process for ISO9001:2000 General Auditing Discussions 4
S Welding - Is welding always a special process per ISO9001:2000 Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
O Training on ISO9001 Process Approach Training - Internal, External, Online and Distance Learning 13
L Necessary to Write a Process Capability Procedure? ISO9001 Capability, Accuracy and Stability - Processes, Machines, etc. 13
D Is the Equipment for Measuring Process Parameters covered by ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
L Describing the Process - ISO9001:2000 - Flow charts? Other documents? Document Control Systems, Procedures, Forms and Templates 14
Sidney Vianna Official ISO Interpretations - A Formal Process for ISO9001 Interpretation Requests ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
C Training Process Map - An ISO9001:2000 Requirement? Process Maps, Process Mapping and Turtle Diagrams 31
S ISO9001 Major for repeat issue. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
M Management Review Inputs ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Exclusions to ISO9001:2015 Manufacturing and Related Processes 6
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M How to answer ISO9001:2015 audit finding of old revisions of documents being used? Document Control Systems, Procedures, Forms and Templates 8
S ISO9001 QMS: Quality Manual Examples & Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
T Transition from ISO9001 to AS9100D: O&G to Aerospace AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
I Form templates for software (iso9001) Document Control Systems, Procedures, Forms and Templates 0
T COVID, Furlough and ISO9001 Surveillance Audit Coffee Break and Water Cooler Discussions 2
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
D ISO9001 for one man company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S What's meant by ISO9001 clause 8.7 non conforming output? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G Calibration: Conforming to ISO9001 Requirements General Measurement Device and Calibration Topics 6
H Communication plan according to ISO9001 - Pharmaceutical field Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
S ISO9001:2015 Clause 9.1 - What the external auditor will look at? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Is consultant prohibited in ISO9001 audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
S ISO9001:2015 6.3 - Planning of Changes - OFI from auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
I ISO9001:2015 9.1.2 - Customer Satisfaction Feedback ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
L Is writing out the ISO9001:2015 standard full name a requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
R ISO13485/ISO9001 Convenient Document Management System Document Control Systems, Procedures, Forms and Templates 3
E Interesting Discussion Was this the fastest ever stage 2 ISO9001:2015 audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 76
R ISO9001 & ISO13485 QMS for 2 types of products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
