Issues with Dielectric Strength Testing - IEC 60601
Sclpt
Hello All,
This is my first time involved with 60601 testing so please forgive any ignorance.
I am working on a robotic system for orthopedic surgery currently undergoing 3rd edition 60601 (the system was previously certified to 2nd edition). Our test house is performing clause 8.8.3 by applying 1500V directly to our UPS (uninterruptable power supply) with the UPS breaking down between input and earth at around 500V.
The power flow in the system is as follows: power from the mains, to an isolation transformer (3rd edition certified) to the UPS (60950 and 62040 certified) to various components in the system (PC, monitor etc.), most importantly the cutter console (unit which powers the drill, which is 60601 3rd edition certified and has passed 8.8.3) to finally the drill which is the Type-B applied part and which contacts the patient. All components are within a metal and polyurethane enclosure under sterile drapes.
Is our test house testing this clause correctly?
Does the UPS classify as solid electrical insulation and insulation that is relied upon as means of protection?
I appreciate all insight, the test engineer is not being particularly helpful in helping me understand this issue.
Thank you
Marc
Another quick "Bump". My Thanks in advance to anyone who can help with this one.
raymond02302
Technically, 500 V can not puncture the CR/Cl between earth and input of UPS which is 950 certified. I guess the test house did not disassemble the capacitor or SPD between input and earth that will lead to increased trip current. Test house may mistake this condition for failed test.
N
NickM
Couple things:
1) Have they done the hipot at AC or DC? If they are doing it at AC, ask if they would accept doing it at DC. Most will as long as the DC value is square root of 2 times the AC value (1500x1.414=2121VDC)
2) If they insist on AC, ask what the failure progression looked like in terms of leakage current on the hipot tester and what the ramp speed and trip current limit they set.
2a) If the leakage current slowly increased as the voltage increased; that is a typically a sign of a capacitor being charged or some auxillary leakage in the produt and not typically a sign of insulation breakdown. If this was the characteristic, then I would make sure they have a hipot tester that can go to 100mA (only available on older units - newer units have a limit of 10 or 20 mA) if they insist on doing AC hipot.
2b) If the leakage current stayed very low and then all of the sudden tripped the tester; that is a sign of either an insulation breakdown (failure) or some type of suppression device (i.e., TVS) doing its job. These devices (including EMI filters) can be disconnected during the test.
3) If you are still having trouble passing, then it is time to start hipot only portions of the circuit at a time to isolate where the failure is coming from.
My experience has been that most hipot failures are not really failures. Often it is either due to the test setup (i.e., putting leads on a conductive floor or too close to each other or an earthed part) or due to not understanding the circuit you are testing.
Hope this helps.
Regards,
Nick
Sclpt
Thanks so much for the responses so far,
1.Currently they have been doing the hipot at AC voltage, I will enquire regarding DC.
2. I witnessed the failure, essentially the second he started increasing the voltage the current increased, there was no sudden tripping, it was a constant progression.
I have recieved this response from the test engineer regarding the UPS failure, but not entirely sure what to make of it.
[FONT=&quot]If you remove the VDR and GDT (in the UPS), you effectively have a layer of solid insulation between the L/N terminals of the UPS and earth (i.e. pcb material) and this is subject to the requirements of 8.8.3 for the dielectric strength test, but you are left with the problem of addressing the components bridging that insulation. [/FONT]
[FONT=&quot]8.5.1.3 states that components that are connected in parallel with an insulation, an air clearance, or a creepage distance must comply with 4.8 and 8.10.1 if they are to be regarded as a means of protection.[/FONT]
[FONT=&quot]4.8 states that all components, the failure of which could result in a hazardous situation shall be used in accordance with their specified ratings unless a specific exception is made in this standard or through the risk management process. The reliability of components that are used as means of protection shall be assessed for the conditions of use in the equipment. You do not specifically need to pass the 1500V electric strength test, but you do need to provide conclusive evidence that it meets the requirements for a means of protection under the conditions of the application.[/FONT]
[FONT=&quot]Given the requirements of EN 60950-1 and the failure of the GDT / VDR combination to meet them, I would conclude that they are not reliable for the purpose of providing a means of protection.[/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]If you can’t provide us with a sample that provides evidence of the necessary EN 60950-1:2006 compliance and the manufacturer is unable/unwilling to help resolve, I do have one final line of attack which might provide a solution. As the UPS is supplied through an isolation transformer, it should not be possible for any significant leakage current to flow to earth, so it may not be a problem if the chassis becomes connected to the input of the UPS, even if the earth is disconnected, provided that there is no other accessible point on the equipment to which a leakage current could flow. I don’t think there is, but I would need to convince myself of this. [/FONT]
raymond02302
Just Increased current in an uncontrolled manner(sudden increase) constitutes a failure. An constant progression does not constitute an failure, which is mainly because of leakage of capacitor or bleeding ressitors and SPD etc.
Capacitor complied with IEC 60384-14 (see CL 8.8.3), bleeding resistor and SPD (see IEC 60950) can by removed during Hi-pot test.
