ISOTECH TTI-10 found out of calibration - Calibration house was wrong?
Ed Panek
QA RA Small Med Dev Company
We recently received out ISOTECH TTI-10 back from the cal house and it was "received OOC' we opened a CAPA. This device is a temperature measuring device. We ran some internal tests. We set it against an oven we have that was calibrated last month. It should be noted that my companies sole product is a temperature measuring patch that is verified and validated.
For the test we put the over to 30'C and placed the TTI-10 and 20 of our own devices in the oven. The result was that all of our patches agreed with the oven but the TTI-10 was 0.400'C over the set point.
I havean ISO 13485 audit next week. We have sent the TTI-10 to ISOTECH with our complaint for them to review this issue.
How should I defend this to the auditor that I believe the calibration house was wrong?
TLDR: We sent a device out for cal and the cal house said it was received OOC. We sell validated devices that also do the same thing the tool does and it disagrees.
dwperron
Ed,
Forgive the stupid question, but I need to follow my script.
You sent the TTI-10 out for calibration. Did you include a probe, and were they calibrated as a system?
The reason why I ask is that you do not mention anything about the probe you used with the meter, and that could be the problem.
dwperron
Did they calibrate it with the probe, or did they just do a resistance substitution with the meter?
Also, tell about the oven.
How was it calibrated? To what accuracy? What point in the oven is being monitored?
Ed Panek
It was calibrated with the probe.
The oven report is as follows:
Customer:
Address: Calibration Location:
Contact:
Manufacturer: Date Received:
Description: Date Calibrated:
Model Number: Calibration Due Date:
Serial Number: Calibration Procedure:
Asset Number: Performed By:
Ambient Temperature: 20.8° C Relative Humidity: 36.4%rh Barometric Pressure: 0
Measurement Uncertainty: See Calibration data sheet
Reviewed: Date:
Page 1 of 2
Quality Manager
10/16/18
Ambient Calibration Conditions
Vaisala Temp/Humidity Probe HMP77B P2520230 06/21/18 06/21/21
Vaisala Temp/Humidity Indicator MI70 P2310011 06/21/18 06/21/21
01/30/17 01/30/20
01/30/17
10/16/18
10/16/18
10/15/20
Calibration Date: Due Date:
01/30/20
Calibration Equipment Used
Cincinnati Sub-zero
Temperature/Humidity chamber
MCH-3-50-50-H/AC
MC1129026
57.3
CP0001
Omega Type T Probe 52 CL032250
Name/Description: Model: Serial:
Fluke Process Calibrator 744 8776014
Certificate Number: 68152-01
Certificate of Calibration
Equipment Calibrated
The Uncertainty is estimated using a coverage factor (k) of 2, providing a confidence level of approximately 95%.
This calibration is traceable to the international system of units (SI) through standards calibrated by accredited
laboratories, or through standards calibrated at NIST. This laboratory meets the requirements of ISO/IEC 17025-
2005 and ANSI/NCSL Z540-1-1994. This certificate shall not be reproduced, except in full, without prior written
approval by Auto Technology Company.
Calibration interval and tolerance can only be determined by the customer. When determining the calibration
interval and tolerance, the customer should use the governing quality policies, test procedures, and calibration data
to determine interval and tolerance of above calibrated item(s).
CALIBRATION
CERT# 2563.01
MFG/MODEL: Cert #:
Work Order No.: Date Calibrated:
All calculations and data transfers have been reviewed for accuracy and completeness
Condition
Process
Variable
Lower
Limit
As Found As Left
Upper
Limit
Uncertainty
TEMPERATURE
Cabinet -70.0° C -72.0° C -70.3° C -68.0° C 1.2° C
50.0° C 48.0° C 50.1° C 52.0° C 1.2° C
150.0° C 148.0° C 148.9° C 152.0° C 1.2° C
HUMIDITY
Cabinet 20.0 %RH 15.0 %RH 22.2 %RH 25.0 %RH 1.9 %RH
50.0 %RH 45.0 %RH 52.3 %RH 55.0 %RH 1.9 %RH
95.0 %RH 90.0 %RH 96.1 %RH 100.0 %RH 2.6 %RH
Performed By: Unless otherwise noted
As Found = As Left
Date Performed:
*N/F = Found not functioning,
Cal. Environment: the customer was alerted.
This item was not calibrated.
Notes: Customer has requested Every other Year calibration interval.
If as found is highlighted
Page 2 of 2 above, it was out of tolerance
10/16/18
20.8°C 36 %RH
n/a Tuesday, October 16, 2018
Cincinnati Sub-zero Model #
MCH-3-50-50-H/AC 68152-01
dwperron
You have a problem if you are trusting your calibrated oven's accuracy.
You are concerned that there was a 0.4°C difference between the oven and your TTI-10 meter.
Although the formatting of the calibration data you provided got scrambled, it appears that the tolerance for the oven is ± 2.0°C, with a measurement uncertainty listed of 1.2°C for the calibration. With those numbers there is no way you can declare the oven to be accurate to 0.4°C.
The meter your calibration lab used for calibrating the oven has a basic accuracy of 0.3 to 0.6°C (depending on the temperature being measured) and the Type T probe they used adds 0.5 to 1.0°C (depending on if it is special limits of error material).
They also don't declare where they are monitoring the chamber temperature during the calibration. Was it up at the top with the controller probe, or was it in the center of the chamber, or somewhere else. How does this compare to where you are monitoring the temperature? They did not do a multi-point calibration in the oven, and they do not reference the oven's temperature uniformity tolerance, so just the placement in the oven can cause considerable temperature deviations which are undocumented.
Your TTI-10 has a basic accuracy of ± 0.012°C for the meter and 0.15 to 0.3°C for the probe (depending on the class of the probe).
