"Issue & continuous improvement" columns in AIAG-VDA PFMEA form
morteza
Hello all,
In AIAG-VDA PFMEA form (Form C on page 163) there are 2 columns with no description on how to filling them. May some one show me how to fill these two columns (issue # and History/change authorization) with an example? what are their meanings?
Thanks all.
John C. Abnet
Teacher, sensei, kennari
Good day @morteza ;
Don't overthink this. This comes from the "optimization" portion of the AIAG/VDA PFMEA methodology.
What they are asking for here is....
ISSUE # :
This may be an internal trouble report, or "incident" number or other internally (or customer) assigned tracking number. This number may identify or reflect the impetus for a change to the PFMEA
CONTINOUS IMPROVMENT:
This is simply the action taken as result of the aforementioned "ISSUE #". For example, if "ISSUE # is an identifier for a specific process control failure, then "CONTINUOUS IMPROVEMENT" may reflect the corrective action details
NOTE: The terminology you have provided (i.e. "CONTINUOS IMPROVEMENT" ) is not consistent with most terminology associated with the optimization aspect of the AIAG/VDA pfmea. For example, "CONTINOUS IMPROVEMENT" would not be the correct terms for the "corrective action' example I provided. I would recommend a more generic term such as "action taken".
NOTE: Take care not to circumvent or duplicate your organization's current change point control methodology. If your organization already has a well defined and functioning change point control process, then I would recommend (in the fields in question that you have provided) simply POINTING to (e.g.. applying the discrete change point control tracking number) the details within your change point control tracking log, database, etc.. so there is no confusion or contradiction or redundancy.
Hope this helps.
Be well.
John C. Abnet
Good day @morteza ;
I looked a little closer at your OP. I now see that indeed, in the AIAG/VDA manual (page 163) as you describe, the form template does indeed use the exact verbiage you stated and it is not included in the optimization section. Confusing. As you will note on the referenced form, it states "optional" in this section. As you know, continuous improvement activities generally warrant an update to the PFMEA. As with the change point control advice I mentioned previously in this post, I would recommend simply pointing to your current tracking number/method for identifying the continuous improvement (change point control) activity that was the impetus for the PFMEA change. (Indeed, results of continuous improvement generally result in a controlled change, therefore, the tracking reference may be the same).
Note: The CTS software (AIAG) does NOT have the fields you are describing.
Summary: However you choose to (or not---note the example you provided states "optional"), to use those fields on the PFMEA, be sure not to replicate/duplicate/contradict from existing documenting/tracking methods your organization may use or otherwise fragment information.
Hope this helps.
Be well.
morteza
Good day @morteza ;
Hope this helps.
Be well.
Hi John,
thanks for your explanation. I thought that "ISSUE #" is the publication or edition number. and "History/Change authorization" is a summary description of change applied to the new version.
F Calibration Issue - Continuous Temperature Monitoring System was not Acceptable General Measurement Device and Calibration Topics 7
P MedWatch Report from a hospital due to a quality issue US Food and Drug Administration (FDA) 5
Marc Media Gallery Issue? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
R Problem solving activity - Three hours to fix the issue Manufacturing and Related Processes 15
I Reissuing documents due to missing version / issue numbers Document Control Systems, Procedures, Forms and Templates 3
Marc Fuel tank issue (FOD) hits Boeing’s 737 MAX - Feb 2020 World News 19
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
Ron Rompen 2D matrix issue - Parts (machined steel) returned from the customer Design and Development of Products and Processes 0
G PolyWorks Alignment Issue - How to align the part General Measurement Device and Calibration Topics 1
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
A External Auditor issue with Internal Audits Internal Auditing 7
V Every good documentation practice observation is an data integrity issue US Food and Drug Administration (FDA) 7
V What is the criteria to cite an good documentation practices observation as an data integrity related issue US Food and Drug Administration (FDA) 6
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
J Control of nonconforming product issue (AS91000) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C TL-9000 Certifying Body Issue - Auditor failed to find an issue for 10 years TL 9000 Telecommunications Standard and QuEST 16
E Determining what is good and what is bad can be subjective - when is it a quality issue? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Ed Panek Sensitive Supplier Issue - Single source supplier ISO 13485:2016 - Medical Device Quality Management Systems 6
B NB won't issue CE Certificate or return phone calls CE Marking (Conformité Européene) / CB Scheme 3
A Drawing Issue with Supplier - xb file did not match that of the pdf drawing Nonconformance and Corrective Action 4
J MAG 6 and EASA Part-145 Issue 005. EASA and JAA Aviation Standards and Requirements 0
A ISO/IEC 27001 - Issue during implementation of system IEC 27001 - Information Security Management Systems (ISMS) 3
M Saturated salts issue - Humidity Chamber General Measurement Device and Calibration Topics 5
N Do I need to approach galvanized steel sheet flatness issue with DOE? Problem Solving, Root Cause Fault and Failure Analysis 9
Sidney Vianna ASQ apparently doesn't know ISO does not issue ISO 9001 certificates? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
D Can an AS9100 auditor issue an NCR a month after the audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
K Class II Medical Device Compatibility Issue - Removal or Market withdrawal? US Food and Drug Administration (FDA) 2
J Can you stock parts without an 8130 and issue one at time of sale? Federal Aviation Administration (FAA) Standards and Requirements 2
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
K NCR or CA? We're taking any issue we have and saying its a nonconformance Nonconformance and Corrective Action 11
R DCMA QAR Service Issue - Resident Inspectors absent from the plant AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Wet Signature Document Attachments in SAP - Risk on Data Integrity issue? Records and Data - Quality, Legal and Other Evidence 6
Mikishots Definition Issue - "Issue" vs. "Risk" in ISO 9001:2015 and AS9100 Rev D (Definitions) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
F Power Cord Length Issue - Medical Device Electrical Safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Breach of Contract from Registrar (Auditor Payment Issue) Registrars and Notified Bodies 18
T EASA TAG Block 11 Status/Work issue Quality Manager and Management Related Issues 1
M Issue with CAPA system - Should Over Due CAs warrant a CAPA? Nonconformance and Corrective Action 17
S Could I issue major finding for Inadequate Procedures Supplier Quality Assurance and other Supplier Issues 17
G IEC 60601-1-2 Sample Size issue Other Medical Device Related Standards 1
M Repeatability issue in Gage R&R study for inner diameter of a bushing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
G Out of Dimensional Tolerance - MRB Audit Issue Nonconformance and Corrective Action 11
P Cross Section Issue - Dissecting a plastic part for measurement Manufacturing and Related Processes 4
R Supplier Process Review and Issue Communication SOP/Form help wanted Supplier Quality Assurance and other Supplier Issues 4
L Excel 2013 file issue - Information in the drop down menu disappears Excel .xls Spreadsheet Templates and Tools 2
J Clear Zinc Plating Corrosion issue...Need some education Manufacturing and Related Processes 4
T Excel Conditional Format Issue Excel .xls Spreadsheet Templates and Tools 16
W Profilometer Surface Roughness Tester Issue - Ball Bearings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
