It is acceptable moving remote locations staff to manufacturing plant for auditing?
Ferreira_Portugal
In the company where I'm working, we are experiencing a huge issue with the CB that certificates our plants of Asia perimeter, because doesn't accept as valid the certificates of another different CB that certificates our other sites and remote locations in the rest of the world.
Basically, the issue is that the audit reports issued in 2017 for the sites + Remote locations, didn't mentioned for which other sites these remote support locations (mainly design centre issue) are working for.
Last week the CB audited one of our sites in Asia and raised 1 major NC because of this, and now we are trying to reschedule the audits in the affected European sites + attached RSL in order to get the audit reports with the description of all production sites around the world supported by the RSLs.
As this action needs to be done quickly, someone put the question if would be possible move some staff of the design centres to the production plant and do the external audit at once !!!
Is this option acceptable or is completely impossible?
:thanx:
Sidney Vianna
Post Responsibly
Re: It is acceptable moving remote locations staff to manufacturing plant for auditin
Wouldn't it be much more cost effective and timely if the remote support site audit reports were revised to indicate the scope of the audits and which manufacturing sites are supported (and how) from each remote site?
If the audits were properly conducted, it seems that it is more of a matter of documenting the scope of the audit(s) and the connections between the support sites and the manufacturing plants. If I were you, I would ask your IATF CB if they would accept that as a correction, instead of demanding a whole new round of audits for the remote sites.
Boa sorte.
Ferreira_Portugal
Hello Sidney Vianna and thanks by your quick reply, Much appreciated.
We already tried to get the changes in the last year audit reports, but unfortunately the CB that cover the sites out of Asia doesn't want to change anything in the reports because they say that they have respected the certification rules in 2017 and in 2018 they're already stating in the reports the plants supported by development centers...
So, my conclusion is that this is an issue between CBs and we are in the middle of the fight....
Anyway, what we are trying to do is to attach the remote design centers to other production sites which will be audited in the coming weeks and try in this way getting the new audit report with the indication of the plants around the world supported by the design centers.
My concern at this time it is if is accepted by the CB that some staff from the design centers travel to the manufacturing site in order to be audited OR if it is imposed by IATF rules that the audit needs to be done in the remote location physical place.
Sidney Vianna
Post Responsibly
People don't get audited. The system does. And the general expectation is that the system being audited is representative of the system and processes, when it is not being audited. So, if the design center personnel work at the remote locations, with the remote site infrastructure, support, etc...the system should be audited where the processes happen, i.e., remotely. Otherwise, it would not be representative of the actual system being approved, in my opinion.
Since the IATF 16949 transition deadline is quickly approaching, I would think CB's would be hard pressed to find the resources for these "unexpected" audits.
M When a moving range is 0, is it acceptable to have a PP/PPK of 0 also? Statistical Analysis Tools, Techniques and SPC 8
R Using RPN to Confirm Risk Reduced to an Acceptable Level Risk Management Principles and Generic Guidelines 12
Eva lee Which is the range for the validated batch size(for example ±5%, 10%) is acceptable? Manufacturing and Related Processes 8
S Examples of FDA acceptable Software Design Specification (SDS) Medical Device and FDA Regulations and Standards News 6
Q Acceptable Tolerance - how to derive? Measurement Uncertainty (MU) 16
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
M Are Fungal counts acceptable in class 1000 clean rooms? Other ISO and International Standards and European Regulations 2
T ISO 14971-2019 doubt - Evaluate if estimated risks are acceptable ISO 14971 - Medical Device Risk Management 9
samer Acceptable limits for Spills - Tracking Hydraulic Spills ISO 14001:2015 Specific Discussions 3
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
Q Is it acceptable to mix components from two different lots into an assembly? ISO 13485:2016 - Medical Device Quality Management Systems 1
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Risk Register - have we considered enough and is the format acceptable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Operator Checks - How to show that they were completed on a checklist as acceptable IATF 16949 - Automotive Quality Systems Standard 2
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
S Dates on Labels acceptable to the USA - GS1 General Specification 3.4.4 Other US Medical Device Regulations 3
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
W Unattached (stand-alone) Forms acceptable for AS9100C? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
X Acceptable methods to store and archive records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Is it acceptable to audit to the Nuclear Principles? Quality Manager and Management Related Issues 9
I Is it acceptable it is to list new products under an existing 510(k)? Other US Medical Device Regulations 14
S If this EN ISO 11137 certificate acceptable for Contract Sterilization? ISO 13485:2016 - Medical Device Quality Management Systems 2
D What is satisfactory & acceptable for Coliform - Staphylococcus - Hands and Surfaces Food Safety - ISO 22000, HACCP (21 CFR 120) 3
S Is a Dynamic Controlled Form acceptable per 21CFR820 Document Control Systems, Procedures, Forms and Templates 3
C Lowest Acceptable Grade for Master Gage Set Calibration and Metrology Software and Hardware 1
B Digital Signature Solutions acceptable to use in an FDA Medical Device Environment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Is a ndc less than five is also acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T Technical regulations that determine the acceptable limits of cigarettes General Measurement Device and Calibration Topics 4
L IEC 60601-1 3rd edition Clause 9.2.2 Trapping Zone (Acceptable Gaps) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
N Is it acceptable to sterilize products without claiming and labeling "sterile" ? ISO 13485:2016 - Medical Device Quality Management Systems 6
M Quality Objectives - Acceptable Levels and Functions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
C What is an acceptable bioburden level or count when working in cleanroom ISO class7 ISO 13485:2016 - Medical Device Quality Management Systems 1
D Is embedding documents within a Contract an acceptable practice ? Contract Review Process 9
B Non Acceptable % Tolerance Result - Decrease Sorting Limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Maximum acceptable Tolerance - Uncertainty Ratio (TUR) General Measurement Device and Calibration Topics 2
S Is it acceptable to have an ASL for Critical suppliers alone? Supplier Quality Assurance and other Supplier Issues 4
S Is this Quality Policy acceptable in the context of ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 24
A Help with acceptable screw gage values per standard BS 919 for Go/ No Go gage General Measurement Device and Calibration Topics 4
S What are typical Acceptable Quality Levels (AQL) adopted in Food industry? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
somashekar Who can provide a WHO GMP certificate in India acceptable to the CDSCO Other Medical Device Regulations World-Wide 6
D Root Cause and Corrective Action - Is our Practice Acceptable? ISO 13485:2016 - Medical Device Quality Management Systems 5
W Application of AQL (Acceptable Quality Level) Concept AQL - Acceptable Quality Level 15
H Acceptable Time to provide proof of CAR (Corrective Action Report) Nonconformance and Corrective Action 4
A Sample Size for Mathematical Model with acceptable Confidence Level Using Minitab Software 7