Unless the TTI-10 calibration was botched I'd trust your meter long before the oven.
Ed Panek
I should also mention Our Main product is a device that measures temperature validated to ASTM E1112 (2011) and it has a tolerance of +/- 0.10 'C at 37'C and it disagrees with the TTI and says it is off by 0.4 'C. at 37'C
dwperron
Since you are having the calibration reviewed by your provider you will have to wait for their response.
When you get it back you can perform a basic sanity check by making an ice bath "slushy" and checking the accuracy of your meter/probe.
A well made ice bath will give you much better accuracy than 0.4°C, so you will see if their calibration is your problem.
M Test failure Root cause not found Customer Complaints 10
M Vigilance - incident found in an article EU Medical Device Regulations 3
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
A Non-Conformances Found After 3rd Party Sorting Supplier Quality Assurance and other Supplier Issues 12
S ISO 9001 7.1.5.2 - Actions Taken When Measuring Equipment is Found to be Unfit for Use General Measurement Device and Calibration Topics 13
G Correction fluid found on documents that are reviewed Qualification and Validation (including 21 CFR Part 11) 11
supadrai Just found out the hard way that only one registration per manufacturer is allowed in Yemen, regardless of OEM or private label arrangement. Other Medical Device Regulations World-Wide 0
supadrai Informational Japan Minor Change Notification Application Form - Found it? Japan Medical Device Regulations 0
M Can we change the ProCode if a better one is found? Other US Medical Device Regulations 3
GStough Pushback on a Nonconformance Found in a Supplier Audit General Auditing Discussions 22
S Recapture Program for Measurement Devices found Out of Calibration General Measurement Device and Calibration Topics 8
GStough Nonconformance Found Outside the Audit Scope - Supplier Audit General Auditing Discussions 16
T Are internally found Medical Device Software "Bugs" Complaints? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Defect Rate for asking for an RMA - Company wants an RMA for every defect found Supplier Quality Assurance and other Supplier Issues 10
Stijloor Inmate-Produced Combat Helmets Found Defective Supplier Quality Assurance and other Supplier Issues 4
C Calibration Certificate "As Found" condition - TS16949 Section 7.6.2 General Measurement Device and Calibration Topics 7
T What to do if parameters are found to be Outside of Control Limits Document Control Systems, Procedures, Forms and Templates 5
A Does anybody know in which Standard can this attached Alarm Symbol be found? Other Medical Device Related Standards 3
B Nonconforming Parts found by our Service Department Nonconformance and Corrective Action 3
D As Found Condition - In or out of tolerance? General Measurement Device and Calibration Topics 4
J Customer found Nonconforming Product Metrics ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Internal Audit Cancellation when Nonconformances are Found Quality Manager and Management Related Issues 13
D "As Found" Condition and Calibration Interval Changes Calibration Frequency (Interval) 5
N What Would You Do If You Found Treasure - But it's not yours... Coffee Break and Water Cooler Discussions 17
D What is "As Found" in Calibration of a Measurement Device? General Measurement Device and Calibration Topics 8
R "As Found" Calibration Results for HPLCs General Measurement Device and Calibration Topics 22
Q Auditor found Form with Identical Contents but different Format - is this an NC? Document Control Systems, Procedures, Forms and Templates 28
D What should the QMS Auditor do if a Major Nonconformity is found during an Audit? Internal Auditing 11
C National/International Standard For Calibration "As Found" Readings General Measurement Device and Calibration Topics 4
Marc So, I woke up this morning and found this tree growing... Coffee Break and Water Cooler Discussions 4
Y What if the Root Cause can't be found? Nonconformance and Corrective Action 6
R Information found missing in a Medical Device Record Other US Medical Device Regulations 4
Hami812 Predicting the outcome using high No Trouble Found Rate Statistical Analysis Tools, Techniques and SPC 4
A Help needed for Fighting a specifically identified Organism found during Dose Audit Miscellaneous Environmental Standards and EMS Related Discussions 2
R Suppliers Defects found during Production Process - Supplier Scorecards Quality Tools, Improvement and Analysis 6
B CMM Stylus Calibration - Required to record the As Found condition AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S Want to buy Pinhole Diaphragm(S) per ASTM E1165-04 - Found it! Various Other Specifications, Standards, and related Requirements 3
Q Torque Wrench Issue - Incorrect method to collect the "as found data" Problem Solving, Root Cause Fault and Failure Analysis 7
S Top 10 areas where most NC's are found during CB audits? General Auditing Discussions 4
S External Auditor Findings when an Internal Audit found a Nonconformance Yesterday Document Control Systems, Procedures, Forms and Templates 11
D Found Watch - Watch is "Element" and says "New York" Coffee Break and Water Cooler Discussions 16
M "As Found" (aka "As Received") Calibration Data - ISO 13485 Requirements ISO 13485:2016 - Medical Device Quality Management Systems 8
S What is the proper flow to feedback the defective found during QA sampling check? Quality Tools, Improvement and Analysis 8
Marc Tar balls found along shore in Key West - 18 May 2010 World News 6
H Elsmar Cove Statistics Found Online Coffee Break and Water Cooler Discussions 2
J Positive Corrective Action - 3 parts found out of 20,000 pcs 9 months after delivery Inspection, Prints (Drawings), Testing, Sampling and Related Topics 33
L No Trouble Found (NTF) concept applied in Automotive Industry Nonconformance and Corrective Action 6
A Injection Mold 100% Visual Inspection - Short Shots and Debris not being found Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
T In-House Calibration - Digital Micrometer found Out of Calibration General Measurement Device and Calibration Topics 10
P Found Blue Green Rust in Bolt after Salt Spray Testing Reliability Analysis - Predictions, Testing and Standards 11
