Isolation requirements for USB/Ethernet
eezud
I have general question about required isolation, creepage and clearance distances for medical devices with patient connections but having also connections available to USB for data and power and/or Ethernet. I searched other topics but couldn't find an exact answer, although this seems to be a general and common design issue.
Both USB and Ethernet operate in low voltage, 5V supply. Does it mean that the medical device need 2 means of protection with working voltage of 5V? In many topics, I saw people recommending 240V as working voltage because the USB can come into contact with the mains. But wouldn't that be a single fault condition? So, you need only 1 MOP for 240V?
Please check the figure J.4 from the standard. There is specified that there shall be the 2 x MOPP relating to working voltage) and 1 x MOPP relating to maximum mains voltage between SIP/SOP (e.g. USB) and patient connections.
Benjamin Weber
It is very common to regard mains voltage at SIP/SOPs as normal condition.
See cl. 8.1 a) for the background:
"Normal condition (...)
- the presence on any SIGNAL INPUT/OUTPUT PART of any voltage or current from other electrical equipment that is permitted to be connected according to the ACCOMPANYING DOCUMENTS as specified in 7.9, or, if the ACCOMPANYING DOCUMENTS place no restrictions on such other electrical equipment, the presence of the MAXIMUM MAINS VOLTAGE as specified in 8.5.3;"
The problem is, even if you specify that only a certain device shall be connected to the SIP/SOP (e.g. medical grade PC), you cannot be sure, that the operator will really adhere to this. And in the context of risk management acc. 14971 this only safey by information, the least favourable risk control measure. As a result for USB-connector mains voltage is considered as the working voltage in normal condition and an appopriate seperation should be implemented.
Additionally you will end up with much more problems regarding the necessary creepages and clearances. I discussed this her:
USB-Connection - Creepages and Clearances
F USB powered handheld medical device - Isolation requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
W Isolation requirements for Wireless ECG device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Body-worn brain stimulator (MOPP isolation requirements) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A IEC 60601-1 SIP/SIO Isolation and Touch current requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Class II PSU (200W) BF Power Supply Configuration Isolation Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Isolation of secondary grounded circuits IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
Q Isolation/Insulation Diagrams - IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T IEC60601-1: Isolation for an applied part with working voltage of 1500Vp. IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
N Triple insulated wire for transformer isolation IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Medical Device Electronics - Secondary to output isolation for 1 MOPP IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
A MOPs needed after Isolation Transformer IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Ambulance Battery Isolation - IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Isolation of Internally Powered (3.3 Vdc) ME Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R How to Determine Working Voltage & Tolerance for Isolation Barriers? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Suitable Protocol for Isolation of Clostridium perfringens Food Safety - ISO 22000, HACCP (21 CFR 120) 2
F Additional Isolation Required? Doppler Probe Desktop Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
C Medical device worn on body with USB, isolation, 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
B IEC 60601-1 2nd Clause 17 and 3rd edition - Electrical Isolation IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Ethernet Isolation Transformer for Medical Grade PCB IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
S High Voltage inside Ultrasonic Probes - Do SIP/SOP ports require isolation? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A USB Port Isolation as per IEC60601-1 - Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R USB Port (Signal I/O) Isolation as per IEC60601-1 - Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 40
D UL Certified Isolation Transformer Various Other Specifications, Standards, and related Requirements 3
apestate Vibration, Measurement and Isolation - Good ways to isolate M&TE from vibration? General Measurement Device and Calibration Topics 9
G What differentiates a "bridging transformer" from an ordinary "isolation transformer" General Measurement Device and Calibration Topics 5
D What are the acceptance criteria/requirements for Stability Study? General Measurement Device and Calibration Topics 5
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
P Requirements for being an European Representative EU Medical Device Regulations 3
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
lanley liao How to understand correctly the requirements of API monogram products Oil and Gas Industry Standards and Regulations 0
A GPS Regulatory requirements? Manufacturing and Related Processes 6
J SSQR-01 Vision Requirements- Color Blindness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
R Weld Penetration Standards and Requirements Manufacturing and Related Processes 2
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
L Requirements for Cables used for Low-Voltage DC Mains (12-36VDC) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
V MDSAP Requirements for Device Designer Canada Medical Device Regulations 1
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
S What are the International Forging Requirements for Nitrogen Strengthened Stainless Steel? EU Medical Device Regulations 3
