Job Shop Inspection and Test - Where should we establish inspections? Why?
Mike S.
Happy to be Alive
#21
M Greenaway said:
No apparently about it Mike.
Traceability to raw material is only a requirement where terms of a contract specify it as such.
Internal controls on traceability are only there to aid positive identification to take effective containment action in the event of a problem. The looser the controls the wider the containment action would have to be. If your product is low risk/value then maybe you neednt have traceability whatsoever.
Well...not exactly.
It is possible that the terms of the contract require it but the company is not doing it (purposefully or by oversight). Also, a company may specify in their own internal procedures that they shall maintain traceability but they are violating their own procedures and not doing it. While I doubt that is the case, 'tis why I said "apparently".
Also, I think there are other reasons for maintaining traceability than just for containment reasons in the event of a problem.
JMO.
apestate
#22
I have no problem having traceability on every part back to barstock supplier.
I'd like to go further and use lot numbers to separate parts made on a certain day from parts made on another day. This might have to wait until things settle down!
Change is a limited resource sometimes, and you've got to use it sparingly.
Well, to clarify, I think that being able to trace back to the material certification for each part made is plenty traceability for now. It's all that is required of us regarding that. Lots will be viewed from the eyes of continual improvement.
This afternoon I will be printing the job routers on green. They include identification, material supplier(s) (which is Supplier and Date Recieved, which is how we file the certs), Then the order of operations with a box to indicate required inspection, and what inspection type.
So at one glance you can see that the Operation is 10. Turn it over and you see that this means Machine to spec 1st operation. Before you can move to 11, you've got to have a certain inspection signed off if indicated. The first operation 10 on a simple part with ample tolerances would fall under Inspection type C, which is the standard once an hour sample plan.
This gets filled out on the first parts router before the job goes out for setup. Subsequent routers are filled out by the QA.
Is there anything else I can accomplish with this router that I might want to include?
bobdoering
Stop X-bar/R Madness!!
#23
Wow, this thread has a lot of retro ideas - how far we have gone in just a few years!
1) First step: gage calibration and gage R&R, make sure you are using the correct gage for the job!
2) Incoming inspection: sure, everybody wants to believe their vendor sent the right stuff, but it sure doesn't hurt to make sure. Sometimes the first metal forming step in a process is done on the truck from the steel warehouse to your dock! Am I right? Of course I am. Check the chemistries on the certs - I have seen bad material certified bad (or good for that matter), and they missed it and shipped it. Cheaper to check it before screwing up your scheduling with scrap and rework.
3) Screw machine/CNC/grinding (and all other precision machining) inspection: Check the tightest dimension and/or the dimension that wears the quickest for each tool that makes a final dimension off of the machine. Keep the data separate by spindle (especially when doing capability verification). SPC using X hi-lo/R chart if you wish (See Statistical process control for precision machining), or at least run to 75% of the specification. Do not use Xbar-R charts, it is the worst and most useless chart for machining, bar none. Do not use precontrol charts, they also provide the wrong direction - they encourage overcontrol. Do not run to the mean. That is back yard hack. For ODs: set up near the lower control limit, and let the tool wear to the upper control limit before removing for replacement or sharpening. For IDs, start at the upper limit and let the tool wear to the lower control limit before removing for replacement or sharpening.
To determine the frequency, do an X hi/lo-R chart capability study of 100 consecutive parts. Do each spindle separately. Calculate the linear regression on the upper and lower X plots. Extrapolate them to the control limits, if 100 parts does not provide enough wear to make it to the control limits on their own. For the number of parts is takes to go from where the X-lo is at the lower control limit to where the X-hi hits the upper control limit, divide that number of parts by 5. That is your minimum frequency for charting.
Just because you chart, and the data is in control, can you assume the product is ok automatically. You should inspect the last part (from each spindle) prior to moving the lot to the next operation - or a special cause (broken tool, etc.) might have occurred, you would not know it, and you are moving scrap. ALWAYS check the last parts to ensure the tools did not break or chip out. Otherwise, you will be sorting all over the shop, rather than containing at the operation.
4) Do incoming inspection on plating thickness and hardness, unless you have some rare world class suppliers. Train your outsourced precision machining suppliers (grinders, etc.) on correct SPC described above, and then sample incoming product. Do not look for Cpk of incoming product, if they are running their process correctly, it will not be relevant, and your sampling error will give you ridiculous conclusions. Statistical process control for precision machining - Sampling Error Just be sure that all of the sample you take are in spec.
5) If you are doing heat treating and plating, you need lot traceability. If you end up with a raw material that does not harden correctly, you do not want to throw out any more product than the lot of material made. Think - what is the point of traceability? It is not just extra paperwork. Somebody got burned - bad - and they figured out traceability is the only way to keep it happening to you. Learn from other's mistakes. Some people make lots by operator or shift...just in case. Really helps during training a new employee.
