Issue Dates/Revisions of Standards referenced in Internal Documents
JoCam
Hi Everyone,
Whilst compiling our integrated management system manual a thought has occurred to me, mainly due to the number of standards my Company is certified to. As I was referencing the standards and regulations I wondered whether it was necessary to include the current date or revision number after each of them, and whether you can just specify that you comply with current versions.
Your thoughts on this would be very much appreciated.
Thanks in advance,
Jo
jelly1921
Hi Jo:
My recommend is like this:
In your mannual, don't mention the date or revision number of the standards and regulations, just put the titles on it. For example, if you put ISO9001 and ISO1400 into one management manual, you just refer ISO9001, ISO14001 instead of ISO9001:2008, or ISO14001:2002. AND put a NOTE in the mannual, saying that the standards referred should be the latest revision. If so, whenever the standard changes, you only need to change the corresponding part, not whole text stating that standard, like ISO9001:2000 into ISO9001:2008, and so on.
JaxQC
I wanted to add a little expansion to the equation. The method listed of no revs in the documents is the best way but you then have other items to consider. The caveat is that you then have to address your Specification system.
· Do you have the most current spec on file & avail? (internal audit & evidence trial to prove it. If the auditor finds one off but you have 10 internal audits showing no discrepancies then maybe a minor vs no supporting evidence and a lack of internal controls-major finding)
· How do you prove it? (where do you go…backcheck to customer, ASTM website etc)
· How often do you confirm / check that it is the most current? (once a quarter, annual)
· Risk review of what if it is not the most current? (didn’t use correct spec for radio tuner-wrong station/return or medical implant-death)
· How do you handle if a customer wants product to an older specification (replacement part) rather than to the latest spec which would not be backwards compatible.
Just some things to consider at the same time.
JoCam
Thanks for these JaxQC.
I have a pretty robust system for ensuring current issues are available. I review on a monthly basis and keep superseded copies. I hope it's robust enough for our assessment bodies.
I Reissuing documents due to missing version / issue numbers Document Control Systems, Procedures, Forms and Templates 3
Marc Fuel tank issue (FOD) hits Boeing’s 737 MAX - Feb 2020 World News 16
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
Ron Rompen 2D matrix issue - Parts (machined steel) returned from the customer Design and Development of Products and Processes 0
G PolyWorks Alignment Issue - How to align the part General Measurement Device and Calibration Topics 1
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
A External Auditor issue with Internal Audits Internal Auditing 7
V Every good documentation practice observation is an data integrity issue US Food and Drug Administration (FDA) 7
V What is the criteria to cite an good documentation practices observation as an data integrity related issue US Food and Drug Administration (FDA) 6
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
J Control of nonconforming product issue (AS91000) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
C TL-9000 Certifying Body Issue - Auditor failed to find an issue for 10 years TL 9000 Telecommunications Standard and QuEST 16
E Determining what is good and what is bad can be subjective - when is it a quality issue? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Ed Panek Sensitive Supplier Issue - Single source supplier ISO 13485:2016 - Medical Device Quality Management Systems 6
B NB won't issue CE Certificate or return phone calls CE Marking (Conformité Européene) / CB Scheme 3
A Drawing Issue with Supplier - xb file did not match that of the pdf drawing Nonconformance and Corrective Action 4
J MAG 6 and EASA Part-145 Issue 005. EASA and JAA Aviation Standards and Requirements 0
A ISO/IEC 27001 - Issue during implementation of system IEC 27001 - Information Security Management Systems (ISMS) 3
M Saturated salts issue - Humidity Chamber General Measurement Device and Calibration Topics 5
N Do I need to approach galvanized steel sheet flatness issue with DOE? Problem Solving, Root Cause Fault and Failure Analysis 9
Sidney Vianna ASQ apparently doesn't know ISO does not issue ISO 9001 certificates? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
D Can an AS9100 auditor issue an NCR a month after the audit? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
K Class II Medical Device Compatibility Issue - Removal or Market withdrawal? US Food and Drug Administration (FDA) 2
J Can you stock parts without an 8130 and issue one at time of sale? Federal Aviation Administration (FAA) Standards and Requirements 2
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
K NCR or CA? We're taking any issue we have and saying its a nonconformance Nonconformance and Corrective Action 11
R DCMA QAR Service Issue - Resident Inspectors absent from the plant AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
R Wet Signature Document Attachments in SAP - Risk on Data Integrity issue? Records and Data - Quality, Legal and Other Evidence 6
Mikishots Definition Issue - "Issue" vs. "Risk" in ISO 9001:2015 and AS9100 Rev D (Definitions) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
F Power Cord Length Issue - Medical Device Electrical Safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Breach of Contract from Registrar (Auditor Payment Issue) Registrars and Notified Bodies 18
T EASA TAG Block 11 Status/Work issue Quality Manager and Management Related Issues 1
M Issue with CAPA system - Should Over Due CAs warrant a CAPA? Nonconformance and Corrective Action 17
S Could I issue major finding for Inadequate Procedures Supplier Quality Assurance and other Supplier Issues 17
G IEC 60601-1-2 Sample Size issue Other Medical Device Related Standards 1
M Repeatability issue in Gage R&R study for inner diameter of a bushing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
G Out of Dimensional Tolerance - MRB Audit Issue Nonconformance and Corrective Action 11
P Cross Section Issue - Dissecting a plastic part for measurement Manufacturing and Related Processes 4
R Supplier Process Review and Issue Communication SOP/Form help wanted Supplier Quality Assurance and other Supplier Issues 4
L Excel 2013 file issue - Information in the drop down menu disappears Excel .xls Spreadsheet Templates and Tools 2
J Clear Zinc Plating Corrosion issue...Need some education Manufacturing and Related Processes 4
T Excel Conditional Format Issue Excel .xls Spreadsheet Templates and Tools 16
W Profilometer Surface Roughness Tester Issue - Ball Bearings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N Documents in different languages - Revision and Issue Number Document Control Systems, Procedures, Forms and Templates 7
M Management Commitment signature issue in same Quality Manual Quality Management System (QMS) Manuals 8
S Does Contract Manufacturer need to issue Food Grade certificate for finished device? US Food and Drug Administration (FDA) 1
A Effective Date (of Documents) issue outlined in 21 CFR Part 820.4 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
J Keyboard issue in Word - Making me nuts Coffee Break and Water Cooler Discussions 5