Combination of VDR and GDT is allowed used between mains input and earth, provided the GDT complies with requiremnts of CR,CL and hipot test for basic insulation (see 108/INF/471 by IECEE)
VDR alone also can be used between earth and main input for three cases,
- type B plugable equipment
- permanently mounted equipment
- equipemnt with extra earthing terminal
Sclpt
Thank you Raymond,
The test engineer has now tested at DC and at 100mA as suggested above and both failed as before, constant progression of current with voltage. According to him the GDT fails the hipot test for basic insulation (we have tested two samples).
Our equipment is type A pluggable so the VDR can't be used alone.
A OQ and reporting issues Qualification and Validation (including 21 CFR Part 11) 2
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
G Issues/Roadblocks with APQP implementation APQP and PPAP 7
G Resistance to solve Issues Customer Complaints 8
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
F Issues in Uncertainty Estimation Measurement Uncertainty (MU) 5
R Robotic weld cell - maintenance issues - expertise needed Manufacturing and Related Processes 0
K Implant Card - Full Manufacturer's Address - Space issues EU Medical Device Regulations 4
A Labeling - 2017/745 - EUMDR Requirements and Trademark Issues EU Medical Device Regulations 0
Q Connecting AS9100 D Clause 4.2 to 9.3.2 b - Interested parties and relevant issues AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
R Identifying internal issues.. at what level? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Ronen E FDA News FDA issues guidance on bench testing in premarket submissions Other US Medical Device Regulations 0
dhuot1990 Issues with REES Environmental Monitoring System Manufacturing and Related Processes 1
P Why does the standard clause use the term Issues in place of Context - ISO 27001 4.1 IEC 27001 - Information Security Management Systems (ISMS) 3
Ashok sunder How to determine the internal and external issues in ISO 45001 standard? Occupational Health & Safety Management Standards 2
CCaantley Issues with Faro Quantum S and LLP General Measurement Device and Calibration Topics 0
M FDA News The FDA Issues Final Rule on Medical Device Classification Procedures Medical Device and FDA Regulations and Standards News 0
S Risk Approach doesn't address External Issues (Auditor's Comment) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
qualprod Closing Out Negative Issues in Context and Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Private label issues For EU - Customer does not have CE Mark CE Marking (Conformité Européene) / CB Scheme 7
O Examples of the external and internal issues and their risks and opportunities IATF 16949 - Automotive Quality Systems Standard 2
Y ISO 9001:2015 Cl. 4.1 Note 1 - External and Internal issues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
bio_subbu Indian government issues guidance on Grouping Medical Devices in a Single Submission Other Medical Device Regulations World-Wide 1
qualprod External/internal issues removed as well? ISO 9001:2015 Cl. 4.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
bio_subbu India’s CDSCO Issues FAQ's on Medical Device Rule, 2017 Other Medical Device Regulations World-Wide 0
M Capturing Issues of Devices Past Lifetime Nonconformance and Corrective Action 3
A ISO 9001 Help - New Quality Manager - Upper Management Support Issues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
A EMC Emission Issues - Communication between PC and Monitor IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Looking for an example of Issues Log ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A One site of multi-site company closing - Quality transfer issues Quality Manager and Management Related Issues 7
Ronen E FDA issues draft guidance on form & content of UDI Other US Medical Device Regulations 0
Ronen E FDA issues draft guidance on additive manufacturing Other US Medical Device Regulations 1
L Packaging Issues Resulted CAR by customer Manufacturing and Related Processes 13
M What is the value of documenting in-process rework for easily-detectable issues? Quality Manager and Management Related Issues 4
bio_subbu USFDA issues draft Guidance on the Acceptance of Medical Device Clinical Data Other US Medical Device Regulations 1
M Issues with UDI additions to 21 CFR 820 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
bio_subbu USFDA issues final guidance on "Reprocessing Medical Devices in Health Care Settings" Other US Medical Device Regulations 1
V What tool do you use for systemic issues? Problem Solving, Root Cause Fault and Failure Analysis 2
J CFDA issues Guiding Opinions on Enhancing the Construction of Food and Drug Inspectio China Medical Device Regulations 1
J Customer Complaint - PPAP - Issues not called out on the print APQP and PPAP 3
Marc FDA Issues Guidance On Cybersecurity of Medical Devices Other Medical Device and Orthopedic Related Topics 1
bio_subbu FDA issues Guidance on UDI - Frequently Asked Questions, Vol. 1 Other US Medical Device Regulations 1
bio_subbu FDA issues Small Entity Compliance Guidance for UDI Other US Medical Device Regulations 1
G VoIP PBX Development Issues Misc. Quality Assurance and Business Systems Related Topics 1
Ajit Basrur FDA issues Guidance Document - Benefits-Risks Factors to consider for 510(K) US Food and Drug Administration (FDA) 1
bio_subbu India's CDSCO issues a list of Medical Devices that require Registration Other Medical Device Regulations World-Wide 8
bio_subbu USFDA issues final guidance on Global Unique Device Identification Database (GUDID) Other US Medical Device Regulations 1
Ajit Basrur FDA issues Final Guidance on Mobile Medical Apps (Applications) US Food and Drug Administration (FDA) 2
C Buffer Media Validation Issues Design and Development of Products and Processes 3
W Customer Recommendation of Supplier - Qualification Issues Supplier Quality Assurance and other Supplier Issues 2
