ISO9001 to QS9000 Compliance Problems
Marc
Fully vaccinated are you?
1. FIFO as in regards to revision control. We currently do not use FIFO in our incoming inventory. Parts from suppliers are often mixed (castings, etc). Is this going to be a problem?
Typically yes. Can you explain why FIFO would not benefit you? YHou're going to have to be able to show that the parts are not age sensitive. Maybe all your projects are less than a year and then all parts are used up. No FIFO will be a difficult arguement to gain acceptance of.
2. APQP and R&D. I want to write my procedure such that R&D is a "black box" and is not subject to APQP until we decide to actually manufacture the product. Problem with this idea?
R&D is tyically not highly structured. To some degree neither is design. But both have some basic 'sequences' they go thru. As far as I understand it R&D can be excluded from the registration scope which woiuld solve your problem.
3. Operator certification. I interprete QS to say that machinist, operators, assemblers, etc., should be certified to handle the product. Yes/No? Best way to comply with existing workforce?
You have to decide what should be certified and what should not. If every company certified every assembler, every operator and every machinist - well, things would be more expensive. For some asides info see: Elsmar.com/ubb/Forum1/HTML/000259.html and Elsmar.com/ubb/Forum2/HTML/000188.html and Elsmar.com/ubb/Forum2/HTML/000110.html and http://Elsmar.com/ubb/Forum2/HTML/000063.html
4. Now the really difficult one: Order entry. Our order entry is EDI. The customer sends it into the system directly. Currently no human review. They create the due date. Sometimes, we can't hit their required date and have to change it. Would this be missing the ship date? What if we get customer approval? Example: Original customer date is 3/15/00 - we change the date to 4/1/00 and notify the customer. If it ships on 4/1/00 did we hit the date? Or is it still counted as late since we didn't hit the original due date of 3/15/00?
I'll let someone else attach this one.
Last question: Does anyone have a "rule of thumb" number for QS consulting? If I want to get some consulting help, what is a rough, ball park number, to plug into the budget? $x per day, per hour, etc.?
Of course, if you're looking for a consultant, you want me !!
I generally charge between US$600 to US$1250 a day. Depends upon the contract and such. You want me to stop in for a day it's gonna be near US$1250. You have a project, 650 to 850 a day. I'm open to negotiation.
Other consultants are welcomed to reply in this thread with their 'typical' fees, by the way.
Marc
By the way, considering TS16949, it QS9000 going to be relevant to you?
BWoods
Thanks for all the quick info, Marc.
As for TS vs QS. The trucking industry runs behind the auto. They are still talking QS and wanting that. It will probably be 2 years before they are making much noise about TS. Further, I think we could get QS quicker and eaiser - then look up at up-grading to TS.
BTW: We don't need FIFO for the material. Shelf life is not a problem for us. The only problem is I have seen auditors "back door" FIFO with revision control. Our stock turns average 10 per year, plus it is mostly metal and non-perishables.
At other companies, I am use to keeping revision control in compliance with FIFO. In an environment with no FIFO, that is hard to do.
Bill
BWoods
We are an OEM for the trucking industry. Currently certified to ISO-9001 and moving to QS-9000 by Dec. 2000. I have noted the following major problems in our systems and would welcome any help or suggestions:
Lots of questions, I know. Thanks for any and all help.
PS BIG management presentation on this being given 3/15/00.
Thanks,
Bill
Q QS9000 Tier 2 for 12 Years - Transitioning to ISO9001 - Where do I start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
Raffy ISO9001:2000 Transition from QS9000 - Or Both? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Registration upgrade ISO9001 to QS9000 QS-9000 - American Automotive Manufacturers Standard 5
Marc What is the difference between ISO9001 & QS9000? QS-9000 - American Automotive Manufacturers Standard 2
Marc ISO9001-2000 vs. QS9000 - What are the differences? QS-9000 - American Automotive Manufacturers Standard 1
M Best ISO9001:2015 Auditing Company in Chicagoland? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
QualityLady414 Element 7.2 Competence, ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
S Audit Duration Calculation - ISO9001 + EN9100 with different scope General Auditing Discussions 2
K ISO9001 - Measurement Equipment records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Sam.F ISO9001/AS9100 Software Quality Assurance and Compliance Software Tools and Solutions 1
T ISO9001:2015 for Work-from-home company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 48
E ISO9001:2015 to IATF16949 Gap Analysis???? IATF 16949 - Automotive Quality Systems Standard 3
L IATF and ISO9001 IATF 16949 - Automotive Quality Systems Standard 15
D Deltas ISO9001 to TL 9000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K ISO9001:2015 clause 8 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
G Legal & Reg. Requirements - ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
S ISO9001 Major for repeat issue. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
M Management Review Inputs ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Exclusions to ISO9001:2015 Manufacturing and Related Processes 9
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M How to answer ISO9001:2015 audit finding of old revisions of documents being used? Document Control Systems, Procedures, Forms and Templates 8
S ISO9001 QMS: Quality Manual Examples & Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
T Transition from ISO9001 to AS9100D: O&G to Aerospace AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Pau Calvo Quality Management process is mandatory in ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
I Form templates for software (iso9001) Document Control Systems, Procedures, Forms and Templates 0
T COVID, Furlough and ISO9001 Surveillance Audit Coffee Break and Water Cooler Discussions 2
S Are there ISO9001:2015 Requirements for Preventive Maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
D ISO9001 for one man company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S What's meant by ISO9001 clause 8.7 non conforming output? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G Calibration: Conforming to ISO9001 Requirements General Measurement Device and Calibration Topics 6
H Communication plan according to ISO9001 - Pharmaceutical field Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
S ISO9001:2015 Clause 9.1 - What the external auditor will look at? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Is consultant prohibited in ISO9001 audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
S ISO9001:2015 6.3 - Planning of Changes - OFI from auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
I ISO9001:2015 9.1.2 - Customer Satisfaction Feedback ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
L Is writing out the ISO9001:2015 standard full name a requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
R ISO13485/ISO9001 Convenient Document Management System Document Control Systems, Procedures, Forms and Templates 3
E Interesting Discussion Was this the fastest ever stage 2 ISO9001:2015 audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 76
R ISO9001 & ISO13485 QMS for 2 types of products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
qualprod ISO9001:2015 Cl. 9.1.1 and 9.1.3 evidenced with only improvement actions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
a_bardi Excluding ISO9001 Cl. 8.4 - Supplier Selection and Evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Effect of ISO9001 2015 transition on ISO IEC 80079-34 Other ISO and International Standards and European Regulations 3
A ISO9001:2015 Process Matrix with clauses General Auditing Discussions 13
S ISO9001:2015 Cl. 4.4.1 - What Processes Do I Need Documented ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