There - now we have freshened this up a bit! :cool:
S Current Inspection Standard for AS9100 Certified Job Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L In-Process and Final Inspection for a job shop (Machine) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B Product Safety Responsibility - Job shop such as a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
JAMESH Building a "Lean" Job Shop Training Program Training - Internal, External, Online and Distance Learning 0
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
M AS9100D excluding Design and Development - Small Job Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
S Job travelers through a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Gage Identification Methods in a Job Shop Calibration Frequency (Interval) 8
Q Help With Airflow Control in a mid sized Job Shop in Southwest Florida Manufacturing and Related Processes 2
B How did you grow your QMS in a Job Shop? Quality Manager and Management Related Issues 11
N Improvement in a Medical Plastics Compounder Job Shop - Any thoughts? Preventive Action and Continuous Improvement 14
S Scheduling Jobs through a fast paced Sheet Metal Job Shop Manufacturing and Related Processes 5
E Production Planning in an Industrial Machine JOB SHOP Lean in Manufacturing and Service Industries 1
B Using Job Shop ERP Software for a QMS Quality Assurance and Compliance Software Tools and Solutions 2
K Job Shop - Registering to AS9100 vs. ISO 9001 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 27
B Environmental Objectives and Targets for Job Shop Miscellaneous Environmental Standards and EMS Related Discussions 5
G Universal FMEA - Small job shop stamper FMEA and Control Plans 3
L How to Avoid Missed Welds - Job shop and weld several small quantity jobs Manufacturing and Related Processes 11
H Determining Customer Satisfaction in a Small Aerospace Job Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Separating Customers not requiring AS9100 - Sheet metal and machine job shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Legacy products in an AS9100 QMS precision machining job shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C SPC on the shop floor - We are a job shop Statistical Analysis Tools, Techniques and SPC 5
B Is SPC appropriate in batch system/Job Shop? Statistical Analysis Tools, Techniques and SPC 5
CarolX Record retention ideas for a sheet metal job shop supplying to a medical device mfg. ISO 13485:2016 - Medical Device Quality Management Systems 11
B Outgoing Quality for a Material Handling Systems Job Shop Misc. Quality Assurance and Business Systems Related Topics 3
H Positive Recall - How it should work in a small job shop - 7.4.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
H Audit Segregation by Product - ISO 9001 & AS 9100 in a small machine (job) shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A How should I implement work instructions when we are sort of a job shop? Document Control Systems, Procedures, Forms and Templates 6
R Adjustable c-type gauges and calibration - Small job shop General Measurement Device and Calibration Topics 2
T Mexico Job Shop - ISO 9001 Certification Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
I Lean in the Tool and Die Industry (Job Shop) - Applying Lean in "one-off" production Lean in Manufacturing and Service Industries 6
P SPC in job shop? CNC machine producing a max of 50 pieces per job Statistical Analysis Tools, Techniques and SPC 4
J Small Machine Shop - No process planning or job scheduling - ISO 9001 Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G JobBoss: Anyone using this Job Shop Management Software?? Quality Assurance and Compliance Software Tools and Solutions 4
G Low Hanging Fruit - Lean Manufacturing Ideas for a Job Shop Lean in Manufacturing and Service Industries 9
M ISO 13485 - Risk Assessment for medical device job shop ISO 13485:2016 - Medical Device Quality Management Systems 4
apestate Job shop seeking QMS intends to manufacture devices, is ISO-13485 appropriate? ISO 13485:2016 - Medical Device Quality Management Systems 11
CarolX NAFTA Certificate of Origin - Sheet metal job shop - Customer Request Various Other Specifications, Standards, and related Requirements 3
G DPPM Industry Standard - Metal fabrication (Job shop) Misc. Quality Assurance and Business Systems Related Topics 3
T Pin gage identification in a small CNC/Screw machine job shop General Measurement Device and Calibration Topics 9
R Job Shop vs. Service - Identification of jobs between departments Service Industry Specific Topics 8
G Workmanship Standard that I can use as a procedure in a job shop environment? Document Control Systems, Procedures, Forms and Templates 6
J Quality in Job Shop Environment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
was named killer Job Opportunity-Quality Engineer-Tampa Florida Job Openings, Consulting and Employment Opportunities 0
Marc Job Opportunity – Quality Assurance Specialist - Suspense 7 April 2021 Job Openings, Consulting and Employment Opportunities 0
L Job Aids for administrative staff in GLP environment Document Control Systems, Procedures, Forms and Templates 6
B Qualifcations of Staffing Agency Employees to meet job description General Auditing Discussions 6
K Looking for a job as Quality Engineer Career and Occupation Discussions 2
J New Job Position - Achieving ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 5
XRAY_3121 New Job with Wholesale Distributor Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
